Dobinsons 4th Gen 4Runner Suspension options
Discussion in 'Exit Offroad' started by Crikeymike, Apr 23, 2020.
  1. Apr 23, 2020 at 2:08 PM
    Crikeymike
    Crikeymike [OP] Exit Offroad, Dobinsons Specialist Vendor
    Jax Beach, FL
    2014 4Runner w/Dobinsons MRA Suspension, Shrockworks bumper/sliders
    Hey guys, my name is Mike Tomczyk (aka Crikeymike) and I'm the former GM of Dobinsons USA, but now running my own company, Exit Offroad. I've been in the industry since 1998 and have always preferred to focus on suspension for 4x4's, since it's something you'll feel every single time you move your vehicle, whether driving to work or home, or offroad for the weekend. Everyone has their own build plans for their vehicle, so no same combo of parts is necessarily right for everyone, which is why we offer such a variety - to get you exactly what you're looking for!!
    I'm putting together a post here for the definitive information thread about all of the components we make and offer for the 4th Gen guys.
    Yes, the coils are teal/green/blue color (update - other colors now available). It's something Dobinsons have been doing for years in Australia as their trademark color, which makes it easy to spot on the trail. They're extremely well powder coated, so if you don't like the color, you could paint over them before installation.
    Also, our shock paint is baked on enamel and is extremely tough compared to some competitors. It resists chips, flaking and rusting very well.
    Added Load Weight.
    How much extra accessory weight have you added to your truck? Did you add a 150LB front bumper and an 80LB winch? That's constant weight, and will change which coil to buy.
    Did you add our drawer system (hopefully) to the back end (150LBS) or a steel bumper with swing out tire carrier (200LBS)? That will also change which coil we would suggest.
    You will want to consider that weight before ordering. If you order a heavy load coil without a heavy load, be warned that it won't ride as it's supposed to and the lift height will be incorrect.
    Click on each part number to be directed for further information
    Front Coil Options
    V6 Engines
    C59-134 - Stock height replacement coil. 370/370mm, 17mm wire, 586LB (made for a 3rd Gen 4runner, but works well on a 4th Gen for stock height replacement)
    C59-296 - Stock front end, low height 1-1.25" 378/378mm, 17mm wire, 586LB
    C59-300 - V6 - Stock front end load, 2" lift. 385/385mm, 17mm wire, 586LB
    C59-302 - V6 - Stock front end load, 2.5" lift. 395/395mm, 17mm wire, 586LB
    C59-302 - V6 - 100-220LBS heavy load front weight, 2" lift. 395/395mm, 17mm wire, 586LB
    C59-314 - V6 - 100-220LBS heavy load front weight, 2.5" lift. 405/405mm, 17mm wire, 586LB
    V8 Engines
    C59-302 - V8 - Stock front end load, 2" lift. 395/395mm, 17mm wire, 586LB
    C59-314 - V8 - Stock front end load, 2.5" lift. 405/405mm, 17mm wire, 586LB
    C59-314 - V8 - 100-220LBS heavy load front weight, 2" lift. 405/405mm, 17mm wire, 586LB
    C59-352 - V8 - 200-240LBS heavy load front weight, 2.0-2.25" lift. 385/385mm, 18mm wire, 730LB
    ***2.5" or more of lift, new UCA's are recommended with 3 degrees of caster correction***
    Rear Coil Options
    C59-323 - Stock height replacement. 375/375mm, 16mm wire, 216LB
    C59-599 - Stock rear end, .75" to 1.0" lift (keeps rear end low, allowing to level the vehicle rake with 2" front lift). 390/390mm, 17mm wire, 220LB
    C59-505 - Stock rear end load, 1.5" lift. 405/405mm, 17mm wire, 220LB
    C59-325 - Stock rear end load, 1.75" to 2" lift. 420/420mm, 17mm wire, 220LB
    C59-327 - 200-400LB heavy rear load weight, 2" lift. 410/410mm, 18mm wire, 271LB
    C59-329 - 600-800LB super ridiculous heavy rear load weight, 2" lift. 410/410mm, 18mm wire, 286LB
    C59-675V - Variable rate comfort option, stock rear weight, 2.5" lift. 470/470mm, 16mm wire, 157-230LB variable
    C59-677V - Variable rate comfort option, 400+LB heavy rear load weight, 2.5-3" lift. 500/500mm, 16mm wire, 157-230LB variable
    C59-701V - Variable rate, 600-700 LB heavy rear load weight, 3" lift, long travel. 500/500mm, 17mm wire, 210-245LB variable. Designed for those with heavy full rear bumper, tire carrier, roof rack, RTT, drawers, and fridge. Rides very well with all that weight, as well as when loaded even further.
