Driver side A pillar grab handle.
Discussion in '5th Gen 4Runners (2010-2024)' started by Jimmycue, Sep 15, 2019.
  1. Sep 15, 2019 at 9:17 AM
    Jimmycue
    Jimmycue [OP] New Member
    Jimmy
    Has anyone installed the A pillar grab handle on driver side? I found this on a parts site and wonder if the trim panel needs to be replaced as well?
  2. Sep 15, 2019 at 9:36 AM
    Dark Knight
    Dark Knight Get off my lawn
    Notice that’s a 4th gen.
    This is the 5th gen mod.
    Saker, kolter45, Rockriv223 and 2 others like this.
  3. Sep 15, 2019 at 9:52 AM
    Jimmycue
    Jimmy
    Jeff you rock. thanks for the help on this.
    Spydr5 and Dark Knight[QUOTED] like this.
  4. Dec 19, 2020 at 7:58 AM
    Resurrecting this thread. Anyone else added this DS A-pillar grab handle lately?
    7385 likes this.
  5. Dec 19, 2020 at 8:51 AM
    Dark Knight
    ~^^^^~ This guy. It’s awesome.
    gunsnob and 7385 like this.
  6. Dec 19, 2020 at 9:44 AM
    Daytonaviolet
    Daytonaviolet TRD Bro
    Bay Area, CA
    Blizzard Pearl TRD Bro
    I did. Besides the oem parts, you’ll need the custom bracket. It’s a great simple mod :)
  7. Dec 19, 2020 at 10:56 AM
    Thanks. I had contacted the bracket maker before, just hadn't ordered it yet. I've also read the install threads, and it seems totally doable. What's the best method of removing the A-pillar trim cover without messing it up?
    @Daytonaviolet, I read through your build thread, hoping for some pics. I didn't see that shown, but may have just missed 'em.
    Daytonaviolet[QUOTED] likes this.
  8. Dec 19, 2020 at 12:00 PM
    Dark Knight
    The directions that come with the bracket are pretty good. Very little chance of damaging the a pillar trim. I would suggest getting a longer screw for the lower mounting position. That’s the only hiccup I had.
  9. Dec 19, 2020 at 12:06 PM
    Daytonaviolet
    Bay Area, CA
    once you pop off the srs plastic cap, there’s one screw in there. After that the A pillar trim just pulls right off.
    The kit included a temple which you use to make the lower hole.
    the custom bracket will be used for the newly cut trim hole. You’ll also need to drill two holes to secure the custom bracket.
  10. Dec 19, 2020 at 12:15 PM
    nm_t4r
    nm_t4r New Member
    2018 Barcelona Red 4runner LE
    Here is mine installed: upload_2020-12-19_13-14-45.jpg
    Firesq14, 2Toys, DrewMan and 6 others like this.
  11. Dec 19, 2020 at 2:47 PM
    Did you have to do this to the back of the trim piece, or did yours fit without doing this:
    toy33 and Daytonaviolet[QUOTED] like this.
  12. Dec 19, 2020 at 2:51 PM
    A longer screw that the handle mounts with?
    Daytonaviolet likes this.
  13. Dec 19, 2020 at 3:34 PM
    Daytonaviolet
    Bay Area, CA
    Yes forgot about that. You’ll need to flatten that area as the brackets clip will sit on that. The black material above that hole is what was removed.
    toy33 likes this.
  14. Dec 19, 2020 at 3:35 PM
    Daytonaviolet
    Bay Area, CA
    I used the supplied screws with no issues.
    A&P likes this.
  15. Dec 19, 2020 at 3:52 PM
    nm_t4r
    nm_t4r New Member
    ^^^^ Ditto
  16. Dec 20, 2020 at 7:53 AM
    Sorry for all the questions - 'supplied screws' being the ones supplied with the Toyota grab handle, or the bracket?
    I'm putting the parts list together to get everything ordered. If anyone has that already listed, as far as the part #s from Toyota for the grey grab handle, and can send me that, it would be great. Meantime, I'll see what I can come up with...am I correct in thinking the handle is the same for both sides, just flipped end for end, or are they side specific?
