Educate me on Viper cut
Discussion in '5th Gen 4Runners (2010-2024)' started by Yotaholic, Dec 17, 2023.
  1. Dec 17, 2023 at 12:38 PM
    Yotaholic
    Yotaholic [OP] New Member
    Olympia, WA
  2. Dec 17, 2023 at 12:55 PM
    Here's some education for ya': https://trail4runner.com/2022/10/18/viper-cut-how-to-step-by-step-guide-5th-gen-4runner/
    The above link will answer and discuss the following:
    Here are the Pro's/Cons:
    Pros:
    • Added clearance for improved approach angle.
    • Added clearance for larger tires.
    • Customization
      • There are so many types of viper cuts out there, with different measurements, and different slopes.
    • For Instagram users, it’s going to improve your total number of likes and comments by at least 15%.
    • When it comes to adding a LoPro that has Stage 2 options, you are already more than halfway done with your chop.
      • My cut is not as high up because the Southern Style Offroad and C4 Fabrication Stage 2 cuts are so different. SSO’s cut is lower and C4’s cut is higher. I went with the former because I still have both options when it comes to adding a bumper and Stage 2s. You can read more about that here.
    Cons:
    • Your washer fluid reservoir will become exposed.
      • Not doing so will allow debris to break through your plastic reservoir.
    • There is no going back unless you order a new bumper.
      • You can see an example here, although it isn’t exactly what we’re talking about here.
    • If you are planning to have an SSO LoPro but you cut too high, you may be S.O.L. C4 will be your only option when it comes to Stage 2s as their cut is higher.
  3. Dec 17, 2023 at 1:09 PM
    Looks like @Borracho Loco has this covered, so I'll just add a picture from a spot where everyone takes pictures on the T.W.A.T.
  4. Dec 17, 2023 at 2:58 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    That's a lot of great info but I'm sad he'll never see it. His internet is obviously broken or he would have found it
    5six, Thacrow, bassist and 10 others like this.
  5. Dec 17, 2023 at 3:20 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    Meh, apologies to OP. I've been guilty of asking to be spoon fed info too but that article is literally the #1 result of a Google search. I'm just in a "be a dick to be funny" mood tonight
  6. Dec 17, 2023 at 4:01 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    :D
    roooo and Yotaholic[OP] like this.
  7. Dec 17, 2023 at 4:15 PM
    @Yotaholic hey buddy, I didn't YouTube my viper cut but I used YouTube to help grow the balls to take on the Dremel cut in my garage. I've been in construction my whole life and enjoy these things but I was still nervous.
    Search YouTube and 4R.com like I know you will, and see my posts below for ideas if you like
    Cheers from Canada
    https://www.4runners.com/threads/wh...h-gen-4runner-today.2261/page-698#post-375516
    https://www.4runners.com/threads/wh...h-gen-4runner-today.2261/page-699#post-375785
    https://www.4runners.com/threads/wh...h-gen-4runner-today.2261/page-740#post-401252
    https://www.4runners.com/threads/5th-gen-4runners-in-scenic-locations.7967/page-100#post-437351
    Yotaholic[OP] likes this.
  8. Dec 17, 2023 at 4:24 PM
    If my off road habits caused me to continuously scrape the front bumper in the areas that are removed from the viper cut then I would consider it, otherwise I think it fits into the vanity project category.
    gomiami, Kezin and Yotaholic[OP] like this.
  9. Dec 17, 2023 at 4:35 PM
    DadOperator
    DadOperator New Member
    22 Trail Special Edition
    Why does everyone have their lights on in daytime?
    Daddykool, icestud, djwantke and 2 others like this.
  10. Dec 17, 2023 at 4:43 PM
    Yotaholic
    Olympia, WA
    Bear with me guys, new to 4Runner world, and I don't like Google :p
    DR_4Runner, djwantke and Thatbassguy like this.
  11. Dec 17, 2023 at 4:47 PM
    It's standard procedure on a trail run. It gets dusty in some areas and anything you can do to be more visible is a good thing.
    Also, some would say that you should always drive with your lights on, regardless of time of day or weather conditions. Mine are pretty much always on.
    Toy4X4, roooo, Old Tanker and 5 others like this.
