Do I need a panhard bar correction kit / Bolt On TrackBar Correction kit for a 2in lift?
Discussion in '5th Gen 4Runners (2010-2024)' started by Son_of_Yeti, Jan 30, 2025.
  1. Jan 30, 2025 at 6:43 AM
    Son_of_Yeti
    Son_of_Yeti [OP] New Member
    Andrew
    2011 Black 4Runner
    I recently bought a 2 inch suspension lift for my 2011 5th gen. I recently discovered that lifting throws off suspension geometry. Is a kit to correct that necessary for a 2 inch lift? If so, what should I get? The lift I bought is a Stage 2 non KDSS Ironman foam cell pro if that's relevant.
  2. Jan 30, 2025 at 7:04 AM
    from my research when i did mine.............2" max, not really needed but you can correct the little angle it produces. Below that don't spend the money, there's no benefit. Above 2" definitely needed to keep the shift to a minimum.
    The common option is the DRKDSS kit. but there's others out there if you are a good welder.
  3. Jan 30, 2025 at 7:26 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Not necessary. You might want to consider upper control arms.
    Steely123 likes this.
  4. Jan 30, 2025 at 8:41 AM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    slightly modified LE
    So how do you know that you may need panhard correction? Use your eyes and butt.
    By eyes I mean look at the bar, is it fairly horizontal, as it should be?
    By butt, does the rear end “hop” over speed bumps?
    These could be indicators of a need.
    Cheers
  5. Jan 30, 2025 at 10:25 AM
    Maximumdarkside
    J.
    Tennessee
    2014 4Runner Limited
    None yet.
    You don’t list list where you are located, but if near TN I actually ended up with one in my sale pile from another trade deal, Ironman adjustable panhard bar - part #panhard015hl21, new never installed, packaging tore so threw it away, if you decide you need one, site shows $300, figure $100 to get it to a good home and out of my way. Or shipped at buyer cost but the thing is a heavy chunk.
    Spare Parts likes this.
  6. Jan 30, 2025 at 1:52 PM
    ZOOMA-LOOM
    ZOOMA-LOOM New Member
    Right out of sight of Scottsdale
    2024 0RP
    PM sent
  7. Jan 30, 2025 at 1:56 PM
    Maximumdarkside
    J.
    Tennessee
    None yet.
    Yes sir, just replied.
  8. Jan 30, 2025 at 11:42 PM
    I think you do. Just snap a picture and post it.
  9. Jan 31, 2025 at 8:14 PM
    Maximumdarkside
    J.
    Tennessee
    None yet.
    Still available.
