Dead sunroof & Dome Light
Discussion in '4th Gen 4Runners (2003-2009)' started by SpringfieldSG, Jul 9, 2022.
  1. Jul 9, 2022 at 7:43 AM
    SpringfieldSG
    SpringfieldSG [OP] New Member
    Steven
    2006 4Runner Sport White
    Only a touchscreen media deck so far. Much more to come.
    I searched and couldn’t find anyone else with this exact issue.
    my new-to-me 2006 4Runner sport has a non-functioning front dome light. I changed the bulb and nothing. The sunroof is also completely dead, the motor doesn’t even make a sound.
    The dome light & sunroof motor I believe are housed in that same overhead housing compartment. Assuming it’s not a fuse (I’ll check, but I believe these two items are on different fuses), I’m guessing it must be some other electrical malfunction.
    Any ideas on what I should be checking on first? My theory is that some water somehow got into that plastic housing and fried something (but I can’t confirm this and could be completely wrong)
    Any help would be appreciated. I don’t want to buy a whole new sunroof motor if it’s just a wire set that I need to replace.
  2. Aug 3, 2022 at 9:12 PM
    GiveMeTheOutdoors
    GiveMeTheOutdoors New Member
    Ty
    2020 SRS 5
    Led lights all around, Thule Rack, Off road tires. So far !! LOL
  3. Aug 3, 2022 at 10:01 PM
    I would be shocked that they spent the money to run two circuits to the same housing. My money is it's a fuse.
  4. Aug 3, 2022 at 10:25 PM
    GiveMeTheOutdoors
    Ty
    2020 SRS 5
    I'd agree. It's rare that you see wiring go bad unless something is rubbing or has overheated. It's just like running a wiring harness to a trailer. If it's not grounded properly fucky stuff happens. I'd also check to make sure your main grounds are good and not corroded at the contact points :)
  5. Aug 4, 2022 at 6:01 AM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    Its a fuse. Now, why it blew, may be the better question.
  6. Oct 26, 2022 at 11:57 AM
    GigemAgz95
    GigemAgz95 New Member
    Brad
    Houston, TX
    2007 v6 SR5 2wd. 51K mi
    KPMF stealth Tundra vinyl wrap. Interior Led mod. Fog light mod. Jensen deck, Polk DB plus doors. Blackout of chrome - Emblem Delete.
    Late to party, but adding .02 that may/not help. reason for Short.. water somewhere... i.e. from your sunroof...leaking and backing up from the drains, and getting to the headliner. just a Thought. That's was the reason for the Puddle in passenger floorboard - for me... clogged A-pillar drains. just throwing that out there.
