Engine air filter OEM vs replacement
Discussion in '5th Gen 4Runners (2010-2024)' started by roymm, Aug 19, 2022.
  1. Oct 31, 2025 at 3:55 PM
    #151
    My Mahle air filter arrived today.
    Similar in dimensions and construction to the Napa (supposedly Wix) filter I was replacing. Weight was similar between the two.
    The Mahle does have a thinner pre-filter. To my untrained eye, it looked like the Mahle may have more pleats than the Napa filter but I didn't count because I'm lazy and @GrizzlyPro already said he was going to put in the hard yards, so I will leave that up to him. :thumbsup:
    It's made in China, just like most of them. They probably make all the brands in the same factory to whatever spec they're told to and then slap a different name on it.
    Lc200, GrizzlyPro and 2Toys like this.
  2. Oct 31, 2025 at 3:56 PM
    #152
    :eek:
  3. Oct 31, 2025 at 8:18 PM
    #153
    See the filter box advertises "no hassle lifetime warranty". When the engine blows up, I can transfer the filter to the next engine :thumbsup:
    Shredder and nimby[QUOTED] like this.
  4. Oct 31, 2025 at 8:24 PM
    #154
    4onto
    4onto New Member
    Toronto
    2009 SR5 V6 4WD
    Years ago, this guy from work would buy those Fram Air Hog filters wholesaler closeout from Rock Auto. He has a big collection of vehicles.
  5. Oct 31, 2025 at 11:44 PM
    #155
    It doesn’t count as reusing it if it stays stuck on for 10 years of oil changes. Now if it falls off and then I put it back on, then yes, that counts as reusing it, which is an abomination.
    Speaking of abominations!!!! A knock-off K&N filter?
    2Toys likes this.
  6. Nov 1, 2025 at 4:18 PM
    #156
    ^Not a knock-off. K&N owns several brands, among them Airaid and AEM (maker of TRD intake).
  7. Nov 1, 2025 at 4:42 PM
    #157
  8. Nov 1, 2025 at 6:38 PM
    #158
    ^It's like comparing Goodyear tires with Cooper or Mickey Thompson. The tires are not the same and perform differently on the trail, but they're from the same company.
    kmeeg[QUOTED] likes this.
  9. Nov 1, 2025 at 7:35 PM
    #159
    4onto
    4onto New Member
    Toronto
    2009 SR5 V6 4WD
    kolter45 and kmeeg[QUOTED] like this.
  10. Nov 2, 2025 at 5:07 AM
    #160
    GrizzlyPro
    GrizzlyPro New Member
    2016 Quicksand 4Runner TRD Pro
    Dobinson snorkel, Hefty Fab Banshee bumper, Superwinch SX10SR, Gobi rack and widdle wadder and some aux lighting
    Well crap! Received my Mahle LX3003 and was very happy with how it felt and how good the seal looked. Did some measurements but will not share those yet since I have to return it. It is a 1/4” shorter and doesn’t fit the air box at all. So I might be missing a few pleats.
  11. Nov 2, 2025 at 8:52 AM
    #161
    Interesting.
    Mine was slightly shorter as well.
    It fit in the air box but I'm now questioning the integrity of the seal.
    Having this new info, I don't think you're going to get another one that's longer. Sounds like they're cut a little short.
  12. Nov 2, 2025 at 10:05 AM
    #162
    GrizzlyPro
    That is frustrating. Well when they send the next one I will measure and the call and report the same issue. Then will probably check out the Baldwin next
    nimby[QUOTED] likes this.
  13. Nov 2, 2025 at 5:53 PM
    #163
    "High bypass ratio" air filter :cool:
    Saker, nimby, Yamahamer and 1 other person like this.
  14. Nov 2, 2025 at 6:36 PM
    #164
    GrizzlyPro
    That’s how they are able to keep flow rate up with such a high filtration ratio ;)
    nimby likes this.
  15. Nov 7, 2025 at 6:38 PM
    #165
    GrizzlyPro
    Well it is still a 1/4” short. Will be calling my contact at Mahle about this production issue. Even on Rock Auto it says the length is 12.6” and I was measuring 12.25”. Definitely a manufacturing discrepancy. Got a credit from Rock Auto and will get the Baldwin next. Hoping Mahle sends me a sample in the future after they make any changes.
