DRL’s not working
Discussion in '5th Gen 4Runners (2010-2024)' started by FourWalker, Aug 11, 2022.
  1. Aug 11, 2022 at 7:01 AM
    FourWalker
    FourWalker [OP] New Member
    2016 Grey 4Runner
    Remote start but more to come
    2016 forerunner with manual lights trying to figure out where the relay for the DRL’s is I’ve looked at the fuse box schematics and can’t figure out which one it is there anybody out there that knows
    I have the truck in gear daytime running lights selected emergency break off and got nothing
  2. Aug 11, 2022 at 8:14 AM
    Emmantik
    Emmantik New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
    ElectroBoy likes this.
  3. Aug 11, 2022 at 8:51 AM
    FourWalker
    2016 Grey 4Runner
    Yes it’s preowned in the previous owner put fog lights in the front end I can see the wiring thanks for the heads up I’ll check it out and report back
  4. Aug 11, 2022 at 12:08 PM
    FourWalker
    2016 Grey 4Runner
    Emmantik I Think you win the cigar I pulled the relay and one pin is bent up out-of-the-way I’ll get it straightened out when I get home tonight and report back thanks for pointing me in the right direction
  5. Aug 11, 2022 at 12:36 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    If the previous owner put LED bulbs in the high beam headlights you will probably get annoying pulsating light when in DRL mode.
    If so, re-install the OEM halogen 9005 high beams, or for better output try the modified 9011 bulbs.
  6. Aug 11, 2022 at 2:07 PM
    FourWalker
    2016 Grey 4Runner
    Thank you both gentlemen you were both correct and the problem is solved If you find yourself out my way I’ll buy a beer
  7. Aug 11, 2022 at 3:04 PM
    TeslasBigCarbonFootprint
    Southern California
    '23 TRD ORP Totaled - RIP 4RORP!
    I had a similar problem with my 2014. The relay pins were not straight. It would sometimes work, sometimes not...
    I have stopped using the DRLs on my 2020 and have put LEDs in my headlights and just leave the headlights on all the time. They shut off automatically when I pull the key and open the door. It is a fanless design off of Amazon and I am not totally confident that they will last. It is worth the shot though (2-year "warranty"). They are about the same brightness as my 2-year-old halogen H11-LL Sylvania lights, but the contrast is better.
