Electrical issues. I’m stumped
Discussion in '4th Gen 4Runners (2003-2009)' started by 13tanner, Apr 25, 2021.
  1. Apr 25, 2021 at 6:29 PM
    13tanner
    13tanner [OP] New Member
    Tanner
    2007 4Runner silver
    Icon stage one coilovers Spc uca’s 33’s
    I was outside today I noticed something weird...
    The rear wiper on my 2007 4Runner was on, while I’m outside of it and it’s locked with no keys in the ignition. I got in and I noticed some other gremlins. The small display showing outside temp, time, and climate control is also still on with no key. Along with the blend door selection light and the recirculation button light.
    This is all intermittent. I’ll hear some relays clicking under the dash and the rear wiper will turn on or any or all of those displays will come on. All with the ignition in the off position.
    I’ve checked simple things like battery is clean and at 12.5v. There’s no blown fuses
    13.6v at idle.
    Wiggled different parts of the harness to see if it may affect it (shorted wire?)
    I’ve unplugged the ignition switch and it is still happening
    I’ve unplugged the wiper switch (in steering column) and it is still happening.
    It has no issues starting or running and when it’s running with key on everything works as it should.
    I’ve researched for a couple hours now and I can’t seems to find anyone that’s had a similar issue. Any ideas or help with this would be great!
  2. Apr 25, 2021 at 7:07 PM
    Check for a short on your trailer hitch??
  3. Apr 25, 2021 at 7:14 PM
    13tanner
    Tanner
    2007 4Runner silver
    I will definitely check that tomorrow with some light, thanks!
  4. Apr 26, 2021 at 2:19 PM
    13tanner
    Tanner
    2007 4Runner silver
    No issues with the trailer wiring connection.
    I’ve pulled all fuses to see when the displays will turn off and the only ones are IG1 and Ecu-IG. As well as under the hood, the “short pin”
    *also just found that if, and only if I put the front wipers to high everything will turn off.*
  5. Apr 27, 2021 at 8:00 AM
    importman
    importman The mountains are calling and I must go...
    Danny
    Carolinas
    05 Silver SR5 V6 4X4
    Blacked out, Ironman 3" Nitro Gas Suspension lift, JBA High Caster upper control arms, Differential drop and sway bar relocate, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX100 with Apple Carplay, USB Jack, Backup Camera, Black TRD Pro Wheels with General Grabber ATX 265/70/17, Rear differential vent extension, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Weathertech floor mats, Homemade rear storage compartment with built in pull out table.
    That battery voltage at 12.5 is a little low. Should be 12.6 or higher. Just for curiosity I just checked mine and it was 12.82. Not sure if that could cause your gremlins but these cars are known for having a weird glitch related to the battery and the rear wiper. When the battery gets weak a lot of times the rear wiper will wipe one time when cranking. And if I read you post correctly it doesn't do it when the engine is running, which would have your voltage higher. Worth looking at anyway. Good luck with it.
    13tanner[OP] likes this.
  6. Apr 27, 2021 at 8:22 AM
    13tanner
    Tanner
    2007 4Runner silver
    Correct, these issues only persist once the key is off. Everything functions like it should while key is on. I’ll definitely look more into the battery and go get it tested. I was thinking that if the battery had an internal short or bad cell that the voltage would be much lower
  7. Apr 27, 2021 at 8:34 AM
    13tanner
    Tanner
    2007 4Runner silver
  8. Apr 27, 2021 at 8:58 AM
    importman
    Danny
    Carolinas
    Like I said, I'm not sure if that's your problem but it's worth looking into. I don't know what causes the wiper to wipe one time while cranking with a weak battery but I suspect it's probably computer related. Maybe the lower voltage is confusing the body ECM and causing this. If you have a charger or a set of jumper cables you could connect it and get the voltage up a little and see if that affects it. Good luck.
  9. Apr 27, 2021 at 9:08 AM
    13tanner
    Tanner
    2007 4Runner silver
    I appreciate the input! I’ll try that out and see what happens
  10. Apr 27, 2021 at 3:03 PM
    13tanner
    Tanner
    2007 4Runner silver
    Update: ended up just buying a new battery, it was from 2017 and was a little weak on cca’s. Didn’t fix the problem
