Eibach Lift: Upper Control Arms or No?
Discussion in '5th Gen 4Runners (2010-2024)' started by goicuon19, Sep 28, 2020.
  1. Sep 28, 2020 at 4:29 PM
    goicuon19
    goicuon19 [OP] New Member
    Phil
    Portland, OR
    2020 Magnetic Grey TRD Off Road Premium
    Eibach Lift Kit 2.75in front / 1in rear JBA Off Road UCA K&N Cold Air Intake TRD Exhaust Alpharex Luxx Series Alpha Black Morimoto XB Fog Lights LED Interior Swap Predator Tube Steps Black Sequential Side Mirror Turn Signal Black Rhino Sidewinder Wheels 275/70/17. BFG KO2
    Hello everyone.
    I'm not as active, but have been with this forum since late 2017. I recently just sold my 2017 Magnetic Gray SR5 for 33K when I had purchased my SR5 for 33.5K back in June of 2017. I turned around and got a 2020 Magnetic Gray TRD Off Road Premium. Right when I got the new 4Runner I knew I was going to be modding it. So far I have added:
    -K&N Cold Air Intake
    -TRD Exhaust
    -Blacked out the emblems
    -Predator Tube Steps
    -LED Interior Light upgrade
    -AVS Window Visors
    And of course as the title says the Eibach Lift Kit!
    My question is do I need to upgrade my upper control arms? When installing the lift kit I saw the OEM control arms and can see why one would want to upgrade them. But is it really needed? If I were to upgrade I would go with the JBA STD Upper Control Arms. I don't off road as often as I would like, but I would say I go maybe six times a year for a little back story. But the 4Runner is more of a daily driver for my wife and I. Let me know what you guys think! I just need a little help deciding if I should or not and need reasons. All opinions welcomed.
  2. Sep 28, 2020 at 4:55 PM
    Nice truck and good choice on the lift.
    No, you don't need UCA's. However, even though you don't offroad much aftermarket UCA's will improve on-road drivability and handling with the 2.75" lift you have in the front of your vehicle.
    It all comes down to the alignment, and more specifically the caster adjustment you can get using stock UCA's vs. aftermarket UCA's on a lifted truck. With stock UCA's at that height, you will still be able to get your caster at the low end of alignment spec, which is fine for some, but not for others. If you think your truck drives fine as is, then leave it.
    On the other hand, if you feel your truck wander on the highway a bit more or easily pull one way or the other without the steering wheel snapping back to center quickly, then aftermarket UCA's (and the higher caster number you can achieve with them) will help this.
    If I was lifted that high in the front, I would absolutely have aftermarket UCA's. Others will insist theirs rides fine without them :notsure:
    Overlandcharlie, Toy4X4, 7385 and 3 others like this.
  3. Sep 28, 2020 at 5:07 PM
    fajitas21
    fajitas21 New Member
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    I drove one with a 2.5" lift for 4 years with OEM UCAs. This vehicle I did the same 2.5" lift (same amount, different brand), and went UCA.
    In the end, I didn't notice much of a difference, but it would be helpful to not have issues with alignment, and it's nice to know they are beefier.
    Oldtoyotaguy likes this.
  4. Sep 28, 2020 at 5:31 PM
    goicuon19
    Phil
    Portland, OR
    Thank you! The OEM UCA just look some "frail". I guess I will just have to drive it more on the highway to notice the wandering of the car. I will be putting 275 KO2s on it at some point and will get an alignment done then. For now I got to put some miles on the stock tires.
    Toy4X4 and nimby[QUOTED] like this.
  5. Sep 28, 2020 at 6:10 PM
    Totally reasonable.
    Don't worry about the beefiness of the stock UCA. They don't break easy.
    Aftermarket UCA's are more for alignment, drivability, and getting a small amount of additional travel out of your suspension. You'd have to beat on your truck pretty damn hard to break a UCA (stock or aftermarket). More than likely, other parts will break first.
    GoSlow, Toy4X4 and 7385 like this.
