Dashboard "Maintenance" Word
Discussion in '4th Gen 4Runners (2003-2009)' started by 08toyobill, Aug 2, 2025 at 8:40 AM.
  1. Aug 2, 2025 at 8:40 AM
    08toyobill
    08toyobill [OP] New Member
    Bill
    Grey 4runner
    none
    My '08, low mileage 4runner has showed this message in the lower left side of dash for a couple weeks now. The only other warning icon is for low tire pressure...one of the sensors is bad. The vehicle is running normal and showing no signs of problems. I maintain the vehicle with normal fluid and filter changes.
    Any thoughts ??
    Thanks, Bill
  2. Aug 2, 2025 at 8:43 AM
    In a 4th generation Toyota 4Runner (2003-2009), the "MAINT REQD" or "Maintenance Required" light illuminates after 5,000 miles as a reminder for routine maintenance, primarily an oil change.It's a separate indicator from the check engine light and doesn't necessarily mean there's a mechanical issue.
  3. Aug 2, 2025 at 8:54 AM
    Probably hasn't been reset
  4. Aug 2, 2025 at 2:26 PM
    4onto
    4onto New Member
    Toronto
    2009 SR5 V6 4WD
    Sometimes, it's a low spare tire that turns the low tire pressure light on.
  5. Aug 2, 2025 at 2:38 PM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    As mentioned on a 4th Gen T4R the "MAINT" is a notice/reminder that it's time to changed the oil and possibly do other maintenance, you can reset it yourself easily, here's a video that shows you how to do so.
    https://youtu.be/MTaT43dBtlo?si=WbAIcpUpVNMbAam3
    LOSTR4 likes this.
  6. Aug 3, 2025 at 12:00 PM
    08toyobill
    Bill
    Grey 4runner
    none
    Problem solved...thanks for the help guys. And thanks for not calling me a dummy and suggesting I just read my manual!
    AuSeeker likes this.
