Driver window not working
Discussion in '4th Gen 4Runners (2003-2009)' started by Shamano Prime, Oct 20, 2022.
  1. Oct 20, 2022 at 6:10 PM
    Shamano Prime
    Shamano Prime [OP] New Member
    Matthew
    2004 Toyota 4runner V6
    Hi everyone, new here, I've posted more on the Facebook pages but have not had any help on my current issue. My driver window does not work at all, this happened right after I had my battery disconnected. The master switch controls the other windows fine, just the driver window does not work.
    What I've already done:
    Checked fuses under steering wheel and in engine bay, none found to be blown.
    Took another window switched and plugged in, no change.
    Plugged in a new motor to the power plug (without installing it) and I still get no power.
    I took a voltage meter and tested the plug for the motor, looks like I am not getting any power. Should I replace the wires that run everything in the door that connect under the dash? I'm not sure how much work is involved, any other suggestions? Where can I find a wire diagram for the door?
  2. Oct 20, 2022 at 7:07 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    Sounds like a break between the switch and the motor - do those wires go under the dash?
  3. Oct 20, 2022 at 11:23 PM
    Shamano Prime
    Matthew
    I'm not sure where in the wiring the break would be. All the wires look like they combine and go through the door to under the dash, but I've not messed around with the wiring yet.
