CV axles replacement
Discussion in '5th Gen 4Runners (2010-2024)' started by wanderer75, May 10, 2023.
  1. May 10, 2023 at 7:38 PM
    wanderer75
    wanderer75 [OP] New Member
    2019 4runner
    I’m new to this forum and appreciate all the helpful information posted. I have been traveling cross country from the east coast to the west. My 2019 4runner has about 42k miles. Sent it in for brakes and oil change at a friend’s mechanic. He told me the CV boots are leaking and the axle should be replaced. There was mention of all the rust and how hard the roads can be on the vehicles. Keep in mind I am currently in a state that never sees vehicles rust. Everyone who is more knowledgeable about such repairs tells me this doesn’t seem right at such low mileage. I barely go off road, just some dirt roads now and then…No modifications. Just 3-4 years of New England winters. Appreciate any feedback. Thanks.
    mrmike7189 likes this.
  2. May 10, 2023 at 7:45 PM
    afret
    North Idaho
  3. May 10, 2023 at 7:46 PM
    Stitches1974
    Stitches1974 New Member
    2023 Nautical Blue TRD ORP
    Depends on how the vehicle was treated. As a former NYer, I've seen new vehicles rust out in under 2 years, because the undercarriage was never washed.
  4. May 10, 2023 at 7:46 PM
    I agree, seems unusual.
    But, a 19’ with less than 60k miles should still be covered under the Toyota powertrain warranty which is 5 years or 60k miles. Find a dealership and get it fixed. I’ve heard that OEM CV axles are far superior than aftermarket.
  5. May 10, 2023 at 8:30 PM
    Welcome to the forum!
    As mentioned above, that seems super premature. But, it's worth having another shop, or the dealership take a look.
    McSpazatron and wanderer75[OP] like this.
  6. May 11, 2023 at 4:21 AM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    2019-2020 4runners are the axle bearings !!!!!!! looks like the CCP .... CHINA !
    I was the rubber parts of the exterior boots and the steering .. I did the silicone spray ..
  7. May 11, 2023 at 7:37 AM
    marinrunner
    marinrunner Not a New Member
    2023 ORP, MGM
    Stock on Mickey Thompson Baja Boss, XL load, 265/70/17
    Can't speak to the rust, but my 2019 had leaking CV boot on passenger side at around 25-30K mi. Might not be common, but definitely not unheard of. The rust is a separate issue that has nothing to do with the CV boot leak.
    Dealership replaced the entire axle assembly under warranty (no rust on my axle or undercarriage).
    Mechanic is probably recommending replacing the entire assembly because it's easier not because of rust.
    Leak was easy to spot (if you happen to be laying under the truck): thick gear oil flung all around the undercarriage.
  8. May 11, 2023 at 1:09 PM
    j cat
    j cat New Member
    massachusetts
    so 2019 of the front axle of the bearings , then the seal is damaged of the bearing ,, and the bearings are the china parts of the bearings ... 2019-2020 !
  9. May 11, 2023 at 2:16 PM
    afret
    North Idaho
    Huh?
    Mully410, Too Stroked and Rocko9999 like this.
  10. May 11, 2023 at 3:24 PM
    j cat
    j cat New Member
    massachusetts
    did your 2019-2020 4runner of the front axles of the bearings ...
    look up the dealership of the 2019-2020 inspect it ...
  11. May 11, 2023 at 3:32 PM
    Startrek
    Startrek New Member
    Double Huh? (to j cat).
    I think it is Scottish lingo.
    java, Bagman, Mully410 and 3 others like this.
  12. May 11, 2023 at 3:44 PM
    j cat
    j cat New Member
    massachusetts
    toyota is the 2019-2020 bearings ....replaced it .
  13. May 11, 2023 at 4:46 PM
    rottielvr
    rottielvr New Member
  14. May 12, 2023 at 7:23 AM
    marinrunner
    2023 ORP, MGM
    I think he trying to say there's some problem with the bearings in 2019-2020 and to replace them? I am not aware of any problems with the bearings. No symptoms that I am aware of. Haven't seen any other posts about it.
    ***Come to think of it, maybe he's referring to the needle bearing issue that affects some? I haven't had that problem. Many replace the needle bearing with the ECG bushing.
    j cat[QUOTED] likes this.
