Diode dynamics stealth mount.
Discussion in '5th Gen 4Runners (2010-2024)' started by Trees91, Jul 8, 2024.
  1. Jul 8, 2024 at 4:52 PM
    Trees91
    Trees91 [OP] .
    Forrest
    South Dakota
    2023 MGM SR5p
    Did a search, didn't find anything.
    I recently mounted two ss3 pro lights with diode ditch light mounts....I really don't like the way they look. I'm thinking of doing the stealth mount that mounts 4 pods behind the lower grill. I plan to order two more ss3 pods. My question is, are they accessible at all once they're mounted and the bumper is put back on? I'd like to have the option of using amber snap on covers during the winter. Anyone know if you can sneak your hand in there at all? Maybe from the top if you remove that plastic cover?
    Any help would be great. Thanks
  2. Jul 10, 2024 at 5:54 PM
    Bandit Runner
    Bandit Runner New Member
    Jeremy
    2021 TRD Off Road Premium
  3. Jul 10, 2024 at 7:05 PM
    T in Texas
    T in Texas New Member
    FEMA Region 6
    2024 Terra TRD Pro Terra - finally got it
    Have you watched the install video?
    It doesn't look like you'll be able to change lenses without removing the bumper again
  4. Jul 10, 2024 at 7:08 PM
    Trees91
    Trees91 [OP] .
    Forrest
    South Dakota
    2023 MGM SR5p
    I did. I guess I'll just have to see if I can get my hand in there somehow.
  5. Jul 10, 2024 at 8:09 PM
    Trees91
    Trees91 [OP] .
    Forrest
    South Dakota
    2023 MGM SR5p
    I can get my hand to were the lights would be mounted...not sure I'll be able to get a cover on or off... I'll just have to wait and see.
  6. Jul 10, 2024 at 8:47 PM
    T in Texas
    FEMA Region 6
    how about coming up from the bottom of the truck, and going behind the lights...just in front of the radiator?
    I just watched the instal video again, and about the 8:10 point they show a good view of the front...access looks really hard after its installed, but I like your idea.
    Have you thought about going 4 lights and having two white and two yellow?
  7. Jul 10, 2024 at 8:52 PM
    Trees91
    Trees91 [OP] .
    Forrest
    South Dakota
    2023 MGM SR5p
    I did reach up from the bottom. I can get there but it'll be tight depending on how close the lights are to the grill.
    I thought about 2 amber and 2 white but don't really want to run two wiring hanesses and two switches.
    The switch and harness I have installed now for the ditch lights can be used for the stealth mount. Just need two 4 pin splitters to add two more lights. I figured that keeps things simple.
