Do I really need a new A/C compressor and radiator? IDK?
Discussion in '3rd Gen 4Runners (1996-2002)' started by Artsy1, Jul 18, 2022.
  1. Jul 18, 2022 at 4:38 PM
    Artsy1
    Artsy1 [OP] New Member
    J
    1997 4runner Limited, 6 cylinder, 2 wheel drive
    I have a 97 4runner Limited w 103k miles. AC stopped blowing cool air. Now, blows neutral air. Mechanic new to me started up the SUV, looked under the hood and immediately said I need a new compressor, he could smell it and it wasn't engaging. My radiator is also crazing. He said order the parts (I bought Denso). He'd install the compressor for $250 labor and radiator for $180 labor. I caught a previous mechanic trying to rip me off, so, I no longer trust them. Maybe because I'm female, they think I'm a good target. Ugh. Your thoughts? Do you think the labor charges are fair (I'll have both parts installed at the same time)? Couldn't the AC just have a leak, or??? TIA, Jan
  2. Jul 18, 2022 at 4:55 PM
    Tama1968
    Tama1968 New Member
    Florida
    T4R SR5 in Classic Silver
    no way to know for sure. *if* it's the original AC (on 4Runner, that's possible) then I would not be surprised at all if it's finally shot. Labor doesn't sound bad at all. last time I had an AC system replaced on my POS Chevy it was just over $1,000 parts and labor, and this was 8-9 years ago
  3. Jul 18, 2022 at 6:42 PM
    Nevin
    Nevin New Member
    Puyallup, WA.
    2022 TRD ORP
    PPF, Tint, Black out badges/Valances. Bilstein 6112's & 5100's
    Your mechanic may be correct if it's not engaging. Most likely the compressor clutch is going out. It'd be smart to just replace whole compressor. Labor price doesn't sound bad.
  4. Jul 18, 2022 at 8:14 PM
    Ahdofu
    Ahdofu New Member
    Matt
    I am actually surprised to see that the car has only 103K on it and now needs a new AC compressor and a radiator. Does the compressor receive a signal and the clutch does not engage or can it be that no signal makes it to the compressor? The labor rate itself looks reasonable for both.
  5. Jul 18, 2022 at 8:29 PM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    a few goodies
    Before I would spend a dime on the parts, I would make sure the clutch on the compressor has power. Might just be a blown fuse. If there is power to the compressor clutch, then a low refrigerant quantity / pressure would prevent the compressor clutch engaging. If the refrigerant is low, a can of that could be purchased for not very much money and serviced in the air conditioner system. If nothing else, the new refrigerant could help find the leak in the system (assuming there is a leak).
    Toy4X4 likes this.
  6. Jul 19, 2022 at 7:34 AM
    SnowBunny56
    SnowBunny56 New Member
    North Texas
    1999 3rd Gen
    Toyo tires with Fuel wheels, Carhart seat covers, getting started with some suspension mods
    My 99 3rd gen has a slow leak in the a/c, maybe a couple of oz a year, not going to tear into it over that, will blow 40 degrees on a good day
  7. Jul 19, 2022 at 1:31 PM
    Justthemechanic
    Justthemechanic New Member
    Nevada desert
    94 4Runner SR5, 5 speed, 3.0
    OME 2” lift, BudBuilt armor, RRO sliders, Spartan rear locker
    Yes your A/C could have a leak, if the system is not fully charged the compressor will not engage. If your new mechanic did not hook up a set of A/C gages to check the pressures and told you your compressor was bad I would recommend you find a different mechanic.
    GrantA and runnerjimmy like this.
  8. Jul 19, 2022 at 5:50 PM
    runnerjimmy
    runnerjimmy Wannabe
    Scottsdale Az. Castle Rock Co.
    2021 ORP Barcelona red
    Fox 2.5 DSC. 2 1/2” front, 2”rear. Falken Wildpeak 255/80/17
    Agreed, and just what is he smelling if the clutch is not engaging. Mechanics don’t warranty there work when you bring them the parts. They need to source the parts in order. Something smells here and I don’t think it is the compressor. Check the charge, and see if is leaking. May need to just do a recharge on the system. Is he crazy or is the radiator crazing. I don’t understand. No leaks no overheating?? Maybe a flush wouldn’t hurt.
  9. Jul 19, 2022 at 6:10 PM
    Dillusion New Member
    KYle
    Hes full of shit.