  16. Nov 7, 2025 at 6:50 PM
    #166
    Dude. Just go to Walmart and buy a cheap Fram filter, install it and forget about it. Repeat every year or two. Your engine will love you.
    GrizzlyPro[QUOTED] likes this.
  17. Nov 7, 2025 at 7:01 PM
    #167
    GrizzlyPro
    I think you are finally understanding the level of OCD I have ;)
  18. Nov 7, 2025 at 8:25 PM
    #168
    :rofl::rofl::rofl:
    You know it would sell if they market it like that! Lol
  19. Nov 7, 2025 at 8:38 PM
    #169
    kolter45
    Denver
    Inferno Pro & BRM Sport
  20. Dec 4, 2025 at 9:44 AM
    #170
    GrizzlyPro
    Back from vacation and saw my Baldwin PA4435 filter came in.
    Dimensions:
    12.5" x 9.25" so this will fit the airbox correctly.
    Filter area:
    - Pleat count: 109
    - Pleat depth: 1.8125"
    - Pleat width: 8.65625"
    - Total filtration area: 3,420.3 in^2
    Filter efficiency that was stated a while back is 99.6%
    Still waiting on a response from Mahle. I also purchased the YZZ filter from Toyota to see if the dimensions were any different for the gasket area. It ended up being the same dimensions as the previous YZZ, Japanese Denso and the Baldwin. So Mahle definitely dropped the ball on tolerancing. Also to note the YZZ filter that I just got has even worse pitting on the gasket than the previous one I had.
    I know people have said why worry about this so much. I just want to say again this is for research and to give better knowledge out there, not to sway anyone away from what they choose for their vehicle!
    2Toys and nimby like this.
  21. Dec 4, 2025 at 9:50 AM
    #171
    4onto
    4onto New Member
    Toronto
    2009 SR5 V6 4WD
    Here I thought you were gonna leave us all hangin'.
  22. Dec 4, 2025 at 10:03 AM
    #172
    I switched over to a Wix 49350.
    99.5% efficiency rating.
    We don't know for sure, but I'm assuming the efficiency rating on the Wix is similar to the stock Denso filter that came with the 4Runner (now the Lexus GX filter). I'm also assuming it has a better efficiency rating than the YZZ filters.
    Guppy1301 and GrizzlyPro[QUOTED] like this.
  23. Dec 4, 2025 at 11:23 AM
    #173
    GrizzlyPro
    :D
  24. Dec 4, 2025 at 11:24 AM
    #174
    GrizzlyPro
    After seeing how the gasket is messed up I will never use the YZZ. Build quality is definitely economy style.
  25. Dec 4, 2025 at 3:17 PM
    #175
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    Wix fan here. I change once or twice a year. Cheap insurance.......
    nimby likes this.
  26. Dec 4, 2025 at 4:51 PM
    #176
    4onto
    4onto New Member
    Toronto
    2009 SR5 V6 4WD
    Some Beck/Arnley air filter porn. You're welcome.
    nimby, GrizzlyPro and icebear like this.
  27. Dec 4, 2025 at 7:09 PM
    #177
    GrizzlyPro
    Wow that is a large pre filter pad. Definitely would make others blush!
    nimby and 4onto[QUOTED] like this.
  28. Dec 4, 2025 at 11:44 PM
    #178
    4onto
    4onto New Member
    Toronto
    2009 SR5 V6 4WD
    For those who like 'em thicc.
    nimby and GrizzlyPro[QUOTED] like this.
  29. Dec 5, 2025 at 7:45 AM
    #179
    I’m going to install a $4 Purolator filter this weekend. I’ll probably reduce the life of the engine to 499K miles instead of 500K miles. :D
    Yamahamer likes this.
  30. Dec 5, 2025 at 9:58 AM
    #180
    I used to change them a couple times a year but I think it's actually better to let them get a little dirty.
    Dirt attracts dirt which allows the dirt to become part of the filtration process and less of it to make it through.
    Oscar, GrizzlyPro and 2ndGen22re like this.
