DRL lights on 2023 4 runner limited
Discussion in '5th Gen 4Runners (2010-2024)' started by Redorigins123, Nov 28, 2023.
  1. Nov 28, 2023 at 3:22 PM
    Redorigins123
    Redorigins123 [OP] New Member
    Just installed DRL lights on my 4 runner 2023
    Rtorres73, ramnj and SlvrSlug like this.
  2. Nov 28, 2023 at 3:38 PM
    Welcome to the forum.
  3. Nov 28, 2023 at 4:24 PM
    Nice job, now you need to upgrade the turn signals (like I did):
  4. Nov 28, 2023 at 4:38 PM
    Do the 23’ models not come with DRL lights?
  5. Nov 28, 2023 at 4:40 PM
    They do come with DRL. I think the OP meant he upgraded his?
  6. Nov 28, 2023 at 4:42 PM
    Ok, thanks
    08TXRunner likes this.
  7. Nov 28, 2023 at 5:01 PM
    Redorigins123
  8. Nov 28, 2023 at 5:03 PM
  9. Nov 28, 2023 at 5:39 PM
    kjfswkr
    kjfswkr New Member
    New Hampshire
    2023 4 Runner
    With what?
  10. Nov 29, 2023 at 8:06 PM
    Sirpopealot
    Sirpopealot New Member
    Scott
    SR5 Premium XP
    Converted my DRL to LED this evening!
    2Toys likes this.
  11. Dec 2, 2023 at 3:49 PM
    kpmhspirit
    kpmhspirit New Member
    Pete
    North Illinois
    Would you care to share how you did that? I have the same rig except in white and would love to do that. I thought, though, that I saw a post from you a few days ago in another thread that you got hyper flashing. Did you put in the resistors? Any info would be appreciated.
    Thanks,
    Pete
    Edit: I just saw this post of yours:
    https://www.4runners.com/threads/wh...h-gen-4runner-today.2261/page-930#post-519833
    Looks great...Hopefully it worked out. I'd love to do that too.
  12. Dec 2, 2023 at 3:58 PM
    kpmhspirit
    Pete
    North Illinois
    Interesting. I assume your high beam/DRL is incandescent originally like in my rig? I tried a Diode Dynamics LED 9005 SL1 LED light I had left over from my Ram. It supposedly was the right bulb. The high beam worked ok but the DRL would not come on. I assume this was the wrong light. Could you share which lights you used, assuming your OEM setup is the same as mine.
    Thanks for any help
    Pete
  13. Dec 2, 2023 at 4:27 PM
    Sirpopealot
    Scott
    SR5 Premium XP
  14. Dec 2, 2023 at 4:30 PM
    so2315
    so2315 New Member
    Iowa
    2022 TRD ORP Nautical Blue
    I literally just did this in less than 10 minutes following this procedure too. Took me longer to make the harness than to install it!
    Sirpopealot[QUOTED] likes this.
  15. Dec 2, 2023 at 4:34 PM
    I have the resistors (and a new set of led’s) on order and will arrive on Monday. I will keep you posted.
  16. Dec 2, 2023 at 4:38 PM
    Sirpopealot
    Scott
    SR5 Premium XP
  17. Dec 2, 2023 at 4:42 PM
    Sirpopealot
    Scott
    SR5 Premium XP
    Same here, took me longer to find my solder gun than it did to do all the rest. :)
  18. Dec 2, 2023 at 4:45 PM
    so2315
    so2315 New Member
    Iowa
    If you need a wiring harness, I have an extra one complete for $20 shipped, just need the bulbs. Harness comes in 2 pack and you only need one for the passenger side.
  19. Dec 2, 2023 at 7:55 PM
    Fishhead74
    Fishhead74 At Least I'm Enjoying the Ride
    Montana
    2020 Venture Nautical Blue/2023 TRD MGM
    Evening,
    I would be happy to buy your extra harness if it is still available.
    Cheers
  20. Dec 2, 2023 at 11:50 PM
    Does this change the high beams too?
  21. Dec 3, 2023 at 8:50 AM
    kpmhspirit
    Pete
    North Illinois
    Thank you. Appreciate it.
    Pete
  22. Dec 3, 2023 at 10:33 AM
    kpmhspirit
    Pete
    North Illinois
    Thank you. I'll definitely look at getting those. I finally figured out that the halogen bulb is only the DRL. The owner's manual under Light bulbs references a 9005-HB3 bulb as the high beam/DRL but does say "if equipped". I finally tested it out and, yes, I have LED high and lows so all this bulb is for is the DRL. I was confused....not unusual...:rolleyes:
    However, I still have one of these left over from my Ram
    https://www.diodedynamics.com/high-...bs-for-2011-2023-ram-1500-2500-3500-pair.html
    It does fit and works but I removed it again. I didn't want to mess something up and between the transformer (or whatever that is in the connector) and the anti-flicker module, it will take some thought to secure all that. But, theoretically, is there any technical reason I couldn't use those? I still will check the brightness, though.
