Drive shaft greased?
Discussion in '5th Gen 4Runners (2010-2024)' started by Daddy83, Nov 6, 2022.
  1. Nov 6, 2022 at 8:46 AM
    Daddy83
    Daddy83 [OP] New Member
    Blue 4runner SR5
    Is the drive shaft coming greased from factory? The common sense tells me yes, but still have doubts.
  2. Nov 6, 2022 at 8:55 AM
    aroyalsfan
    aroyalsfan The Owner
    Kansas City
    Oh yeah daddy that shaft comes pregreased...but you can always slowly lube it up some more.
    suaveflooder and MeefZah like this.
  3. Nov 6, 2022 at 8:57 AM
    Daddy83
    Blue 4runner SR5
    Thanks
  4. Nov 6, 2022 at 9:09 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    It's part of routine maintenance; I normally hit my zerks every other oil filter change which translates to about once a year.
    skistoy and Slopemaster like this.
  5. Nov 6, 2022 at 9:12 AM
    Daddy83
    Blue 4runner SR5
    It's up to you but I wouldn't change the oil once a year or 10k miles, that's too much, bit as I said up to u
  6. Nov 6, 2022 at 9:33 AM
  7. Nov 6, 2022 at 2:03 PM
    MeefZah
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    I change the filter every other oil change and change at 5000 or less depending on use.
  8. Nov 6, 2022 at 6:44 PM
    suaveflooder
    suaveflooder New Member
    you will find a ton of threads on oil change intervals. I go with 10k because I am 99% highway (literally). All depends on driving. Get a blackstone analysis if you have questions.
    To your original question, yes it does :)
