Dobinson IMS lift
Discussion in 'Suspension' started by homesteader, Jan 6, 2023.
  1. Jan 6, 2023 at 10:17 PM
    homesteader
    homesteader [OP] New Member
    2022 4Runner TRD OR lunar rock w/KDSS
    Hi Everyone,
    Well it’s been about a year and very low miles since I installed my Dobinson IMS lift. Before I go any further, just so you all know this ride is for my wife. It will probably see no off roading LOl. I like it, the rides is firmer than stock no nose dive during breaking. It rides well with the KDSS. I don’t know how one rides with out it. First time 4 runner owner.
    One thing that I’m not happy with is the stance. Which I believe is fixable.
    Right now I have a 1”-1 1/4” rake. I like it to be more level. My goal was to have no more than 1/2” rake.
    According to Mike at Exit off-roads base line is 20” front 22” rear stock 5th gen. My stock measurements were 19 11/16” front 22 1/2” rear.
    If I were at Dobinson base line I would have been level.
    Here are few pics.
    Before
    After
    It’s a little hard to see the difference while on the grass.
    I’ll post more pictures with it on concrete and more pictures on the suspension.
  2. Jan 6, 2023 at 10:52 PM
    homesteader
    You can see the rake now it’s parked on concrete.9FBF8903-DB94-48B6-8420-12DF42859D96.jpg
  3. Jan 7, 2023 at 3:43 AM
    Accelerator
    Accelerator New Member
    Chris
    Satellite Beach, Fla
    2022 SR5 Super White 4Runner #3
    I think it looks great. If you ever load up the back end such as for a road trip, that little bit of rake should level nicely and prevent negative rake aka Carolina squat.
  4. Jan 7, 2023 at 6:56 AM
    auspilot
    auspilot DustRunner
    2020 TRD OR
    Dobs IMS, lots of small stuff
    You don't say what springs you're running. I installed C59-599 rear springs which according to Dobs should give a rear height of 23" (+1"). I ended up with 23.5" on drivers side and 24" on pass side. This was more rake than I wanted so I switched the springs for Eibach E30-82-071-01-02. The Eibachs reduced the rear to about 23"/23.5". Not a huge difference but just what I wanted. Also I think the lower spring rate on the Eibachs gives a better ride with my stock weight rear, although I had no problem with the original Dobs ride.
  5. Jan 7, 2023 at 8:46 AM
    homesteader
    My setup
    Front coils-C59-302
    Front struts-S59-50574
    Rear coils-C59-505
    Rear shocks-IMS-50705
    Dobinson UCA
    KDSS spacer kit.
    Diff drop kit.
    The 505’s is what Mike spec out for my setup. My kit is 3.5” lift. That’s exactly what it gained up front when I lifted it. I still need to measure to see how much it settled.
    My thinking was to swap out with the 599’s which should bring it down .5”. I was hoping I could go up more in front and leave the 505’s but I may be maxed out up front. I would need to check with Mike.
  6. Jan 7, 2023 at 8:51 AM
    homesteader
    Yeah it does look good, but at times it just looks to much. 99% of the time it just the wife and my self. Yeah I don’t like the negative rake and that’s why I was hoping to have about 1/2 rake.
    Accelerator[QUOTED] likes this.
  7. Jan 7, 2023 at 8:55 AM
    homesteader
    Here is stock compared to Dobinson.7C15F423-95AE-4B70-BBA0-BA2739EB7713.jpg6AB328BE-EF08-477E-90F7-D914C8E496E1.jpg 0165AFBD-4166-41AE-9A3D-BFE1CFA76A10.jpg
  8. Jan 7, 2023 at 4:47 PM
    hossler1788
    hossler1788 DADWAGON
    Joshua
    Central Pa
    2020 4runner
    What size tires?
  9. Jan 7, 2023 at 6:11 PM
    homesteader
    275/55/20. Originally I was going with LT285/55/20 but wasn’t sure about clearance. I believe it will work now.
  10. Jan 7, 2023 at 6:18 PM
    hossler1788
    Joshua
    Central Pa
    2020 4runner
    Looks good!
  11. Jan 8, 2023 at 5:20 PM
    homesteader
    MT hunter and Crikeymike like this.
  12. Jan 31, 2023 at 4:55 PM
    Klinsman55
    Klinsman55 New Member
    K
    Northern Nevada
    2024 LE silver
    XREAS. Cooper Discoverer Road and Trail AT 255/75r17. Trd Pro Wheels
    how do you find the ride quality over pot holes and speed bumps or dirt road?
    I got my 4Runner this month and looking to add a suspension to make ride more soft over these things. Have been looking at Dobinsons IMS. Dobinsons supposed to be progressive and maybe more soft.
    Accelerator likes this.
  13. Feb 3, 2023 at 7:43 AM
    homesteader
    I can’t tell you much because I don’t have a lot of miles on it yet. But the ride is much improved. It feels a lot firmer in a good way.
  14. Feb 6, 2023 at 12:03 PM
    This is a very subjective question, especially considering I couldn't imagine anything softer than stock suspension on an Off-Road. The stock suspension is very soft! I thought it was like riding on clouds lol. (But maybe you have KDSS? That could give it a firmer feeling than my non-kdss)
    I also installed IMS shocks front and rear when I did my lift. I used dobinson springs as well. I find them to be firmer, but very comfortable and very well composed on the road.