    Thanks for all the help.
    Edit: never mind on the grab handle parts list. It's in post #1 of the link above.
  17. Dec 20, 2020 at 10:43 AM
    Looks great, thanks for the photo. I am looking forward to installing this, it's much missed since I sold my Tacoma. Any tips or tricks you would suggest?
    2Toys and toy33 like this.
  18. Dec 20, 2020 at 10:46 AM
    BimmerChop
    BimmerChop Rich
    CT
    '17 Super White TRD Pro
    I'm going to have to do this soon!
    A&P likes this.
  19. Dec 20, 2020 at 11:53 AM
    If you go to the 4R.org thread linked above, it gives the email address for Jason, who manufactures the brackets. That is how you order them, or PM him from that 4R site if you are a member.
    I just emailed Jason today to see if he had any in stock, what the current price is, and said I want to place an order. Emailing him would be best for pricing.
  20. Dec 20, 2020 at 1:48 PM
    nm_t4r
    nm_t4r New Member
    For the grey:
    Grip Handle Part #: 74680-60010-B0
    Grip Handle Hole Cover Part #: 74615-60040-B0
    Grip Handle Hole Cover Part #: 74616-60040-B0
    Take your time, measure three times and drill once. I used a sharp utility knife to cut the black plastic.
    toy33 likes this.
  21. Dec 20, 2020 at 3:50 PM
    Bracket, handle and covers ordered.
    toy33 likes this.
  22. Dec 20, 2020 at 4:40 PM
    I ordered the bracket from Jason. I believe it includes the bracket, the mounting hardware for the bracket, and a template for where to make the holes, for the bracket and the hole in the A-pillar trim, I believe. What I don't know is if mounting bolts are included for the grip handle...I think so.
    A question for those who've already installed this - does the bracket use an existing threaded/or non-threaded hole in the sheet metal behind the cover for one side of the bracket, and you have to drill a hole for the other side of the bracket? Or do you have to drill holes for both sides of the bracket?
  23. Dec 20, 2020 at 4:53 PM
    I sent you a PM.
    A&P[QUOTED] likes this.
  24. Dec 20, 2020 at 5:08 PM
    Jason just confirmed in an email that all the hardware needed comes with the kit. All that needs to be ordered elsewhere is the handle with the two caps.
  25. Dec 21, 2020 at 10:01 PM
    Good to hear. I have everything on the way also. If you didn't live across the country, this would be a nice project to collaborate on. Good luck with the installation.
  26. Dec 22, 2020 at 7:41 AM
    Did i miss something on this grab handle mod? Does no one feel the handle above the door is adequate? I use mine every time i get in, and it seems fine to me.
    Desert Dawg and Toy4X4 like this.
  27. Dec 22, 2020 at 8:34 AM
    I don't know about you, but for me that handle above the door is useless for some things. I've tried to do what you're saying, and it always seems to just be in the wrong place, or the wrong angle for exit and entry. I do use it if I need to access the roof or up high, but I hate it for entering/leaving the vehicle. That's just my take.
  28. Dec 22, 2020 at 8:38 AM
    I did miss the a-pillar on my 2002 when we first got the 2017, but i guess i just got used to it. Thanks my friend.
    A&P, Toy4X4 and toy33 like this.
  29. Dec 22, 2020 at 5:23 PM
    nm_t4r
    nm_t4r New Member
    This is what I paid online plus shipping:
    Part Number Part Name Price Quantity Total
    74680-60010-B0 Grip Handle $23.99 1 $23.99
    74615-60040-B0 Grip Handle Hole Cover$1.58 1 $1.58
    74616-60040-B0 Grip Handle Hole Cover$1.58 1 $1.58
    Subtotal: $27.15
    Estimated Shipping to 87508 via Standard Shipping: $10.37
    Total: $37.52
    toy33 likes this.
  30. Dec 22, 2020 at 8:50 PM