  6. Sep 29, 2020 at 6:17 AM
    wmdtech
    wmdtech Send MOD Money!!
    Nate
    Mid TN
    18 TRD ORP
    I did the UCAs with the Eibach after I went in for an alignment and the specs were not to my liking. I would recommend doing it all at one time, I did the lift then about 10 days later had the front end back on jack stands doing the UCAs, would have been easier to do it all at one time.
    Toy4X4 likes this.
  7. Sep 30, 2020 at 3:23 PM
    Joekader
    Joekader New Member
    Joe
    I have the ARB bp51 setup on stock UCAs no issues with alignment Or ride it is very close though but I’m about to install a set of JBA high casters next week because it should give me peace of mind on upcoming excursions planned
    J
    Toy4X4 likes this.
  8. Sep 30, 2020 at 3:27 PM
    goicuon19
    Phil
    Portland, OR
    Those are the exact arms I am looking to order. It looks like it will take at least two weeks to get to me.
    Toy4X4 likes this.
  9. Sep 30, 2020 at 3:28 PM
    Joekader
    Joekader New Member
    Joe
    Should go great with your red covers
  10. Sep 30, 2020 at 3:41 PM
    goicuon19
    Phil
    Portland, OR
    How long did it take for you to get yours?
  11. Sep 30, 2020 at 4:26 PM
    Joekader
    Joekader New Member
    Joe
  12. Sep 30, 2020 at 4:44 PM
    goicuon19
    Phil
    Portland, OR
    Questions of curiosity: when did you order?
  13. Sep 30, 2020 at 4:46 PM
    Joekader
    Joekader New Member
    Joe
    Ordered September 14 got it the 22nd
  14. Sep 30, 2020 at 4:48 PM
    goicuon19
    Phil
    Portland, OR
    Make sure you post some install pics :)
  15. Sep 30, 2020 at 4:49 PM
    Joekader
    Joekader New Member
    Joe
    Wednesday is my scheduled appointment ASAP
  16. Oct 1, 2020 at 4:27 AM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    I'm at about 10k to 15k with my Eibach Pro Truck Lift and OEM UCA's with OEM sized tires.
    Per the Eibach reps on the other boards UCA's are not needed.
    My plan is to add SPC UCA's when I go up to my next tire size (33" or 34").
    My non-KDSS Off Road handled horribly stock. Tons of body roll and nosedive on braking. That's been cured with the Eibach suspension lift.
    Regarding this:
    "On the other hand, if you feel your truck wander on the highway a bit more or easily pull one way or the other without the steering wheel snapping back to center quickly, then aftermarket UCA's (and the higher caster number you can achieve with them) will help this."
    I'll let you know in the next year or so.
    Hind sight being 20/20, I should've just had UCA's installed when I had the lift installed. Needed or not.
  17. Oct 1, 2020 at 6:18 AM
    Miller1236
    Miller1236 New Member
    Chicago
    2020 TRD Premium OR
    Interior LED,LED Back up Lights, Oem Led fog lights,Screen Protector,Canvasback Cargo Liner, Front Film Protection,TRD skid plate, Eibach Pro lift kit, JBA Uca. OEM Door edge protection, Rola cargo roof rack
    I installed JBA UCA when I installed the Eibach Pro kit they have great customer support.
  18. Oct 1, 2020 at 3:11 PM
    goicuon19
    Phil
    Portland, OR
    I think hindsight I should have installed the JBA's also, but I just ordered them last night so I will have to get the truck back on the lift.
    DRobs[QUOTED] likes this.
  19. Oct 1, 2020 at 3:11 PM
    goicuon19
    Phil
    Portland, OR
    Got some pics of your install before and after?
  20. Oct 1, 2020 at 3:18 PM
    livinthedream
    livinthedream New Member
    I installed the Eibach Pro kit springs front and rear paired with the 5100s all around along with 285s. I got an alignment and was not very pleased with the results so I ordered UCAs to get installed, I would recommend just getting it all done at once.