    To be clear, It most definitely is NOT as soft as stock! However, the quality of compression rebound damping results in a sublime ride on rough roads. IMO, comfort is not simply in how soft they are, I think it mostly results from how well the shocks control compression and rebound.
  15. Feb 9, 2023 at 9:38 PM
    IOTOI
    IOTOI New Member
    2016 Toyota 4Runner Limited
    Any lean to the sides? some people complain about lean towards the driver side.
  16. Feb 10, 2023 at 12:55 AM
    Haven’t noticed anything visually. But I believe there was some when I measured a while back. It changes with load anyway, so Im not gonna chase a half inch here or there.
  17. Feb 10, 2023 at 8:01 AM
    homesteader
    No. Not really. It depends on the ground that you are measuring on.I’ve measured dead on on both side and at times it’s about 1/8” or so difference.
  18. Feb 28, 2023 at 8:26 PM
    Sandman317
    Sandman317 New Member
    2022 AG ORP
    Seems high, I could be wrong, but I was thinking the 302s were around 2.5" lift and the 505s were for 1.5" in the back with no added weight. Looks good, but I agree it does look high.
    I actually have an IMS set up w/ 302 & 505s sitting in my garage awaiting installation.
    How you liking the ride now its been on for a couple weeks?
  19. Feb 28, 2023 at 10:20 PM
    homesteader
    My runners base line wasn’t the same as Dobinson’s base line. If it were it would be right where I would liked it to be. My rear stock height was about 1/2” higher and the fronts were about 1/4” lower than Dobinson’s base line. I’m still thinking of swapping out with a shorter springs. I would love to go up in the front but I’m not sure if it’s possible with the KDSS.
    The ride is firmer than stock in a good way and feels more stable. It’s been a year since I installed it.
  20. Mar 1, 2023 at 3:09 AM
    Accelerator
    Chris
    This is very interesting. What were your pre-lift heights front and rear?
    Mine is very similar. Pre-lift I had about 3 inches worth of rake. After I put my IMS in I still have 1 inch of rake after lifting the front end 3” and the rear 1.5 inches. I believe the front end was lower than most baseline numbers from the factory. Pre-lift I was at 19” in front and 22” in the rear. All measurements were from the center of the hub to the bottom of the fender.
    Sandman317 likes this.
  21. Mar 1, 2023 at 10:58 AM
    homesteader
    My pre lift heights 19 11/16 fronts and 22 7/16 rears center hub to bottom of fender.
    I need to get some new readings. I don’t believe the rears has settled any. My fronts maybe. It should be all settled since its been a year.
  22. Mar 1, 2023 at 6:21 PM
    Accelerator
    Chris
    Thanks for the info. I’m curious to know if you have any settling. I really wasn’t looking to go up 3” in the front but if my final height is the same as everyone else’s who went up 2” then I’m thinking I’m where I should be.
  23. Mar 1, 2023 at 7:34 PM
    homesteader
    My front was 3.5” and rear 1.5”.
    I believe maybe the front has settled,
    I need to double check.
  24. Nov 23, 2023 at 5:52 PM
    2chains
    2chains New Member
    ^^Have you made any changes to your setup? Can you post your current fender to centre hub measurements? I'm scheduled to get Elka's with the Dobinsons c59-505 rear coil springs which are posted by Exit as 1.5" to 1.75" lift in back. I have the third row seats but not carrying any additional weight.
  25. Nov 23, 2023 at 7:58 PM
    homesteader
    I can in a few days. I’m away from my 4Runner. But my rears are a little higher than I want it to be. I would like to level it out more. Hope to lift the front up a bit more.
  26. Nov 24, 2023 at 6:17 AM
    agreed. I love the stance of it!
  27. Jan 20, 2025 at 2:32 PM
    Escher121
    Escher121 New Member
    TOYTEC 3" Lift
    I've heard only good things about Dobs and will liking be using them on my 2022 OR w/ KDSS. I'm hoping to get 2" front and 1" rear. It looks like Dobinson sells two different struts. IMS59-50700 that gives between 0-2" as well as IMS59-50574 that give 2.5"+ lift. Ideally I'd like to be able to adjust between 2" and 2.5"/3". Is there any Dobs setup that can achieve this?
  28. Jan 20, 2025 at 2:37 PM
    Escher121
    TOYTEC 3" Lift
    Will setting the IMS59-50700 to the max 2" cause a stiffer ride compared to using the IMS59-50574 at the lowest 2.5" setting?
  29. Jan 20, 2025 at 4:38 PM
    Klinsman55
    K
    Northern Nevada
    2024 LE silver
    do you have any experience how they do on washboards? Or if anyone here has experience how they ride on washboards?
    my recent drive on a 3 mile stretch of washboards with XREAS was pretty rough even aired dow. I could only drive 4-7mph
  30. Jan 20, 2025 at 7:09 PM
    I can drive comfortably faster than that, aired down to mid 20s psi. Of course, some washboard is worse than others, so it’s hard to give you a useful number.
    Klinsman55[QUOTED] likes this.
