Dip Stick Oil Level
Discussion in '5th Gen 4Runners (2010-2024)' started by Gonefar32, Jul 28, 2024.
  1. Jul 28, 2024 at 3:26 AM
    Gonefar32
    Gonefar32 [OP] New Member
    Hello all! I just did my first break in oil change at around 1000 miles on my 2024 ORP. I added exactly 6.6 quarts (using measuring containers that I have for oil change). I let the vehicle sit overnight and pulled the dip stick to allow for the oil to drain back from the tube, as well as I parked on level ground. When I check the level it is between the 2 dots and maybe an 1/8 of an inch under the top dot. Has anyone experienced this? Is it better to leave it as is since I know I put 6.6 quarts in or is it better to fill to the top dot?
    My other thought is I used ramps for the oil change and may have removed more than 6.6 quarts with the 30 min drain time since I’ve read the absolute dry fill of the engine is in the 7 quart range. Thank you!
  2. Jul 28, 2024 at 3:34 AM
    You're fine with the level! I put 6.5qts in mine and I'm right at the top dot. Drive it and enjoy!
    Shredder likes this.
  3. Jul 28, 2024 at 3:58 AM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    No need to overthink this. You are fine.
    icebear, Tama1968 and Shredder like this.
  4. Jul 28, 2024 at 6:55 AM
    Startrek
    Startrek New Member
    Oh man, you just scratch the surface in oil level ocd. Check it cold and hot, engine running or not, hot ambien temperature or freezing cold, before long trip - after long trip.Oil color gold or dark. Before dealership visit and after. Before and after speaking with your wife. There are millions of conditions that affect oil level and therefore millions reasons to worry
  5. Jul 28, 2024 at 7:21 AM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    You forgot if the dog farts smell or not that day.
  6. Jul 28, 2024 at 8:52 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Good lord. We now have a documented 24 hour oil long change.
  7. Jul 28, 2024 at 9:52 AM
    Tama1968
    Tama1968 New Member
    Florida
    you're good. I'm a reformed obsessive-compulsive maintenance guy myself, so I feel ya.
  8. Jul 28, 2024 at 9:58 AM
    Gumpus
    Gumpus New Member
    You may have lost a little oil from checking the level and wiping off the dipstick 300 times.
    Mr Swervlin and catbrown357 like this.
  9. Jul 28, 2024 at 10:08 AM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    When all else fails READ YOUR OWNER'S MANUAL!!
    It clearly says that the first dot is "Low", the second dot is "Excessive", in between the 2 dots is "Normal", just to make it even easier for you it's on page 415!!
    BS67, Nick B, catbrown357 and 2 others like this.
  10. Jul 28, 2024 at 5:17 PM
    Capacity is the maximum and you just gotta be between the dots, this isn’t a Hyundai or Kia.
    And measuring procedure varies, it may account for expansion of hot oil.
  11. Jul 28, 2024 at 7:31 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    I gave up getting an accurate reading a long time ago.
    make sure you give plenty of time for all oil to drain, add your 6.6 quarts and never check it lol
