Electrical issue
Discussion in '5th Gen 4Runners (2010-2024)' started by Evan.PR, Mar 24, 2025.
  1. Mar 24, 2025 at 8:14 AM
    Evan.PR
    Evan.PR [OP] New Member
    2010 4Runner sr5 2wd 6cilindro
    Hey chat,
    I’ve started having this problem with my 2010 SR5 4Runner that the lights in the car and radio turn off as soon as I turn on the headlights , they work perfectly fine when the headlights are off and the ac works consistently when they are off or on, also the car starts up perfectly, does anyone know what the problem might be?
    I haven’t taken to a mechanic yet because I’m not sure if it’s a matter of replacing a fuse or adjusting something, thank you!
  2. Mar 24, 2025 at 8:53 AM
    You probably checked this, but did you ensure the panel dimmer control is adjusted to full brightness?
  3. Mar 24, 2025 at 9:32 AM
    Evan.PR
    Yes it’s not that :/
    Slopemaster likes this.
  4. Mar 24, 2025 at 9:54 AM
    Daddykool
    Nothing was done to the headlights? No aftermarket electrics? Does it happen whether the engine is or isn't running? Have you tried disconnecting one headlight, then the other, then both?
  5. Mar 24, 2025 at 10:05 AM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Which “lights” are you referring to? When you turn on the headlights the dash and radio/clock displays will dim, as designed. Is that what you are seeing?
    Daddykool likes this.