  15. Mar 7, 2024 at 10:11 AM
    JS222STL
    JS222STL New Member
    2020 SR5 premium
    j cat likes this.
  16. Oct 20, 2024 at 12:20 PM
    mrmike7189
    mrmike7189 New Member
    mike
    2020 silver SR5 4x4
    My 2020 had axle boots replaced twice already due to tears in the rubber both times it was covered under warranty ......haven't had any issues with bearings........yet!:D
  17. Oct 20, 2024 at 2:13 PM
    Are you saying to replace the bearings? Wording is, in a way confusing, trying to understand.
  18. Oct 20, 2024 at 2:54 PM
    LetsTacoboutit
    Adobe
    What we'd give for a non-stroke victim, complete sentence with an attempt of punctuation in some of these posts. OMG. "Say 'what' again, I dare you!!!"
  19. Oct 20, 2024 at 3:34 PM
    Too Stroked
    Too Stroked New Member
    Tom
    South shore of Lake Ontario
    2021 SR5 Premium
    English translation please? Your posts are not making sense.
    java likes this.
  20. Oct 20, 2024 at 3:47 PM
    That may actually be the case judging from his previously post history with much clearer communication. Take what you can from the post, sometimes you can tell what he’s trying to say. I’m probably sure it’s frustrating on both sides.
  21. Oct 21, 2024 at 1:09 PM
    j cat
    j cat New Member
    massachusetts
    the china bearing 2019-2021 runner bearings destroy !!!!
    Toyota company bearing maintenance ...
    java likes this.
  22. Oct 21, 2024 at 1:16 PM
    Acesandeights
    Acesandeights #34
    2024 ORP
    Not everyone's first language is English. Good job for trying @j cat It sounds like what you're trying to say is, China is 4Runner bearing wear destroy bad and fix good if dealer 4Runner maintenance company. Hope that helps indeedy.
    glwood54 likes this.
  23. Oct 21, 2024 at 1:45 PM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Don't bother, just ignore.
  24. Oct 21, 2024 at 1:47 PM
    Rocko9999
    2011 Limited
    Without visually inspecting yourself, don't replace anything. Crawl under and take some pictures and post them.
  25. Oct 22, 2024 at 6:39 AM
    ^OP had a single post a year and a half ago then disappeared. We can only surmise he died a fiery death when his CV axle exploded like in a Michael Bay movie. The rest of the thread is about a possible stroke victim.
  26. Dec 27, 2024 at 8:33 AM
    19runner
    19runner New Member
    Elliott
    194runner
    I have 19 4Runner @ roughly 40k my driver side cv axel was replaced due to a leaky boot it was under warranty. 4Runners at about 60k and the CV needs to be replaced again no leak noticed just a horrible grinding and screeching noise. Of course we are out of warranty. Was curious if anyone had replaced those axel with aftermarket equipment? Seems the axels for this year are trash (and expensive). Any aftermarket recommendations?
    We don’t off-road this 4Runner, my wife basically drives the kids to school and target lol
  27. Dec 27, 2024 at 10:16 AM
    ^Pictures of the inboard CV joint? How high are you lifted?
    Which side are you hearing the grinding, driver or passenger?
    The OEM CV axles are actually the best in the business for a mass-produced offering. Some aftermarket ones are OK; some have less articulation so they lock up at full suspension droop.
    To get better-than-OEM CV axles, you'd be spending ~$2000 for competition-grade hardware from RCV, Longfield, etc. where the technician puts his nametag in the package:
  28. Dec 27, 2024 at 10:31 AM
    19runner
    19runner New Member
    Elliott
    194runner
    Stock height, nightshade edition so it’s running 20in rims
    yes inboard board joint on drivers side
    oooo 2k!? I guess I’ll stick with Toyotas axle for 500
    I’ll try to grab some pictures today or a video
  29. Dec 27, 2024 at 11:38 AM
    j cat
    j cat New Member
    massachusetts
    2019-2021 the CHINA AXLE CV FRONT HORRIBLE !!!!!!!!!!!!!!
    java likes this.
  30. Dec 27, 2024 at 12:43 PM
    You'll want to isolate the problem. It's rare for an OEM CV joint to go bad without leaking. Grinding/screeching could also be wheel bearing, brake contamination, or the brake pad wear indicator being bent.
    At 40k, did the dealer replace the whole CV axle or just the boot? (Toyota sells boot kits with grease and clamps.)