    A/C probably has a leak causing the clutch to not kick on. If he didn't refill with dye no way can he tell its the compressor. Good mechanic will show you the leak spot when he finds it.
    Toy4X4 and runnerjimmy like this.
  10. Jul 20, 2022 at 7:17 AM
    So, when a clutch goes, it can lock up and the belt and the clutch can stink. Ask me how I know.
    103k miles is not a lot of miles...BUT it's a 20+ year old AC clutch. Miles don't always indicate failure potential.
    Rates do seem reasonable...but like was said, a mechanic should diagnose it better. Checking the clutch is not hard.
  11. Jul 26, 2022 at 7:03 PM
    a yden
    a yden New Member
    Ayden
    Illinois
    1999 4Runner Limited
    get a cheap A/C recharge kit and try charging it. if the compressor is good, it should kick on. if not, you either have a massive leak somewhere or the compressor kicked the bucket. i got lucky with mine and that the mechanic gave me a false diagnosis about a bad compressor. charged it with a cheap kit from AutoZone and boom, compressor kicked on and the A/C works. if it's a bad compressor, you may need to get the entire system replaced if it came apart.
  12. Aug 2, 2022 at 7:49 AM
    SnowBunny56
    North Texas
    1999 3rd Gen
    There is a pressure cycling switch in the high side line on the passenger inner fender, if faulty they can prevent compressor engagement
    2Toys likes this.
  13. Aug 2, 2022 at 10:18 AM
    KYle
    Considering the questions asked I would not do this. I've seen shit ton of people overfill because they were filling their AC with the compressor off and it did not need freon.
  14. Aug 2, 2022 at 1:49 PM
    SnowBunny56
    North Texas
    1999 3rd Gen
    Behind the grill on the pass side find the accumulator, there is a sight glass on top, with the a/c on you will be able to see refrigerant flowing unless it's completely full or empty, if bubbly or milky it's low, mine is that way at the beginning of the summer in the 3 years I've had it
  15. Aug 2, 2022 at 4:16 PM
    Yeah, that's low for a recent car, but this thing's 25 years old. Those could be 103,000 really hard miles on that thing, who knows?
    IMO on a 25-year-old vehicle, actual mileage on the odometer is one of the least important things.
  16. Aug 2, 2022 at 6:16 PM
    Expansion valve?
  17. Aug 2, 2022 at 6:35 PM
    SnowBunny56
    North Texas
    1999 3rd Gen
    Just looked at mine, appears to be a fixed orifice system, no other valves of any type
  18. Aug 2, 2022 at 6:49 PM
    Inside the evaporator? And clean the evaporator while your at it remove glove box 4 bolts.
  19. Aug 15, 2022 at 5:39 AM
    a yden
    a yden New Member
    Ayden
    Illinois
    This is why you generally want to watch a couple YT videos on how to do it beforehand and it also helps a lot to get an A/C charge kit which has a pressure gauge built in. If you manage to overfill that then you're doing something very wrong. There's a reason why charge kits are usually readily available, something super easy most vehicle owners can do themselves without a trained professional.
  20. Aug 15, 2022 at 10:51 AM
    KYle
    A lot of people can't even tell when the compressor is on to get an accurate reading when using the DYI kit.
    If you have a leak the kit is only a bandaid. I would fix it right if you plan on keeping the vehicle.
  21. Aug 15, 2022 at 10:53 AM
    My AC is too cold I don’t like it. Jan, this is what you will be saying let the mechanic do his thing.
  22. Aug 15, 2022 at 12:20 PM
    a yden
    a yden New Member
    Ayden
    Illinois
    This is a good point, but all you need to do to see if the compressor is on is just see if it's spinning. Pretty simple to do.
  23. Aug 15, 2022 at 3:15 PM
    KYle
    Ask the OP to point out the compressor. I bet she won't be able to. Nothing against it just saying.
  24. Aug 27, 2022 at 3:32 PM
    DaveB
    DaveB New Member
    Dave
    Central Hellinois
    97 limited
    Vehicle Modifications:
    0
    I just did the entire ac kit. It was a chore but all new components and inside behind glove box fit well. I have 240k on mine. Since it was old it wasn't worth charging and having a new issue come up. I think it was about 225 total. Condenser, compressor, dryer, and accumulator. Replaced switch already. Good for another 200k
    2Toys likes this.
