Criss cross tires when rotating?
Discussion in 'Wheels & Tires' started by Hank69, Sep 18, 2024.
  1. Sep 18, 2024 at 11:49 AM
    Hank69
    Hank69 [OP] New Member
    Hank
    2002 Blurple 4runner
    Hey all.....
    Quick question about Tire rotation.
    Do I have to Criss Cross my tires when I rotate them, or can I just switch back & front?
    Or, if I can do either or, which way is best for the life of the tires?
    I have free rotation, but I don't want to go back to where I got them.
    They tightened the lugs so tight that I needed a breaker bar to break them free, which is not good for the rotors.
    The pic is the actual tire.
    As always, any wisdom is much appreciated.
  2. Sep 18, 2024 at 11:51 AM
    Acesandeights
    Acesandeights #34
    2024 ORP
    Are you doing a four or five tire rotation?
    Hank69[OP] and Thatbassguy like this.
  3. Sep 18, 2024 at 12:23 PM
    You can just go front to back, if you prefer. I think the typical pattern is to drop the fronts straight back, and bring the rears across and forward.
    I do a Z pattern:
    DF->PF, PF->DR, DR->PR, PR->DF.
    It's not typical, but this way every tire changes direction at every rotation. My tires have been wearing great and having excellent tread life since I started doing it this way.
    Hank69[OP] and Bob like this.
  4. Sep 18, 2024 at 12:42 PM
    Stoney Ranger
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
  5. Sep 18, 2024 at 1:01 PM
    I've never crossed them just front to back and never had issues with premature wear.
    Ripper238 likes this.
  6. Sep 18, 2024 at 1:11 PM
    Lost Woods
    Lost Woods New Member
    I like the rearward cross here personally. Been doing it that way for years every 4-5k and I've had zero cupping issues on all kinds of ATs. Best part is you can do it with a single floor jack on the frame and only have to lift twice.
    TrailSpecial22 and Hank69[OP] like this.
  7. Sep 18, 2024 at 1:18 PM
    Durango Dave
    Durango Dave New Member
    Durango, Colorado
    2023 4Runner Off-Road Premium w/ KDSS
    Some directional tires can only be rotated front to back - check your tires to make sure they are not directional if you are doing the crisscross rotation :mudding:
  8. Sep 18, 2024 at 1:24 PM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    interesting, I guess I use the front wheel drive rotation. I drop my spare, use that as a place holder on my rear passenger, rp goes to df. Df to dr, dr to pf, and finish with pf to pr and spare back up.
    Does it really make a difference or can some one explain why using the 4 wheel-drive way Would be better than the front wheeled way.
  9. Sep 18, 2024 at 1:59 PM
    Acesandeights
    Acesandeights #34
    2024 ORP
    Just FYI, those tires are not directional, so you don't have to worry about that. Are you doing a four or five tire rotation? Have you checked your owner's manual?
  10. Sep 18, 2024 at 2:25 PM
    Just saying from the manual.
  11. Sep 18, 2024 at 2:39 PM
    Spare Parts
    Southern Maine
    22 LR ORP
    How can they say equal wear with the 2nd diagram? The drivers side new get a break, unlike the passenger
  12. Sep 18, 2024 at 2:41 PM
    That's probably just to make it dummy-proof, in case anyone would install directional aftermarket tires.
  13. Sep 18, 2024 at 2:49 PM
    Beats the shit out of me. Looks like its a Limited problem.
  14. Sep 18, 2024 at 3:00 PM
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    2023 TRD Pro Ice Cap
    Use the correct TQ per owners manual
    Hank69[OP] likes this.
  15. Sep 18, 2024 at 3:30 PM
    Spare Parts
    Southern Maine
    22 LR ORP
    That’s what I was thinking, I’m not running 20s so it doesn’t matter. :D
  16. Sep 18, 2024 at 4:24 PM
    Rotating is overrated. I've found 5k mile rotations to be a ridiculous number.
    I'm rotating every 15-20k.
    Got 80k miles out of my last tires.
    Hank69[OP], 3JOH22A and LCJ77 like this.
  17. Sep 18, 2024 at 5:26 PM
    Typically you need a 17"+ breaker bar to loosen lugnuts torqued to 83 ft-lb. What's the problem?
  18. Sep 18, 2024 at 5:38 PM
    Before I got my 1/2" impact I needed to use a breaker on lug nuts as well.
  19. Sep 18, 2024 at 5:53 PM
    True.
    I think it depends on how you're using the breaker bar. If you can break them free by hand with an 18" breaker bar, they are probably fine.
    OTOH. I had tires installed on my ex's TC at a shitty budget tire shop called Mr P's in Milwaukee once, and I had to stand and jump on the breaker bar to free the lugs. I'm not a big guy, but 200# on a breaker bar should be more than enough to loosen a lug nut.
    brownersd and Hank69[OP] like this.
  20. Sep 18, 2024 at 6:01 PM
    Commited
    Commited New Member
    Oscar
    So Cal
    2019 Silver Metallic TRD ORP
    Tinted fronts, blacked out overlays.
    Sometimes simple things are over thought.
  21. Sep 18, 2024 at 6:01 PM
    Technically, that's a Figure 8 patten. It's a good one though.
  22. Sep 18, 2024 at 6:02 PM
    I have a sign on my desk "Hang on, while I over think this."
    Hank69[OP] and Commited[QUOTED] like this.
  23. Sep 18, 2024 at 6:19 PM
    Commited
    Commited New Member
    Oscar
    So Cal
    That’s a good one. I’m gonna remember that one LOL
  24. Sep 18, 2024 at 6:23 PM
    No need to remember, just buy it on Amazon (you can get errrrythang there!)
  25. Sep 18, 2024 at 6:40 PM
    I never thought of it that way. I like to think of it as a Z because it's easier to remember the direction everything is moving.
    Plus, I always think of "In Living Color" and laugh while I'm rotating them.
    https://youtu.be/gxtDvHFc8h8?si=tuqcbWEBoZMrro2N
  26. Sep 18, 2024 at 6:41 PM
    I probably need one of those. :anonymous:
  27. Sep 18, 2024 at 6:42 PM
  28. Sep 18, 2024 at 6:58 PM
    Yep. Front to rear per owner's manual is good enough. Rear tires wear faster because the vehicle is RWD most of the time.
    Any other reason for uneven wear on any individual tire would be caused by alignment or pressure being off, in which case you should correct that defect rather than trying to subject other tires to the bad condition.
  29. Sep 18, 2024 at 7:00 PM
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    Men on Films & Homey the. Clown were funny!!!
  30. Sep 18, 2024 at 7:31 PM
    Spare Parts
    Southern Maine
    22 LR ORP
