Driveshaft after lifting
Discussion in '5th Gen 4Runners (2010-2024)' started by CambodianThunder, Nov 17, 2024.
  1. Nov 17, 2024 at 8:18 AM
    CambodianThunder
    CambodianThunder [OP] New Member
    Space City, Texas
    22 Lunar Rock ORP
    Pretty Stock except for Sherpa Crestone Roof Rack with 44" Extreme LED X6S Slim Light Bar, RCI 5 degree Sliders with Top Plates, General Grabber ATX 265/70R/17.
    I have a 22 4runner that I just lifted 1.75 inches. While under it, I was noticed that the driveshaft was extended out due to the lift. Is this a concern and require some kind of spacer. I haven't found much on this and I know alot of people on here are bigger lifts, so not sure if it's something to be concerned about.
  2. Nov 17, 2024 at 8:55 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Normal. Just lube it every 5-10K and you'll be fine.
    CambodianThunder[OP] likes this.
  3. Nov 17, 2024 at 10:58 AM
    Acesandeights
    Acesandeights #34
    2024 ORP
    They are made to move in and out, to a degree. You haven't over-extended it.
  4. Nov 17, 2024 at 11:43 AM
    Not an issue, as long as you haven’t increased the travel range of the rear suspension. A typical lift doesn’t do that.
    It’s not that it’s actually extended, but rather it’s not compressed. Where the grease line ends is essentially the furthest you’ve compressed the rear suspension. It probably looked just like that before lifting.
  5. Nov 17, 2024 at 11:45 AM
    You’re lifting within the stock travel range so it normally slips in and out.
