D light flashing
Discussion in 'General 4Runner Talk' started by mauihiguy1029, Apr 19, 2024.
  1. Apr 19, 2024 at 7:42 AM
    mauihiguy1029
    mauihiguy1029 [OP] New Member
    Jayme
    What does it mean when my Drive light is blinking
  2. Apr 19, 2024 at 7:48 AM
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    2023 TRD Pro Ice Cap
    What does the owners manual say?
  3. Apr 19, 2024 at 7:51 AM
    mauihiguy1029
    Jayme
    Just got the car this morning , honestly I for got about that ,i must have had a Biden moment...I'll go check that out thank you
    2Toys and LCJ77 like this.
  4. Apr 19, 2024 at 7:54 AM
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    :yes::cheers: Was your uncle shot down:plane: & eaten:hungry: by cannibals' too :anonymous:
  5. Apr 19, 2024 at 8:06 AM
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    What Yr/Model?? I looked in my old 2018 TRD OR manual I down loaded back when I bought it. pg 417-426 I didn't see any "D" in the warning lights?
  6. Apr 19, 2024 at 8:25 AM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    More info needed. I know on my 2019 R (reverse) blinks when it's engaged.
    But D (drive) may mean a transmission issue?
  7. Apr 19, 2024 at 9:03 AM
    Probably a flaky transmission range sensor (aka neutral safety switch).
  8. Apr 19, 2024 at 9:20 AM
    This seems pretty typical. Mine acts up from time to time. I wonder if I should just go ahead and change it preemptively.
  9. Apr 19, 2024 at 9:30 AM
    ^I think a failed switch may strand you (can't crank the engine if "P" position isn't detected).
  10. Apr 19, 2024 at 9:32 AM
    That's certainly some incentive to get it done. :eek:
  11. Apr 19, 2024 at 9:37 AM
    Daddykool
    If you do it, let me know how painful it is. Guy at the dealership said they can be a pain and you need to be careful not to break the pin/shaft that extends out of the transmission. He's a solid guy whom I've worked with for years.
  12. Apr 19, 2024 at 9:54 AM
    ^On a 2019, it probably isn't too painful. On older 4Rs, you'd be chiseling the rusted old switch off in pieces. There are Youtube videos showing how that's done.
  13. Apr 19, 2024 at 12:18 PM
    Daddykool
    So 2019 is different/easier?
  14. Apr 19, 2024 at 3:56 PM
    ^Newer years will be less rusty.
    Daddykool[QUOTED] likes this.
