djwantke 2016 White Trail build and travels
Discussion in '5th Gen Builds (2010-2024)' started by djwantke, Mar 27, 2023.
  1. Mar 27, 2023 at 5:39 PM
    djwantke [OP] New Member
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    After May 2021:
    -K&N Engine Air Filter
    *NOW FRAM EXTRA GUARD CA10835
    -Pedal Commander
    -valance cap trim
    Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets.
    Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x
    In progress:
    4th, 5th, and 6th set of off road lights
    Electrical components and wiring purchased, not started
    -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar
    And
    -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners
    And
    -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side
    And
    -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side
    -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather
    Bought, in the garage queue:
    -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover
    -Blue Sea Systems 100A Circuit Breaker w/ reset lever
    -Rust prevention
    •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax
    •partially used POR15 Degreaser, Metal Prep
    Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Photon_Chaser, Thacrow and Bob like this.
  2. May 1, 2023 at 5:41 PM
    Wife booked summer camping;
    *April 29* RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit
    *Bought 51" beer cooler hitch carrier! Arrives tmro
    Dabigono, 2Toys and captrussia253 like this.
  3. May 4, 2023 at 9:01 PM
    very nice
  4. Jun 17, 2023 at 1:50 PM
    Invested in crowfoot wrench sets!
    Thacrow likes this.
  5. Jun 17, 2023 at 1:53 PM
    Picked up / cleaned up more spare tires to store in basement
    Dabigono likes this.
  6. Jun 17, 2023 at 1:53 PM
    Always a good feeling when you can add the crowfeet to the tool box!
    TacoGeeloor and djwantke[OP] like this.
  7. Jun 17, 2023 at 2:14 PM
    Added magnetic grease gun holder to the Runner garage. So simple yet so smart
    2Toys likes this.
  8. Jun 18, 2023 at 9:50 PM
    Blaster Surface Shield KDSS finished for 2023.
    front and rear stabilizer control, accumulator housing assembly, hose fittings, hardware, tube and valve protectors, frame
    2Toys likes this.
  9. Jun 20, 2023 at 10:35 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    What does the chain wax go on?
  10. Jun 20, 2023 at 11:19 PM
  11. Jun 20, 2023 at 11:22 PM
    I haven't saved enough money for a dirt bike and trailer haha or even a chainsaw
    Thacrow likes this.
  12. Jun 20, 2023 at 11:23 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    The chain wax goes underneath for salt protection?
    Forgive me I don't live where they salt the roads and I ride motorcycles and saw the chain wax in the shot.
  13. Jun 20, 2023 at 11:35 PM
    Yeah, Chainwax has really good capillary action and sets up waxy. Great for a corrosion barrier on hard to reach area or for crevices.
    Haffnez and Thacrow like this.
  14. Jul 12, 2023 at 11:51 AM
    dropped the spare steely for the first time
    interested in spare tire carrier on the hitch
    I'd wrap the 17 in a newer spare 285 I have at 80%
    progress shots rehabbing the wheel
  15. Jul 12, 2023 at 11:52 AM
  16. Jul 14, 2023 at 3:33 PM
    actually impressed with just POR15's step one Degreaser man
    Thacrow likes this.
  17. Jul 14, 2023 at 3:35 PM
  18. Jul 15, 2023 at 12:59 PM
    just built my most redneck shelving yet in the Runner garage. wood storage.
    It's noon but the dash says 4:20, you know what time it is :rasta:
  19. Jul 15, 2023 at 2:09 PM
    starting POR15 3step paint under the ARB skids
    she's rusty bro
  20. Jul 15, 2023 at 5:44 PM
    POR15 Cleaner Degreaser→Specialty Products Company arm
  21. Jul 15, 2023 at 5:56 PM
  22. Jul 15, 2023 at 8:19 PM
    completed 1" Original EZ Flares off my garage queue
  23. Jul 16, 2023 at 7:12 PM
  24. Jul 18, 2023 at 7:50 PM
    Year #2 member of 4wdabc
    captrussia253 likes this.
  25. Jul 18, 2023 at 10:21 PM
    best photo this summer
    Blackshirt, Latrans, Dabigono and 3 others like this.
  26. Jul 23, 2023 at 12:05 PM
    Last step, sliced EZ Flares to match bumper lines
  27. Jul 28, 2023 at 2:27 PM
    Camo Toyota driving hat has arrived at last
    Latrans, roooo, Dabigono and 2 others like this.
  28. Jul 29, 2023 at 3:09 PM
    Cheeky rusted out soft screws, little bugger
    HONK IF YOU LOVE HONKY TONK
    -George Straight
    :canada:
    roooo, Dabigono and Thacrow like this.
  29. Aug 4, 2023 at 5:25 PM
    Back at my beloved Princess Auto. Free coffee and rad offroad lighting
  30. Aug 7, 2023 at 12:40 PM
    Rock Creek Rec. Site
    [off of Stave Lake]
    - Mission, B.C.
