Dual batteries 5th gen
Discussion in 'Lighting' started by Kyblack76, Sep 27, 2018.
  1. Sep 27, 2018 at 3:03 PM
    Kyblack76
    Kyblack76 [OP] New Member
    Layton, Utah
    18 TRD O.R
    I didnt do a single search on the forum lol.
    But, does anyone on here, run a dual battery set up in their rig? I've seen a few options sniffing around.
    Two smaller cells, in the one stock location.
    Then (and my preference) with the stock and adding (reserve) one, pass side, back of the engine compartment. I like the thought of 2 large, vs 2 small, and ill never want, or have a air comp. No desire, need what so ever for me.
    There is a ton of room there, im sure where most stick a air maker. I want to just do my own. Im not paying anyone 900 bucks to make a bracket, cut some wire, and crimp some lugs/eyelets for me. Although, the one kit, i was reading on (Off Grid Engineering) has a set up, where the brain/isolation unit, leaves the 2 bats as one, until the starter battery sees 12.xx (or whatever) or below, it isolates the two, letting you run the reserve down, and still get off the mountain, or out of the desert and back home. I dig that.
    Is there anyone on here, that is running a dual set up ? Lets chat... love to hear from you. Im gonna make this happen. And soon.
  2. Sep 27, 2018 at 4:58 PM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    the dual corner battery are my next item. however I will insall a comp. but I'm putting it in the cargo area wher the factory jack is
    Toy4X4 and (deleted member) like this.
  3. Oct 1, 2018 at 8:55 PM
    WallyT4R
    WallyT4R New Member
    There are so many ways to do this. I am torn between putting one in the back by a fridge or using the Shrockworks kit to put one in the front passenger area. Either way I will be using a DC to DC charger instead of the other way because I will use solar and they come with a mppt solar controller built in. Leaning towards the Redarc brand of DC to DC chargers especially if I put it in the back. Still researching and saving cuz none of this stuff is cheap.
    Kyblack76[OP] and ruiz4251 like this.
  4. Oct 2, 2018 at 7:58 AM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    like the solar idea but it wouldn't work in my case...have too much to carry. wish I could do that. danm
  5. Oct 2, 2018 at 8:30 AM
    Kyblack76
    Layton, Utah
    18 TRD O.R
    I sniffed around for 3 seconds, and spoke to a car guy, that knows his shiz on 12v swag. He pointed me to the Blue Seas ML-acr relay. Looks like a fine unit. I may get jiggy with this while on shift this weekend. Run wires and such, then order some new bats.
  6. Oct 2, 2018 at 8:37 AM
    4X4Runner
    The left coast
  7. Oct 2, 2018 at 11:35 AM
    Kyblack76
    Layton, Utah
    18 TRD O.R
  8. Oct 2, 2018 at 7:50 PM
    WallyT4R
    WallyT4R New Member
    Yeah it won't be a permanent mount. It will most likely be some folding panel that will give the batteries some juice while parked for a few days. The DC to DC charger does everything the other relays do and still allow you to hook up solar since the solar controller is built in. I just feel it's a more versatile system than the relay only. Of course none of this stuff is cheap in price.
  9. Oct 9, 2018 at 8:18 PM
    muttscrub
    muttscrub New Member
    viejo
    newb here... midlife crisis has brought me to t4r and offroading
    the easiest way to do this would be to charge a second 12v battery using a charger plugged into the 120 volt outlet. No?
    In reading about amps and watts, it appears that chargers use too high amps, and the system would shut down. Does that seem right?
    also, if the 400 watts (maximum amps) is only an option when in idle, that means exhaust becomes an issue?
    or significant charging should only happen when driving??
    any thoughts?
    thanks
  10. Jan 22, 2019 at 9:12 AM
    blackoutt
    blackoutt New Member
    Southern IN
    2007 4Runner Limited V8
    Adventure Build
    Trent likes this.
  11. Mar 19, 2019 at 4:32 PM
    Doglover2003
    Doglover2003 New Member
    '18 ORP w/KDSS
  12. Mar 19, 2019 at 5:12 PM
    4X4Runner
    The left coast
  13. Mar 19, 2019 at 6:33 PM
    Doglover2003
    '18 ORP w/KDSS
  14. Mar 19, 2019 at 11:31 PM
    WallyT4R
    WallyT4R New Member
  15. Jan 7, 2021 at 4:20 PM
    totmacher
    totmacher New Member
    Daniel
    West TN
    2018 SR5 Nautical Blue
    done some stuff to it
    thread revival...
    Any nice battery tray upgrades for single stock location?
  16. Jan 27, 2021 at 12:56 PM
    newlife
    Knoxville TN
    2021 venture 22 JTR
    All of them.
    Rago’ isn’t bad or too expensive. Depends on what you’re wanting.
