CV axle disassembly problem passenger side....
Discussion in '4th Gen 4Runners (2003-2009)' started by 4runnerPRO, May 6, 2020.
  1. May 6, 2020 at 6:23 PM
    4runnerPRO
    4runnerPRO [OP] New Member
    2005 4Runner Limited 4WD 4.7V8
    Hey Folks,
    Had my bearing go, kept driving n got quite wobbly and finally lost acceleration. Today got down to check/change the bearing n hub assembly. The CV axle would not come out hitting with pry bar at the notch, the end is off the knuckle held secure from falling. When i tried pull n turn the CV end it just turns by itself, IS THAT NORMAL. Or did it disconnect from the rest of the axle. I cut the seal (was already open) & just took the end part out for pictures.
  2. May 12, 2020 at 11:17 AM
    Crikeymike
    Crikeymike Exit Offroad, Dobinsons Specialist Vendor
    Jax Beach, FL
    2014 4Runner w/Dobinsons MRA Suspension, Shrockworks bumper/sliders
    I'm not sure if this will answer your question, but the CV is separated into 2 halves. Half is still inside the differential housing, so that needs to come out.
  3. May 15, 2020 at 10:33 AM
    Agent_Outside
    Built 2011 T4R Limited
    You pulled the joint apart in the boot.
  4. May 15, 2020 at 10:57 AM
    kbp810
    kbp810 rebmem wen
    My trick for pulling a CV Axle, is to pry on both sides. If you're just using one pry bar, you are side loading the C Clip, making it even more difficult to pull. I use a large flat head screw driver on one side, and a pry bar on the other; or, I've even used just two large flat heads before. Give just enough pressure on the screwdriver to even it. Usually comes out fairly easily without much fuss using this method.
  5. Jun 6, 2020 at 12:38 PM
    WarChild
    WarChild New Member
    2005 JRU 4Runner
    They make a fork tool that would help you remove that. I had to use one to get my drivers side axle out. Pry bar wouldnt do it.
  6. Jun 14, 2020 at 1:36 PM
    chassis
    chassis New Member
    Indiana
    Sold: 2005 4Runner SR5 V6 4WD
    @4runnerPRO How is it going? Did you replace the shaft?
  7. Jun 16, 2020 at 3:03 PM
    4R777
    4R777 New Member
    Crikeymike and kbp810 like this.
  8. Jun 28, 2020 at 10:47 AM
    WMU
    WMU New Member
    Frank
    Wabamun, Alberta
    2006 - 1GR-FE - Ltd - 2007 - 1GRE - Ltd - 2008 - 2UZ - Ltd
    Shrockworks Bumper - Winch - Rock Sliders - Bilsteins - 2 inch lift - Hankook Dynapro MT
    A slide hammer, axle flange and two vice grips. The slide hammer and axle flange are usually available at an auto parts store. Free rental. THe vice grips must be top quality or they will release every time you slide back, with force, the hammer. I used my 50 year old craftsman and purchased an Irwin. Irwin is not a good tool. Avoid!
