Death shake
Discussion in '2nd Gen 4Runners (1990-1995)' started by jonasshole, Jan 26, 2021.
  1. Jan 26, 2021 at 8:42 PM
    jonasshole
    jonasshole [OP] New Member
    94 4 runner
    Hi I have the “death shake” in my runner and can’t figure out the problem been to two different mechanics in my area it’s not any of my joints the wheels or the alignment had them all checked wondering if anyone has a knowledgeable mechanic that I could trust find the problem come on around over 60 mph and shakes the whole car feels like it’s comping from the center but I can’t really tell
    Southern California
  2. Jan 26, 2021 at 11:06 PM
    Simtech
    Simtech New Member
    Rob
    Ozark, Al
    2019 Metalic Gray 4Runner XP Gunner
    Not pretending to know anything about "death wobble" in second gen 4runners but my daughters jeep did this and it ended up being the track/panhard bar. The bushings in the ends looked fine but we replaced them anyway and it fixed the problem. We fought with this problem for quite some time and finally started throwing parts at it and got it fixed pretty quick. Good luck hope this helps.
  3. Jan 27, 2021 at 11:07 AM
    jonasshole
    94 4 runner
    seems like its the from
    seems like its the motor mount that's causing it to shake anyone have recommended parts store or place for 2nd get parts oem if possible
  4. Jan 27, 2021 at 4:38 PM
    That’s how my Corolla ran after Toyota serviced it. They bent three rims and tried to charge me 4K.....,,,
  5. Jan 29, 2021 at 8:04 AM
    D60
    D60 New Member
    Is this triggered by bumps or just occurs on smooth road? Does the steering wheel vibrate back and forth noticeably when it happens?
    No track bar on IFS, it's a very different animal from a solid axle Jeep
  6. Jan 30, 2021 at 8:52 AM
    Dezman92
    Dezman92 New Member
    Doug
    Norcal
    1994 Green 4runner
    Has anyone checked to see if your tires are balanced? Some boneheads at 4 wheel parts balanced my 33s wrong when they installed them and it shook the whole truck when I went 60 mph. I went back and they still couldn’t get it right. Tried telling me it was my fault and tried selling me a bunch of BS I didn’t need. I’m a mechanic, I knew the front end was ok. I was unemployed at the time, so once I was back working at a shop, I balanced them and they were off by 4oz each! Yeah, sounds like your tires aren’t balanced or out of round so I would get that checked before diving into the suspension
    Toy4X4 and mousemeat like this.
  7. Feb 19, 2021 at 4:29 PM
    atgparker
    atgparker Cal Poly, ETME 1988
    Andrew
    Mission Viejo, CA
    1991 White 4Runner 3.0 L
    You can grab the PS tire at 9 and 3 o'clock and look at the idler arm and see if it is wiggling in the housing that is bolted to the frame. Also look at the rag joint on the steering column.
  8. Mar 6, 2021 at 9:26 AM
    jonasshole
    94 4 runner
    finally got her running smooth ended up being a rim problem the whole time I guess the previous owner had made his own 6th lug nut whole to fit the rim only took 3 tires shops to figure that out and them trying to charge me to fix everything else I just got some stock rims off offer up for about 120 realigned and had the right lug nuts put on for 14 and now she's as smooth as ever had
  9. Mar 6, 2021 at 9:28 AM
    D60
    D60 New Member
    Alright then! Thanks for posting the resolution!
