DASH GEAR SELECTION INDICATOR
Discussion in '5th Gen 4Runners (2010-2024)' started by JBauern, Mar 9, 2023.
  1. Mar 9, 2023 at 4:12 PM
    JBauern
    JBauern [OP] New Member
    2020 TRD
    I noticed the other day, while using the gear selector manually, that the gear selector would show the 4 display in the center part of the information panel, then when i moved it into D , the indicator would show D. ( normal). But this last time, i moved the shift lever forward, ( not D) , the indicator showed 5. I then moved the lever to D, and the D illuminated. I do not seem to be able to locate anything for this in the owner's manual. does 5 mean the torque converter may be unlocked for towing. My previous vehicle had a TOW/HAUL feature, which unlocked the torque converter for towing.
  2. Mar 9, 2023 at 4:26 PM
    Following..
    I love to see the gear position in D if possible. I wonder if some tool like scanguage can show it. Anyone has an idea?
  3. Mar 9, 2023 at 4:32 PM
    I'll do it next time I drive it, but pretty sure my 2013 does this. When you're in 4, and shift up, you're just manually shifting it into fifth gear.
  4. Mar 9, 2023 at 4:36 PM
    I thought if you select 5 this tells the car "you can shift up to 5" vs if you select 2 it will shift only up to 2nd. I'd love to see a method to see "what gear am I in?" :):)
    MartianArmada and Thatbassguy like this.
  5. Mar 9, 2023 at 4:41 PM
    I think this is true, as @Thatbassguy has reminded us periodically. But it also wouldn’t surprise me if moving the shift lever into “S” mode also changes the shift points.
  6. Mar 9, 2023 at 4:57 PM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    I did my scan gauge tool MPG, eng transmission temps , lookup that scan gauge tool a lot of the data of the vehicles .
  7. Mar 9, 2023 at 5:12 PM
    My understanding is that you are just giving it permission to shift in the fifth gear. If you are full throttle at low speed and bump it to S5, it will not shift into overdrive instantly. It will shift into overdrive when it decides to.
    Unfortunately it is snowing here right now so I can't go outside and test this. Maybe tomorrow morning...
    I think you are correct. I'm going to try to confirm that tomorrow.
    I do think that being in S mode affects the way it shifts. In overdrive, it seems to always head right to the highest gear available. But, in S mode, it seems like it holds gears for just a little bit longer. This could just be in my head though.
  8. Mar 9, 2023 at 5:59 PM
    Actually, you want the torque converter to lock for towing. In "S" mode, you control the top gear the transmission will shift into. It will also engine brake more in "S" mode.