  12. Dec 17, 2023 at 4:52 PM
    I do it just to piss you off.
    How ya' like them apples! :)
    Toy4X4, Saker, roooo and 2 others like this.
  13. Dec 17, 2023 at 5:04 PM
    I can't speak for the OP, but I manage to scrape mine even after the cuts. :anonymous:
    Forgive the crappy nighttime picture, but I couldn't find a good picture of my bumper, and it gets dark at like 4pm this time of year. :confused:
    McSpazatron and Yotaholic[OP] like this.
  14. Dec 17, 2023 at 5:20 PM
    Kezin
    Kezin New Member I guess?
    ‘21 and ‘17 Limiteds
    If I didn’t have auto lights, I’d leave them on all the time too. Doesn’t hurt and I’ve had auto lights on every vehicle since 2000 so would be liable to forget them.
  15. Dec 17, 2023 at 7:18 PM
    I had to google vanity project haha
    Not offended, everyone knows the quote opinions are like assholes
    I've scraped the crap outta the bumper well above the clearance cut. I cut to mimic a steel bumper look, haven't invested that far yet
    Saker, Thatbassguy and Yotaholic[OP] like this.
  16. Dec 17, 2023 at 7:21 PM
    Yotaholic
    Olympia, WA
    After I fire up the engine, next thing I turn on the lights plus fog lights no matter what time of the day lol
  17. Dec 17, 2023 at 7:24 PM
    Yotaholic
    Olympia, WA
    ARB steel bumper is the way to go. But I am not ready for that yet
  18. Dec 17, 2023 at 7:24 PM
    I used to run the fogs all the time, but I stopped when I realized that they actually make it harder to see at night in regular conditions.
    Yotaholic[QUOTED][OP] likes this.
  19. Dec 17, 2023 at 7:25 PM
    Yotaholic
    Olympia, WA
    roooo likes this.
  20. Dec 17, 2023 at 7:26 PM
    I'm probably going with Coastal off-road if I get a full bumper. There are a bunch of good looking ones.
  21. Dec 17, 2023 at 7:26 PM
    Yotaholic
    Olympia, WA
    This guy carries the spare like I do lol
  22. Dec 17, 2023 at 7:29 PM
    Yotaholic
    Olympia, WA
    Wow, yeah
  23. Dec 19, 2023 at 1:37 PM
    MusashiSushi
    MusashiSushi New Member
    Colorado Springs, CO
    2023 4Runner SR5 Premium Black/Black
    Elka 2.5 DC 3" lift, SPC UCA's, Toytech rear springs, ARB Diff Breather, RSG Rock Sliders & front Skid. C4 front bumper with High Clearance sides and Warn Winch.
    A "Con" I would add is that there is less of your bumper attached to the vehicle. Sometimes when I drive up to Denver on i25 if I get up over 80 MPH and there is a cross wind my bumper will cavitate a little. Scared the crap out of me the first time I heard it! LOL I did take some slices of pipe insulation, basically pool noodle, and jammed it in a few strategic spots and that seems to have solved the problem though they do disappear on occasion so sometimes after a wash I have to cut a new piece of foam off for stuffing.
  24. Dec 19, 2023 at 2:14 PM
    HazOpRed
    HazOpRed 22' TRDOR
    Here is mine. I incorporated a curve similar to T4R Garage. I think it turned out pretty well. If I had to do it again, I think I would have curved it too make it flat at the top if that makes sense
  25. Dec 19, 2023 at 3:17 PM
    Do these cuts improve your approach angle or are you still limited by the center of the bumper?
  26. Dec 19, 2023 at 3:32 PM
    Not if you approach an obstacle straight on in the center of the bumper. But, if you approach at an angle, yes. Or, if there is a random boulder you can get one tire on it more easily.
  27. Dec 19, 2023 at 3:54 PM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    I pray that you're joking, even in broad daylight on the road you're way more visible with lights on. This is driving 101...
  28. Dec 21, 2023 at 1:48 PM
    DadOperator
  29. Dec 21, 2023 at 3:00 PM
    CalcityRenegade
    Matt
    2023 T4R ORP KDSS
    Repent sinner
    DadOperator[QUOTED] likes this.
  30. Dec 21, 2023 at 3:16 PM