    C59-749V - Variable Rate, 750-900 LB super heavy constant rear load, 3" lift, long travel. 520/520mm free height, 18mm wire, 198-300LB variable rate, usually around 270LB at loaded height
    Front Strut Options
    GS59-221 - Twin Tube, fixed mount (not adjustable), suits 0-2.5" lift (21.3" extended length), can be used on stock height or lifted vehicle, use with OE or aftermarket coils, coil seat mount same as OE. Diff drop kit not needed
    GS59-220 - Twin Tube, fixed mount, suits up to 3" of lift, higher coil seat height gives extra 1" lift at the wheels over listed coil spring heights above. (22.28" extended length), longer travel than normal, recommended to run with diff drop kit. Use this with 2" coil to get 3" of lift.
    IMS59-50220 - IMS Front Monotube Struts - suit 0-3.5" lift
    Dobinsons 3-way adjustable MRA struts and shocks have their own thread, located here: Here are the options too:
    MRA59-A221 - For 0-2.5" Front lift
    MRA59-A220 - For 2-3.5" Front lift - longer travel
    MRA59-A701 - For 0-3" Rear
    MRA59-A575 - For 3-3.5" Rear - long travel
    Rear Shock Options
    GS59-637 - Twin Tube, suits 0-2.5" lift. 581mm extended, 349mm compressed.
    GS59-705 - Twin Tube, suits 0-2.5" lift, softer valving for empty rear ends. 590mm extended, 355mm compressed
    GS59-701 - Twin Tube, longer travel, suits 2-3" lift. 605mm extended, 362mm compressed.
    GS59-575 - Twin Tube, Long Travel, suits 3" lift (3" bump stop spacers recommended so shocks don't bottom out). 730mm extended, 425mm compressed. That's 28.7"/16.7".
    IMS59-50705 - IMS Rear Shocks comfort valved - suits 0-3" lift - due March 2020
    IMS59-50701 - IMS Rear Shocks medium/heavy valved - suits 0-3" lift - due March 2020 (uses these for a vehicle with constant rear weight)
    IMS59-50575 - IMS Rear Long Travel Shocks - suits 3"+ lift (not for KDSS models) due May/June 2020[/B]
    Front Top Mount Strut Spacer - new February 2019
    PS59-4030 - Single 1/4" machine alloy strut spacer, anodized black, suits almost all Toyota's from the 90's to current. Drilled with 2 bolt patterns to fit multiple vehicles. 4Runner 3rd, 4th, and 5th Gen. All Tacoma's 1998 to 2019. All GX470/460. All FJ Cruisers. Can be used to correct a vehicle lean if one exists, or to add one to both sides to add 1/2" lift.
