Drove through deep water, now all the warning lights are on...
Discussion in '5th Gen 4Runners (2010-2024)' started by dep4b, Jul 11, 2022.
  1. Jul 11, 2022 at 5:47 AM
    dep4b
    dep4b [OP] New Member
    2019 Red 4Runner
    My father in law drove through a flooded beach road on the Outer Banks, NC, and while the 4Runner did great, afterwords the Slip indicator AND the check engine light came on....
    No problems in driving it, however how do I get it to reset, or, does it reflect something bad happend to the vehicle? It's a ~2012 4 Runner.
  2. Jul 11, 2022 at 5:54 AM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
    You’re gonna have to find out what the malfunction code is. You might have shorted out a sensor or actuator
    4runGirl88 and Thatbassguy like this.
  3. Jul 11, 2022 at 10:53 AM
    If you just want to reset the computer, disconnect the battery for a half an hour or so. The computer will reset to factory settings. If the lights pop back on again, then you know you have a problem.
    Or, you could take it to an auto parts store and many of them will read the codes for you and reset them.
    brownersd, Ironguy and 4runGirl88 like this.
  4. Jul 11, 2022 at 11:06 AM
    banjos-n-beer
    banjos-n-beer New Member
    Steve
    Maine
    2018 Pro
    how deep was the water? where do you live?
    i'd check the fluids in your Diffs and T-Case. If water got in there thru the breathers you'll want to replace the fluids... especially if you live in a climate where that water could freeze and do irreparable damage those units.
    4runGirl88, Dabigono and Thatbassguy like this.
  5. Jul 11, 2022 at 4:30 PM
    Dabigono
    2020 4Runner
    X2
    DUSTYDOGDAN and Thatbassguy like this.
  6. Jul 11, 2022 at 4:45 PM
    Just out of curiosity, how does one check the fluids for water without draining them?
    Bodie the Dog and Thatbassguy like this.
  7. Jul 11, 2022 at 4:49 PM
    ZebraScissors
    ZebraScissors New Member
    Drake
    Reno, NV
    2018 TRD Pro
    None yet!
    By draining them.
  8. Jul 11, 2022 at 4:50 PM
    you could suck some out through the fill hole. Bu I would just drain the fluid and replace if there was enough suspicion to bother checking. You’re already there anyway.
  9. Jul 11, 2022 at 7:06 PM
    Okay. So please clarify, because it seems that what’s being implied is that a fluid change is prudent whenever the vehicle fords anything deep enough to get the axles wet.
  10. Jul 11, 2022 at 7:09 PM
    ZebraScissors
    Drake
    Reno, NV
    2018 TRD Pro
    None yet!
    Anything over the breather can get the diff wet inside. The breather is directly attached to the top of the rear diff. They aren’t designed to be dunked under water unless you have an extended breather.
    Like on my Tacoma, my rear breather is extended and sits behind my driver tail light.
    https://www.northridge4x4.com/part/170112-arb-differential-breather-kit
    This is the location of the rear breather. Mine of course has a hose because it’s re-routed.
    onaquest and banjos-n-beer like this.
  11. Jul 11, 2022 at 7:14 PM
    That breather is maybe 2 to 3 inches higher than the center of the wheelhub. Which is pretty close to the bottom of the body. If you go that deep, you’d be safest draining your rear diff.
  12. Jul 11, 2022 at 7:21 PM
    I should add, the breather is supposed to shut, I think in situations where the diff experiences vacuum (like when a hot diff is cooled by water resulting in a vaccuum inside). So it’s not guaranteed that you would suck in water, and turn your diff oil into mayonnaise. But it’s more about safe than sorry, especially since I think that would be exceeding the maximum fording depth of the 4runner.
    banjos-n-beer likes this.
  13. Jul 11, 2022 at 7:36 PM
    Okay. This mostly lines up with my prior knowledge. My understanding is that the water doesn’t get into the diff through the diff breather. It gets sucked in through the axle seals when a hot axle is suddenly doused with cold water. The purpose of the diff breather is to prevent the vacuum that sucks water in past the axle seals. The diff breather closes when the breather itself is submerged, so that water doesn’t just pour into the diff. I think it takes a long and deep bit of wading to contaminate the gear oil.
  14. Jul 11, 2022 at 8:39 PM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    Oy, Cap'n: I have gotten wetter than many in various crossings, and when I changed my diff oil after multiple dozens of river fords there was no evidence of water contamination. I don't have any breather mods. Personally, I rate this concern of water intrusion to be not a worry... though obviously opinions vary.
    https://youtu.be/-fVw9N4T6aI
  15. Jul 11, 2022 at 8:47 PM
    My prior vehicles, a 1985 G-Wagen and a 1997 Defender, both had remote breathers from the factory. So this is the first time I’ve had to really think about it beyond the theoretical.
    Nice crossing by the way. I saw that video in another thread, along with a video about plumbing one’s own remote breathers. Interesting that the threads on the stock breathers are BST.
  16. Jul 12, 2022 at 3:48 AM
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    yeah, i doubt its common, but it did happen to a guy with his CX5, and the crossing was no more than 7" or 8" deep. obviously different vehicles, but the science behind it happening is still the same, and swapping out the fluid is cheap insurance.
  17. Jul 12, 2022 at 5:25 AM
    I agree that it worth checking, or just changing the differential fluid to be safe.
    I'll have to see how mine looks the next time I change it, as I also tend to practice proper driving technique at times. No breather mod... yet.
  18. Jul 12, 2022 at 4:12 PM
    Tmiesowicz
    Tmiesowicz New Member
    The better half of New York
    nice!
