Dash lit up red with the brake warning light and a buzzer
Discussion in '5th Gen 4Runners (2010-2024)' started by KENTUCKYRUNNER, Jan 8, 2023.
  1. Jan 8, 2023 at 3:42 PM
    KENTUCKYRUNNER
    KENTUCKYRUNNER [OP] New Member
    2006 sport to a2016 SR5 PREMIUM TO A 22 LIMITED
    Said she was coming up on a cross street and a car pulled out in front of her but was about 8 to 10 car lengths ahead so she doesn't even know if she hit the brakes but her dash lit up red with the brake warning light and a buzzer then went right off. the book says doesn't necessarily mean a malfunction but contact dealer. also says could be low break fluid. She says it hasn't been back on.Its a 2022 with 6000 miles, wouldn't think low break fluid. any suggestions?
  2. Jan 8, 2023 at 3:54 PM
    If it's a '22, it could have just been the TSS telling her to brake, or trying to brake for her. My work truck lights up the dash anytime I come up behind another vehicle faster than it likes.
  3. Jan 8, 2023 at 4:01 PM
    KENTUCKYRUNNER
    I think this is it, but she says wasnt that close, but mothers! lol thanks alot
  4. Jan 8, 2023 at 4:08 PM
    wdsteven
    wdsteven New Member
    Sound like the TSS did what it is suppose to do.... Shock you into action to put the Brakes on NOW! I had mine go off once and Yeah it certainly got my attention quick and that is just what the Toyota is suppose to do. as for Low brake Fluid Quick easy check of that is open the hood and look at the Brake fluid reservoir and you can see the liquid level easy and the full markings on it but I doubt there is an issue there.
  5. Jan 8, 2023 at 5:00 PM
    Haha!
    The issue I have is that it doesn't know whether you're approaching a vehicle turning off, cross traffic, or a brick wall. So, it always reacts as though you're approaching a wall or stopped/stopping vehicle.
    brownersd likes this.
  6. Jan 8, 2023 at 5:04 PM
    Tama1968
    Tama1968 New Member
    Florida
    If it's anything like my wifes Honda Pilot, the 'radar" will randomly set the BRAKE alarm off when another car is still a quarter mile away. One of the reasons I'll probably keep my 2019 Runner forever...
    brownersd, 2Toys and Thatbassguy like this.
  7. Jan 8, 2023 at 5:35 PM
    2020 4Runner
    2020 4Runner New Member
    Fl
    You are good to go. The TSS is programmed to calculate speed and the distance between an object that comes in front of it. It's a warning to the driver to brake to avoid a collision. The warning is red or amber colored. If it was a malfunction, it would be white on the display and it will also show on the radio display.
  8. Jan 8, 2023 at 7:22 PM
    I was just complaining about this on another thread :p
    Also don't panic if 4Runners with TSS decided to apply hard brakes a vehicle in front of you turn right and stop for that lane traffic (even there is not a single vehicle in front of you). Hope the person behind you don't crash in to you or get angry thinking you have applied brakes for no reason. :p
  9. Jan 8, 2023 at 7:33 PM
    TSS on mine has acted strange on two occurrences. Each time it was a merging right turn onto a continuing moving traffic lane.
    Halfway through the turn/merge it would activate. I am unsure if this was due to the lane lay out or the yellow directional pylons.
    On the 3rd time in the same area, with a slight amount of brake pressure, all acted normal.
    This has made me become a little more gun shy on clover leaf s and same lane merges going forward.
    Each time, the front sensor was clean and not blocked. I honestly believe the sensor logic is just in the infancy stages in regards to go, no go situations.
  10. Jan 9, 2023 at 8:45 AM
    NOS4A2-1
    NOS4A2-1 New Member
    NY
    2020 Venture
    I believe you can adjust the sensitivity of the distance in front of you that the warning will activate. You may have it set to high. I think its in the menu options on the display between the rpm and speedometer.
    Saker and wdsteven like this.
  11. Jan 9, 2023 at 8:55 AM
    It’s very sensitive in Toyotas.
  12. Jan 9, 2023 at 12:37 PM
    totmacher
    totmacher New Member
    Daniel
    West TN
    2018 SR5 Nautical Blue
    done some stuff to it
    At least you aren't in an 18 wheeler with it automatically hard braking at shadows from the overpass or tar lines as you approach at highway speed.
    I've heard of that happening.
  13. Jan 9, 2023 at 12:52 PM
    wdsteven
    wdsteven New Member
    You can "Adjust" it since it is a simple menu driven selection for LTA, LDA and the PCS they are delivered at full sensitivity and you can dial it down some or turn off.
