Dobinsons and bilstein 5100s
Discussion in 'Suspension' started by Ar16545, Aug 3, 2020.
  1. Aug 3, 2020 at 5:35 PM
    Ar16545
    Ar16545 [OP] New Member
    2020 4runner sr5p
    Anyone have pictures of their ride with this setup: bilstein 5100s front and back. Front at 0 and Dobinsons c59-300 and back c59-599?
  2. Aug 15, 2020 at 2:35 AM
    kC_yota
    kC_yota New Member
    2019 Toyota sr 5
    Bilstien 5100 Dobinson springs Toyo open country at3 Trd matte grey 17X7 Padel commander Lasfit H11 K&N filter
    Hope this helps
    ready6delta and Ar16545[OP] like this.
  3. Aug 20, 2020 at 10:47 PM
    j485
    j485 New Member
    2020 OR Premium
    How does it ride vs stock?
  4. Aug 20, 2020 at 10:54 PM
    kC_yota
    kC_yota New Member
    2019 Toyota sr 5
    Runs amazing it’s better then stock , and most important it doesn’t rub with the 285, also no more nose dive
  5. Aug 25, 2020 at 9:13 AM
    beachT4R
    beachT4R New Member
    2016 Silver SR5
    So you have that exact setup and 285's?? Has you gas mileage hit been bad?
  6. Aug 25, 2020 at 9:20 AM
    PCRIDE4RUNNER
    PCRIDE4RUNNER New Member
    SUPER DUPER
    Are the Dobinsons 300 and 599 the stock oem replacement where they are just stiffer than OEM, but not higher? Can you explain the differences? I was going to get these myself but considering the slightly higher ones as I do have the Bilstens but on the 4/5 setting, cornfed spacers in the rear with stock OEM coils. I'd like a bit stiffer coil but not have to lift everything again, then worry about getting the drop kit for the transfer case etc and control arms.
    ** Ah differences being front and rear. Are these larger than the OEM and what the Bilsteins 5100 come in? I have the 6112 and rear with the reservoir.
    **Answered my own question. Per the Dobinson Rep
    "Hello. Our C59-599 rear coils are the lowest height lift coils we make. They will lift 1" to 1.25", depending on loads and weight added to the rear"
