Elka 2.5 vs stock TRD Pro Fox 2.5 vs ???
Discussion in 'General 4Runner Talk' started by Klinsman55, May 1, 2022.
  1. May 1, 2022 at 8:22 AM
    Klinsman55
    Klinsman55 [OP] New Member
    K
    Northern Nevada
    2024 LE silver
    XREAS. Cooper Discoverer Road and Trail AT 255/75r17. Trd Pro Wheels
    Looking for:
    On-road: a smooth soft Cadillac ride
    Off-road (at speed 25-40mph): 1-2 hour drives over washboards, whoops, fire roads etc (think Death Valley ), would like a soft non jarring ride.
    No rock crawling anticipated.
    will need 2.5 shocks with reservoirs. From what I can gather from reading through posts is that Fox 2.5 and Elka tend to run on the softer side. Is Toyotec same as Elka?
    Debating getting a TRD OR and putting Elka’s or Fox 2.5’s on it with a a 1-1.5” lift and 275/70/17 tires. Probably cost me with parts and labor around $7-8k(close to TRD Pro cost now)
    Or
    TRD Pro and it might be good enough
    Or
    TRD Pro and rip the shocks off and put either the Elka or Fox shocks on.
    wondering if anyone has experience between these shocks and which is the better softer smoother ride for said situations.
  2. May 1, 2022 at 8:26 AM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    Stock pro suspension is a solid set up and super smooth. I just wanted more travel so upgraded to 2.5
    elka is a great set up, as well. Not as commonly used
  3. May 1, 2022 at 8:37 AM
    TRD Pro fox shocks are pathetic compared to ELKA2.5DC. Also TRD Pro shocks not meant to have good flex when lifted. Buy longer shocks if you want flex after lift.
    275 tires don't have good options. I would vote for 285s and do minor trimming.
    Nowadays ELKA are very expensive. For the same amount of money I would even look at Accutune offroad tuned Fox2.5DCs.
    Thatbassguy and Klinsman55[OP] like this.
  4. May 1, 2022 at 8:46 AM
    afret
    North Idaho
    I wish I could find a set of shocks that gives me 25-40 MPG at speed or even going slow. ;)
  5. May 1, 2022 at 8:47 AM
    Klinsman55
    K
    Northern Nevada
    2024 LE silver
    Ha. Good catch
  6. May 1, 2022 at 8:17 PM
    slixx1320
    slixx1320 New Member
    Elka builds toytec suspensions. So they are virtually the same except no DC and they’re red. If you don’t need the dual adjusters go for toytec. I’d even consider looking into dobinson.
  7. May 2, 2022 at 2:40 PM
    Bilstein 8112/8110 will give you more control over the way your shocks ride when compared to Elka, Fox, King, or any other high end options on the market. Might want to look into those if you're looking to dial in the ride quality to your specs.
    Klinsman55[OP] likes this.
  8. May 3, 2022 at 6:46 AM
    Klinsman55
    K
    Northern Nevada
    2024 LE silver
    Hmmm, I’ve heard of those Bilstein 8112/8110’s but haven’t really looked them up. Is Bilstein known for better reliability compared to say Fox? I guess the Pro used to use Bilstein shocks so they must have liked their reliability
  9. May 3, 2022 at 6:58 AM
    Bilstein makes high quality products.
    The thing that the 8112/8100's offer that the other shocks don't are an adjustable internal bypass system which allow you to adjust the rebound and compression so it rides like you want.
    Klinsman55[OP] and kmeeg like this.
  10. Nov 11, 2022 at 2:28 PM
    blackcloud08
    blackcloud08 They're Watching Us....
    Elka 2.5 or King 2.5 with E load tires at about 35 psi up front and 30 psi in rear(always follow the psi ratings from tire manufacturer for safety and legal reasons.) With that length of time on wash boards you need remote resi's to keep from cooking the fluid. If you don't go with a remote resi stay away from anything with a steel body if going on wash board roads that long. PRO's are mostly a status or for people who want to leave suspension/tire size as is, no way I'd buy a PRO and remove the only thing of additional value(fox shocks) over an OR / ORP. So if you want a better riding 4runner, get an OR / ORP and invest in high quality suspension with the money you saved and throw some PRO badges on it.
