Diff Breather Options Other Than ARB??
Discussion in '5th Gen 4Runners (2010-2024)' started by 1SilverRunner, Feb 6, 2024.
  1. Feb 6, 2024 at 12:34 PM
    1SilverRunner
    1SilverRunner [OP] My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Anyone make their own diff breather extension? All you need is some hose and a check valve right? Not sure why I should buy the ARB kit when I can make one for less than 5 dollars...
    Am I missing something
  2. Feb 6, 2024 at 12:37 PM
    kolter45
    Denver
    Inferno Pro & BRM Sport
    Toytec has a cheaper one
    1SilverRunner[OP] likes this.
  3. Feb 6, 2024 at 12:46 PM
    1SilverRunner
    Tejas
    kolter45[QUOTED] likes this.
  4. Feb 6, 2024 at 1:02 PM
    Just run a hose with the same type of cap Toyota uses at the end. The ARB is just bling.
  5. Feb 6, 2024 at 1:42 PM
    The barb fitting that threads into the axle is British pipe thread, so it's best to use the Toyota P/N fitting, which is a bit more than 5 dollars. You're free to piece together the rest yourself. Don't even need a check valve. I made a loop with about 12" of hose and ziptied it to the fuel filler pipe running up inside the quarter panel: https://www.4runners.com/posts/497985
  6. Feb 6, 2024 at 1:55 PM
    whippersnapper02 and kolter45 like this.
  7. Feb 6, 2024 at 2:37 PM
    1SilverRunner
    Tejas
    Looks like I can make it myself for 10-15 or pay the convenience fee of ordering it from the yotashop.
    Convenience fee it is!
    Thanks for the input guys.
  8. Feb 6, 2024 at 2:38 PM
    1SilverRunner
    Tejas