    Diff Drop Kit
    DD59-527K - required with 3" lift, could also be used for 2" to 2.5" lifts if desired to correct CV angle
    Adjustable Panhard Rod
    PR59-1423 - Rear adjustable panhard rod, realigns rear axle back to center when lifted 3"+
    Adjustable Rear Heavy Duty Control Arms
    WA59-520K - Rear Lower Adjustable Control Arms
    WA59-522K - Rear Upper Adjustable Control Arms
    Front UCA's
    UCA59-002K - Front UCA Set with Senkei 555 Ball joints - Pair of replacement upper control arms to fix alignment issues with 2.5"+ lift heights. Use OE type rubber bushes on the frame end, and replaceable high angle ball joint on the wheel side (they come not pressed in). 38mm OD tube, 5mm wall thickness (0.2") HSLA steel. Fixed caster of 3 degrees built in. Maintenance free, simply cannot make noise once installed properly
    UCA59-202K - Billet UCA Set with Senkei 555 Ball Joints - Adjustable camber and caster on the vehicle (super easy to adjust), maintenance free, OE style rubber bushings for less NVH. VIDEO LINK
    Front Strut Top Caps/Hats
    SC59-001 - New upper caps - don't waste time pulling apart your old strut assembly just to get the cap off, buy new. Or better yet, we can pre-assemble the units before shipping so you can install at home faster.
    Rear Coil Spacers
    We make 15mm thick spacers, which install on top of the factory rubber isolator and below the coil seat on the frame. These are a good idea on older vehicles that tend to lean, add it to the low side
    Single 15mm Poly Coil Spacer - to correct vehicle lean - PS59-4025
    All options are listed in the suspension builder page here: https://exitoffroad.com/product/dobinsons-1-to-3-5-lift-kit-toyota-4runner-4x4-2003-2009/
    We're new to the USA market (June 2016), so a lot of people haven't heard of us before. And we don't have a lot of real world comparisons yet to all the options out there. We're always asking those who do buy our suspension to write a true honest review with photos and everything after they get it installed and drive it for a while.
    It's all very comparable. The coils are made in Queensland Australia, just like OME coils. Dobinsons shocks are twin tube nitrogen charged gas shocks, built almost the same as OME shocks. We have a few differences though, mainly that we use all rubber bushings for maximum vibration dampening and resistance to noise. Some shocks have built-in (welded) stone shields for forward-facing shocks. Here is the link to all the details of our shocks:
    Twin Tube Nitrogas
    And here's the one for our coil building process:
    Coil Springs
    EDIT: Update on 12/15/17.
    Bring on the kicking and screaming from those who have already bought..... :wacko: :yield:
    Due to popular demand and an amazing amount of requests, we have brought our most common 4Runner (and Toyota) coils to the US in 2 additional colors. Red and black. Now these part numbers are available (depending on stock) in classic Dobinsons Teal, TRD Red, and/or Black, depending on part number.
    C59-300 (Teal, red or black)
    C59-302 (Teal, red or black)
    C59-314 (Teal, red or black)
    C59-599 (Teal, red or black)
    C59-505 (Teal, red or black)
    C59-325 (Teal, red or black)
    C59-327 (Teal, red or black)
    C59-675V (Teal, red or black)
    C59-677V (Teal, red or black)
    C59-701V (Teal, red or black)
    Of course, we would prefer to sell the teal for branding reasons, but so many of you this year have asked us for a color choice, so here you go!!
    NOTE: the optional colors are not listed in the catalog, and are not sold on Amazon or Ebay.
    https://www.youtube.com/embed/Npfx40VD3kM
    https://www.youtube.com/embed/ZjF37uC4n-M
    https://www.youtube.com/embed/na5NvdfxOrM
    https://www.youtube.com/embed/RgyemIrnzsQ
    https://www.youtube.com/embed/lZACSaE2PHI
    https://www.youtube.com/embed/qtkesMe4ddE
    4thgenV808 likes this.
  2. Apr 23, 2020 at 2:11 PM
    Crikeymike
    Jax Beach, FL
    Additional product photos
  3. Jun 15, 2022 at 12:15 AM
    boomking
    boomking New Member
    Hello Mike! I am interested in purchasing a set of dobinsons for my 4th gen 4Runner. Which full kit do you folks currently have in stock? I reached on to you on IG with no reply. Thanks!
  4. Jun 15, 2022 at 5:44 AM
    Crikeymike
    Jax Beach, FL
    There are 100 ways to build a kit on my website. Pretty much every option is in stock in one color or another, and anything sold out says that it's on backorder.
    My site breaks it down the best.