  21. Oct 1, 2020 at 3:24 PM
    goicuon19
    Phil
    Portland, OR
    Ordered the JBA's will get shipping update soon. But I gotta take the wheels off again. The lift only took a friend and I 2.5 hours to complete so we assume the JBA arms shouldnt take too long
  22. Oct 1, 2020 at 3:45 PM
    livinthedream
    I ordered the JBA's as well, they are supposed to arrive next Monday. The reviews on them are too good to pass up and try anything else. I was considering the Camburg ball joint UCAs simply because I didn't want red but hoping the color grows on me.
  23. Oct 1, 2020 at 3:53 PM
    Oldtoyotaguy
    Oldtoyotaguy Paid cash for it
    2018 Toyota 4 Runner Offroad
    I have JBA's on my ORP, installed with an Elka 2.5 IFP set at factory default of 1 1/2". Were they essential? No. But alignment is no issue, and at full droop they won't hit those big coilovers.
    With JBA's there are three grease points - you can see two here in the photo. Some have complained the polyurethane bushings are susceptible to squeeking, but I've had no problems so far. I've greased them once. I had a thread on here asking about which grease is best - JBA recommends plain old lithium. Others suggested synthetic grease, and also, one review I read said silicone grease is best. I asked JBA but they didn't respond to my email, I guess I should have called them, but I just made up my own mind, lol.
    JBA's are a lot beefier than stock. Those stock UCA's are just pressed steel. When you take them off, they look a little feeble.
    icyhotahs, Toy4X4, 7385 and 2 others like this.
  24. Oct 1, 2020 at 5:25 PM
    goicuon19
    Phil
    Portland, OR
    I took a look at them while installing the lift and it was just sad looking how flat they were.
  25. Oct 1, 2020 at 5:26 PM
    goicuon19
    Phil
    Portland, OR
    What grease did you end up going with?
  26. Oct 1, 2020 at 5:37 PM
    gunsnob
    gunsnob New Member
    Vince
    2019 4Runner TRD ORP
    I went with JBA's as well with my Kings, no chopping and no headaches with rubbing. I'm running Toyo AT III's in LT285/70/17 and Method MR702's. Love this set up. I've lost about 2.3 mpg. I am researching gears @ 4.88 now to weigh the benefits if any.
  27. Oct 1, 2020 at 5:46 PM
    Oldtoyotaguy
    Yeah, I decided to use silicon. A bit expensive, but extremely sticky. Also compatible with polyurethane. It turns out stickiness is the issue. You want something that doesn’t easily wash out. That’s why, I assume, JBA specs lithium, which is just a soapy additive to help the grease stick. The only problem is that lithium grease is petroleum based, so I was unsure about using it. JBA recommends it, so it must be ok. After a year or so, I’ll report out on my thread, and we’ll renew the discussion. Maybe silicon grease is a mistake, if it is, I’ll find out and let you know. Seems good enough though, so far.
    Toy4X4, 7385 and gunsnob like this.
  28. Oct 1, 2020 at 8:58 PM
    Just to give you a quick rundown, this is what kind of grease bushing manufacturers send you with their polyurethane bushings:
    Prothane - Silicone based with PTFE
    Energy Suspension - Silicone based with PTFE
    SuperPro - Silicone based with PTFE
    Daystar - Silicone based with PTFE
    WhiteLine - Lithium based with Moly
    https://www.suspension.com/blog/the-best-grease-for-polyurethane-bushings/
    7385 likes this.
  29. Oct 2, 2020 at 12:33 AM
    Miller1236
    Chicago
    2020 TRD Premium OR
  30. Oct 2, 2020 at 6:21 AM
    Oldtoyotaguy
    Thanks, Nimby. I guess what I really wanted to know is how to prevent squeeking. If I end up with squeaky UCAs I know it will drive me crazy. Lol. I guess my plan is to be religious about greasing and hope for the best. One major manufacturer says to loosen the UCA bolt, so you don’t deform the bushings with grease! I hope I don’t have to do that! But when I greased them, I did jack up the vehicle and greased them in a droop, relaxed position.
