Do I need BMC For 285/70/17 tires?
Discussion in '5th Gen Builds (2010-2024)' started by alexh2, Feb 3, 2021.
  1. Feb 3, 2021 at 12:00 AM
    alexh2
    alexh2 [OP] New Member
    2020 4Runner Venture (White)
    going to get a 2.5 inch lift. Bilstein 5100's on my TRD PRO wheels.
    My local auto shop says that I MUST do a BMC.. is there any way around that? What can I advise them to do instead in order to keep the 285 size tires?
  2. Feb 3, 2021 at 12:29 AM
    Mtbpsych
    Mtbpsych New Member
    Probably not, have them set the caster as far forward as they can. The closer to 4 the better is the consensus when going with bigger tires. If you’re getting aftermarket upper control arms, this is much easier to do. Then you may just have to do some minor trimming in the front bumper, but that is much easier/better than doing a BMC.
  3. Feb 3, 2021 at 8:22 AM
    I'm not sure about the BMC. Do you have springs that gives you 2.5 in lift? I didn't need BMC even for my Limited with 2.5 front and 1.5 rear lift with stock UCA. All I did was I did some trimming on the front fender liner and push it forward. I'm not if wheels and tires matter, I got TRD OR wheels with Falken Wildpeak AT3W P285/70R17.
    If Limited does not need BMC needless to say my TRD ORP did not need BMC.
    Thatbassguy and gps470 like this.
  4. Feb 3, 2021 at 9:29 AM
    stunner_4runner
    stunner_4runner New Member
    Raymond
    2020 4Runner SR5 4WD
    Radflo Stage 3 Lift Kit- 2.5 Extended Front & Rear RR Adjustable Coilovers Total Chaos Upper Arms ARB rear medium springs 3” Aiden James Switchback Fog Bezel Lights 4Runner Lifestyle Amber Raptor Grill Lights Trail Standard Offroad Satin/Matte Black TSO Pro Grille with 4Runner Letters Baja Designs WC Amber Fog Lights Baja Designs XL Sport Amber Ditch Lights with Cali Raised Ditch Light Brackets 2 Baja Designs LP6 Amber Behind the grille lights 2 SNS Designs 5" Amber Behind the grille lights N-FAB behind the grill lighting mount Pedal commander Jet Performance Mass Flo Air Sensor 315/70/17 Cooper STT Pro Fuel Rims Custom Magnaflow exhaust with Series 50 Flowmaster Muffler Alpharex Nova Midnight Black Headlights AFE Momentum GT Dry Filter CAI BantamX Touchscreen for Universal with sPOD Alpharex PRO-Series LED Tail Lights Jet Black Mid-Atlantic Off-Roading Full Length Roof Rack Outgear Solutions Low Key Front Bumper 4WDKING 30’ LED Light Bar for the Bumper RSG Front Skid Plate
    Hey Alex,
    You will not need a BMC. Bought my 2020 4Runner from the lot with 285 75 17 Nitto Ridge Grabblers and Front-Rear Bilstein 5100s. Also, had stock UCAs. Since then, I upgraded my suspension and UCAs. I would recommend, if you decide to run 35s like I plan in the near future, then BMC for sure.
  5. Feb 3, 2021 at 9:47 AM
    alexh2
    Any adjustments to your caster? Or stayed at a neutral position?
  6. Feb 3, 2021 at 9:48 AM
    alexh2
    Any adjustments to your caster? Or just stayed at neutral position?
  7. Feb 3, 2021 at 10:12 AM
    The one with stock UCA -
    The one with SPC UCA -
    mve likes this.
  8. Feb 3, 2021 at 10:12 AM
    jack bauer1
    jack bauer1 New Member
    OP-all rigs are a little different.
    I can tell you that I ran 2.5 inch lift on my Pro with stock wheels on 285/70/17 Nitto RGs with SPC's and never needed a chop.
    This may have been due to the ability to push the wheels a touch forward due to the SPC arms.
    I wheeled my rig too, no problems.
  9. Feb 3, 2021 at 10:35 AM
    gps470
    gps470 New Member
    GP
    2021 While 4Runner Nightshade
    I have 2021 Nightshade, and planning to replace the wheels/tires with 17" TRD Pro ones. Looking for tires which can go well with the new wheels without any lifts/BMC or rubbing. Any recommendations ?
  10. Feb 3, 2021 at 10:49 AM
    Not really sure what options without lift. May be 265/70R17s. If it rubs push the fender liner forward.
    My Limited has a lift, 2.5 front and 1.5 rear Bilstien 5100, stock UCA. I like that stance and 285 tires fill nicely. (They are Falken Wildpeak AT3W (non LT) P285/70R17.
    144025180_10158039202361645_181569195412_7e49e8f1733b9cb93c90a3acdfce334cffc04204.jpg
    gps470[QUOTED] likes this.
  11. Feb 3, 2021 at 11:03 AM
    You don't NEED to. I'd say drive it first and see where you actually rub.
    I only rubbed on the front bumper.
  12. Feb 15, 2021 at 7:22 PM
    Amerxon555666
    Amerxon555666 New Member
    Paul
    Red 2021 4runner TRD off-road
    i think it depends on what tires you're running, there are guys in here that are running 285's stock UCA with just 2.5 inch lift and no rubbing.
    but then if tires are beefy like Nittos or Cooper stt, then maybe they'll rub.
    SlvrSlug and Thatbassguy like this.
  13. Feb 16, 2021 at 4:36 PM
    With 285's, the biggest factors that cause rubbing on your body mount are your wheel offset, wheel width, and alignment. As your offset gets lower and lower into the negatives, you will start to rub the body mount. Wider wheels have more of a chance of rubbing. Larger lifts with no UCA's will have more of a chance at rubbing on your body mount.
    If you run Pro wheels with 285's, I don't think you'll rub on the body mount. If you happen to, get UCA's, push your caster to +4 and you will clear it. You will have to do the fender liner mod if they don't already come on the Ventures.
    SlvrSlug likes this.
  14. Mar 3, 2022 at 7:55 PM
    BigStainky
    BigStainky New Member
    Austin
    2022 trd orp
    What is a bmc?
  15. Mar 3, 2022 at 8:14 PM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
    BMC = Body Mount Chop
  16. Mar 3, 2022 at 8:27 PM
    T4Rrunning
    T4Rrunning New Member
    You guys think a 2021 trd pro with 1.5” lift and stock wheels with 285 Toyo open country’s would need a Bmc?
  17. Mar 3, 2022 at 8:56 PM
    Mtbpsych
    Mtbpsych New Member
    Probably not unless you’re running trails. Just get a good alignment.
  18. Mar 3, 2022 at 8:59 PM
    T4Rrunning
    I’m running the stock black trd pro wheels. Looking to put the Eibach pro springs which are 1.5” in the front and 1” rear
  19. Mar 3, 2022 at 9:09 PM
    Mtbpsych
    Mtbpsych New Member
    I meant going off-road, not running trail/off-road model wheels.
  20. Mar 9, 2022 at 7:38 PM
    BigStainky
    Austin
    2022 trd orp
    So what are they cutting, that seems kind of sketch?