  5. Oct 20, 2022 at 8:39 AM
    lemurlovin
    lemurlovin New Member
    liam
    07 Black 4Runner
    What are the exact specs for that suspension setup with those pics posted of the 4th Gens Mike? Really liking how they sit.
  6. May 16, 2024 at 1:59 PM
    gkomo
    gkomo New Member
    San Diego, CA
    2004 4Runner Limited V8
    Excited to get my 4th Gen 4runner setup with the IMS system I ordered. I'll post photos before/after.
    For those curious, i ordered the:
    - Dobinsons IMS Lift Kit for Toyota 4runner 4x4 2003-2009
    - Teal Color Coils
    - C59-296 Front Coils (for v8, 1" lift)
    - C59-599 Rear Coils (1/2-3/4" lift)
    - Assembly included
    Crikeymike[OP] likes this.
  7. Aug 4, 2024 at 4:47 PM
    4RunnerLifter
    4RunnerLifter New Member
    Can you share how you are liking this so far? I am considering doing the same to my 2006 v6 4WD. Also what struts did you choose, 0-2.5inch?
    gkomo[QUOTED] likes this.
  8. Aug 5, 2024 at 8:59 AM
    gkomo
    gkomo New Member
    San Diego, CA
    Have had my Dobinsons IMS installed for a while now. Quick and dirty review, these are fantastic! 110% would recommend.
    They are plush, but firm. In another post somewhere i used the term 'muted' - Its like the suspension is there in the background doing its job but you almost don't notice it. Whereas the worn out stock stuff i had on before was like front and center in the driving experience, and not in a good way. I think they shine the most on long, undulating bumps more so than like pothole type bumps, but they do a much better job than stock on those types of bumps as well. At high speeds, they soak everything up. At low speeds, you'll still get bumped around a bit, but everything still feels more 'solid' if that makes sense. I don't get much if any body roll, no nose dive on braking.
    As far as lift, so from my previous post i was looking for a 1" lift up front and 3/4" lift in the rear with the coils i purchased. I ended up getting 2.5" up front and like 2" in the rear. I attribute this to my 20 year old, sagging springs. Even though its more than i was anticipating, i think it looks fantastic. Its 'lifted' without looking lifted.
    I purchased the 0-2.5" struts as i knew i wanted a 'small' lift. I also paid the extra to have them preassembled. Although I'm wondering if that was smart because the shop quoted me a figure without knowing if they were assembled and i ended up paying that much anyways. Maybe the shop could have assembled them and still charged me the same, who knows.
    Before:
    After:
  9. Jul 5, 2025 at 4:23 PM
    SinglePringle
    SinglePringle New Member
    04 4x4 v6
    Hey Mike couple questions for ya.
    I’ve got an old v6 4th gen that I want to do a small lift on.
    first question is in regards to the rear shocks. Wondering the main difference between the GS59-745 (comfort valves) and the GS59-701. Truck gets used for a good amount of camping but nothing too serious in the off-roading department. Was leaning towards the 745 as it gets used for a lot of high way driving road trips as well and off-roading isn’t the main concern.
    Other question is just about lift height since I’m pretty new to all of this. Was planning on doing
    Front: C59-300 - Stock front end, 1.75-2.0" lift
    Back: C59-505 - 1.25-1.5" with stock weight
    Do you think this would mostly level it out leaving maybe a tiny bit of rake? No added weight to the vehicle at all.
  10. Jul 6, 2025 at 11:54 AM
    Crikeymike
    Jax Beach, FL
    The 745 rear shocks are for use on an empty/stock weight rear end. The 701's should be used if any weight is added to the back, or if the vehicle is regularly loaded up, otherwise the softer shocks would feel too soft and not supportive enough.
    That combo of coils will only reduce about 1/2" of rake. It's the difference between the front and rear lift heights. Factory rake has the rear end 2" taller than the front, so usually most people lift the rear end 1" less than the front to cut the rake in half and have it sit more level than stock but not too far, so that when you load up with gear, you don't get negative rake. C59-300 with C59-599 would be more ideal.
