Deep snow fail....
Discussion in '5th Gen 4Runners (2010-2024)' started by cuse93, Feb 28, 2026.
  1. Feb 28, 2026 at 7:58 PM
    cuse93
    cuse93 [OP] Ice Station Zebra
    After almost 4 years of 4Runner ownership I finally met my match in 4' drifts. I would have gotten better pics but I was in a particularly foul mood at the time because I was trying to get across my property to rescue my Polaris Ranger which was stuck in an even worse jam. Getting stuck in deep snow with my previous Tacomas and Tundras was a fairly regular occurrence for me. I think I had convinced myself that the 4Runner was immune to it. Tried it all.... 4 Low, rear locker, crawl modes, etc..... wasn't happening.IMG_7988.jpg
  2. Feb 28, 2026 at 8:18 PM
    Everything has its limits which you discovered.
    BS67, 2Toys and ToyotaDude99 like this.
  3. Mar 1, 2026 at 4:25 AM
    Snow to the top of your hood? Don't think any vehicle would make it through that.
    ToyotaDude99 likes this.
  4. Mar 1, 2026 at 7:18 AM
    Schlappesepple
    Schlappesepple New Member
    2020 ORP
    Nah, he just needed more speed. And maybe one of those plows they run on trains.
    ToyotaDude99 and BS67[QUOTED] like this.
  5. Mar 1, 2026 at 7:27 AM
    cuse93
    I had made a first pass on my driveway with the plow earlier in the storm.... so I was driving thru only about 16" of fresh snow....unfortunately, that fresh snow was on top of a thick layer of ice. I was on an off-camber section of my driveway and the 4Runner slid from 16" deep snow into well over 3' of snow. Like a dope, I just tried to power thru it. After 30 mins of shoveling, i had to slink back into the house and ask my wife for the keys to her Silverado.
  6. Mar 1, 2026 at 8:57 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    that’s funny, and surely frustrating!
    good candidate for tribute to stuck 5th gens
    https://www.4runners.com/threads/tribute-thread-to-stuck-5th-gen-4runners.42349/
    ToyotaDude99 and BS67 like this.
  7. Mar 1, 2026 at 6:50 PM
    Where’s the 4runner? :D Seriously though, that’s a lot of snow.
    Deep snow is the great equalizer. Once it’s high enough to support the weight of the vehicle by the underside, you’re pretty much not going anywhere. Best you can hope for is for the snow to be hard enough to keep the vehicle from breaking through. But that’s kind of impossible to achieve for any amount of distance. Once the tires break through, the only way to get through is to dig out, and then clear the snow between you and where you want to go.
    ToyotaDude99 and 2Toys like this.
  8. Mar 1, 2026 at 9:09 PM
    Did the Silverado get it out, or do you have to wait for Spring? :eek:
    Saker, NB4x4 and ToyotaDude99 like this.
  9. Mar 2, 2026 at 7:48 AM
    jgalt
    jgalt New Member
    You're not stuck until snow is packed up in the engine bay to the underside of the hood. It wasn't a 4R, just a '68 Nova inline six w/ studded snows, and a long lane of deep snow, and countless running start attempts to get out to the plowed road. The farm tractor pulled me out the following morning. Those were the days lol.
  10. Mar 2, 2026 at 12:20 PM
    OK, ill ask. So did the vehicle who pulled BOTH the Polaris AND 4runner out get stuck?
    ToyotaDude99 and NB4x4 like this.
  11. Mar 2, 2026 at 6:31 PM
    cuse93
    I did pull the 4Runner out with the wife's truck....but I was EXTREMELY careful about it and shoveled quite a bit beforehand. If I pulled a hat trick and got her truck stuck too I would have been truly screwed. This has been the February from Hell.
    IMG_7987.jpg 03BE89C6-A309-4EB0-8C6E-3ED59304EAAC_L0_001.jpg B1F896C5-E360-4056-866B-75A5321668C0_L0_001.jpg IMG_7992.jpg
    ToyotaDude99, NB4x4 and 2Toys like this.
  12. Mar 2, 2026 at 6:44 PM
    Photon_Chaser 65,322 smiles and counting…
    West Coast!
    Might be time to consider...
    Saker, ToyotaDude99 and NB4x4 like this.
  13. Mar 2, 2026 at 7:54 PM
    mac1usa
    mac1usa New Member
    Or better yet become a snow bird.
    NB4x4, 2Toys and ToyotaDude99 like this.
  14. Mar 3, 2026 at 4:15 PM
    water
    water New Member
    brian
    Portland, OR
    2019 4runner
    Yes
    I wanna see you do this… I am sure it is a quick swap each winter. Lol.
    Han4Run, NB4x4 and ToyotaDude99 like this.
  15. Mar 3, 2026 at 4:44 PM
    That is a lot of freakin snow holy cow! Be safe, it’s real easy to mess yourself up working with that much snow. I messed up a knee a couple years back clearing some snow. Took a year to get better, but even then it still ain’t right!
    I gotta say those things are pretty neat. I looked into them briefly and was surprised how fussy they are. And so expensive. Pretty much would need to live Antartica to have them be worth it lol.
  16. Mar 3, 2026 at 9:31 PM
    West Coast!
    Saw this bad boy last year.
    Han4Run and 2Toys like this.
