End Caps for hatch
Discussion in '5th Gen 4Runners (2010-2024)' started by Diazraf, Dec 30, 2024.
  1. Dec 30, 2024 at 12:58 PM
    Diazraf
    Diazraf [OP] New Member
    21 4Runner Premium
    Work in progress.
    Hello, I am interested in ordering those end caps at the bottom of the hatch when opened. Every time I wash my truck and open the hatch to dry it, those little holes where the bolts go collect some water and I dry them. Wondering if with those caps water still collecting and bolts will rust.
    Anybody have any experience with this product? Thanks
    Happy New Year to all!!
  2. Dec 30, 2024 at 9:30 PM
    I got a set from Etsy, but haven't checked for water in there after washing. I usually wash mine at home with low pressure, so not a lot of water gets in there. I got 'em mostly for looks, and stuff doesn't stay wet around here long enough to rust.
    Diazraf[QUOTED][OP] and Saker like this.
  3. Dec 30, 2024 at 10:33 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Hey I’ve taken my rear bumper cover off and those bolts out a number of times living in a salty area and they aren’t rusty. No caps since 2016. I doubt the caps are water tight in any way..
    They do look really nice tho
    Diazraf[QUOTED][OP] likes this.
  4. Dec 30, 2024 at 11:02 PM
    The bolts still have the factory black finish on my 2010 after 14 salty winters. Don't worry about them.
    Diazraf[QUOTED][OP] and djwantke like this.
  5. Dec 30, 2024 at 11:35 PM
    If anything they will trap moisture. They’re just for aesthetics.
    Diazraf[OP] likes this.
  6. Dec 31, 2024 at 7:41 AM
    Oh, you mean these! I got mine on Etsy.
    https://www.etsy.com/listing/166234...ad3b243b5%3A1662341667&organic_search_click=1
    jwctaco and Diazraf[QUOTED][OP] like this.
  7. Dec 31, 2024 at 8:53 AM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    I got my bolt covers from this Etsy shop. HoneyIslandDesign. I’m pretty happy with them. Use a little dab of adhesive on the bolt heads for extra holding power.
    https://www.etsy.com/listing/152399...1&ref=landingpage_similar_listing_top-1&sts=1
  8. Dec 31, 2024 at 9:45 AM
    dbtong
    dbtong New Member
    Dave
    San Jose, CA
    2024 ORP
  9. Dec 31, 2024 at 10:31 AM
    I love them. I often forget they are there. They snapped right in and are snug. I have had them for…..5months?
  10. Dec 31, 2024 at 11:11 AM
    Agree. If somebody is worried about corrosion on anything, the worst thing you could probably do is cover it. Rust doesn’t become a problem just because the metal gets wet. It becomes a problem when the metal never quite dries.
  11. Dec 31, 2024 at 12:23 PM
    They look great for sure though.
  12. Dec 31, 2024 at 5:56 PM
    VicNic3
    VicNic3 New Member
    Georgia
    2024 Toyota TRD Pro 4Runner
  13. Dec 31, 2024 at 6:26 PM
    4runningMan
    4runningMan New Member
    New Mexico
    Agreed. The water sits below the bolt. And why cover it so it takes longer to dry out or may even trap water? Cover seems counterintuitive.
  14. Dec 31, 2024 at 6:42 PM
    mac1usa
    mac1usa New Member
    I wiped mine down after hand washing. I debated taking an artist brush and putting sole fluid film on all those. Every used unit I saw these were rusted. Same thing for these screws in front wheel wells. Sort of chincey.
  15. Jan 2, 2025 at 5:55 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    The HoneyIslandDesign ones listed above have a drain hole at the bottom. It’s actual a pretty cool design. I’ll examine mine after this winter to see how they held up.
  16. Jan 2, 2025 at 10:04 PM
    4runningMan
    New Mexico
    Those crannies can't drain by design. Each one is a bowl. A hole in a cap/cover won't do anything to change that?
  17. Jan 7, 2025 at 2:27 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    OK, I just had to check. This is after 3 trips and many weeks and miles of dusty sandy trails in southern Utah, a few rainstorms, and a few car washes.
    See how the insert covers the bolt. And BTW the bolt (anodized?) stands off and is above the bowl so it will not sit in any water that may collect there. Notice the collection of red dust at the bottom where it drained and dried, with no dust on the bolt head. There are grippy rubber strips along the sides and bottom that provide the tight friction fit.
    It looks like a pretty effective design to me.