    Thanks again,
    Pete
  23. Dec 3, 2023 at 12:24 PM
    kpmhspirit
    Pete
    North Illinois
    Borracho-Loco. Quick question on those bulbs. I found these two at the DD site
    https://www.diodedynamics.com/switchback-turn-signal-leds-for-2014-2023-toyota-4runner-pair.html
    https://www.diodedynamics.com/7443-hp24-switchback-dual-color-turn-signal-led-bulbs.html
    You posted the latter link above. It looks like the bulbs in the first link do not need the resistors or did I read that wrong? And is it me or did they jack up the price since yesterday? I thought they were $56 for two and the resistors were $16. 25% increase. Damn.
    Pete
  24. Dec 3, 2023 at 12:34 PM
    Both of the links you posted are for the exact same bulb (LED, that is), one is for the pair, one is for a single. Those are the ones I have now, that are hyper-flashing.
    I ordered resistors (and yes, they did go up in price for both. I paid $16.00 for resistors & $56 for a pair of the 110P's) and I also ordered a different type of LED turn signals. I bought non-switchbacks. I want to test them to see if switching from white to amber is causing an issue? I doubt it is, but I want to test. I can return all this for a full refund if my theory fails.
    No biggie.
    This is the LED that I will test with: SKU: DD0114P
  25. Dec 3, 2023 at 2:12 PM
    kpmhspirit
    Pete
    North Illinois
    Ok thanks. Makes sense. The specifications are different, though, which is what threw me. Good idea about the non-switchbacks. I'd be interested in how it turns out. My guess is the resistors will be needed in both cases. I put LED rear turn signals in my Ram and had to put the resistors on each harness. They solved the problem and I never had an issue for 5 years. No bulb out messages once I did that. I never bothered with the front since you had to take the whole headlight out to get at the connectors/bulbs which was a major pain. I just wonder how you'll get the resistors in there if it's as difficult to get at as I've read.
    I just came across these
    https://www.headlightrevolution.com/brightest-7440-turn-signal-bulbs?quantity=1
    Not cheap. It's a good site, though, for ideas and some install videos.
    Pete
  26. Dec 3, 2023 at 2:19 PM
    broken-giver
    broken-giver BFD
    What are those turn lights? Thinking of diode dynamics switchback which I think is a drl and turn signal combo. Looks pretty good in videos.
  27. Dec 3, 2023 at 2:40 PM
    That is exactly what I have. DRL Switchbacks from Diode.
  28. Dec 3, 2023 at 5:16 PM
    so2315
    so2315 New Member
    Iowa
    Yes I still have it and just took an 8 hr drive with mine and they work flawlessly. The harness is complete, you just need to install it on the passenger side, ground it on the bolt on the fender, then replace bulbs. I bought my bulbs from Amazon. https://www.amazon.com/dp/B085B9NYG2?ref=ppx_yo2ov_dt_b_product_details
    Make sure to wear rubber gloves when handling the bulbs
    I do have Paypal, just got Venmo but not 100% sure how it works yet.
    Shoot me a PM to work out details. (I'm new here too, so bear with me while I navigate the PM too!)
  29. Jan 18, 2024 at 9:55 AM
    bronzestar1
    bronzestar1 New Member
    2023 Limited magnetic gray with redwood interior
    275/55-20s, Airaid CAI, Summit muffler, oil catch can
    So from reading thru this thread, there are no true plug and play bulbs to replace the DRL-only bulbs in a late model 4R (mine's a '23, low and high beam are off the same bulb in the projector housing)? Rockauto shows the DRL bulb for a '22 as being a 9005 (which I'm guessing is DRL-only, like my '23?). So why wouldn't a regular 9005 LED bulb work as a DRL in a 4R that has the low and high beam on the same bulb, not shared with the DRL?
  30. Jan 18, 2024 at 10:27 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    As others have documented on other threads, the DRL uses pulse width modulation to control the brightness of the halogen bulb, which means the supply voltage turns on and off rapidly. There are descriptions on those threads of filter circuits you can add to create a steady supply voltage more amenable to LED. You could plug in an LED bulb without that, but it may not behave exactly as you like, such as flickering.
