Correct metal filter housing for 2024 SR5
Discussion in '5th Gen 4Runners (2010-2024)' started by craftech, Mar 2, 2024.
  1. Mar 2, 2024 at 1:59 PM
    craftech
    craftech [OP] New Member
    Hi everyone,
    Bought a Brand new 2024 4Runner SR5 this week. Super excited. Drove 400 + miles home from the dealer and want to change oil at 500 miles.
    1. Should I also change the filter?
    2. If so the metal filter housing replacement some are recommending Toyota #15620-31060 doesn't fit the 2022 - 2024 4 runner according to the Toyota websites I have tried. So what is the correct part number?
    3. I would probably stick with the plastic one, but I am a lot more careful than most mechanics I have encountered and THAT is the concern with substituting a metal one.
    Thanks for the advice.
    Regards,
    kolter45 likes this.
  2. Mar 2, 2024 at 2:20 PM
    Startrek
    Startrek New Member
    I wonder what Japanese Toyota engineers think, when they put plastic housing instead of metal?
    Tama1968 likes this.
  3. Mar 2, 2024 at 2:34 PM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Stick with the Plastic one, it's just better.
    obxbird, kolter45, 2016Pro and 5 others like this.
  4. Mar 2, 2024 at 2:45 PM
    craftech
  5. Mar 2, 2024 at 2:48 PM
    2019 TRDP w/Kangs brah!
  6. Mar 2, 2024 at 3:09 PM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    I have the metal housing sitting in a drawer. It's kind of a solution searching for a problem IMO.
    If you do go that route, don't forget to swap out the spring and center tube from your stock, plastic housing. There really isn't a "correct" PN for a metal 4R housing. The tube from the suitable metal housing is a different length and the springs may have different rates.
  7. Mar 2, 2024 at 3:16 PM
    I'd change the filter, but keep the plastic housing.
    I got a cheapo oil filter wrench from O'Reilly's and it works and didn't really have a reason to keep the Motivx one so I returned it.
  8. Mar 2, 2024 at 3:17 PM
    Redwood
    Redwood New Member
    2022 4Runner TRD Off Road
    Lots of posts/videos on this. 15620-31060 is the correct part # it's just not spec'd for the 4runner 4.0 which is why toyota websites say it's wrong. It is an OEM part on other models. It works fine you just need change over the filter support tube and spring from your plastic housing. That said as long as you don't overtighten the plastic one and have a proper fitting oil filter housing wrench the plastic housing works just fine. I have one of the metal housings on a shelve just in case. So far so good on my '22 multiple oil changes later. But I don't let any one but myself touch my truck and that includes the dealer unless it's warranty.
  9. Mar 2, 2024 at 3:31 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    2Toys likes this.
  10. Mar 2, 2024 at 3:31 PM
    Old goat
    Old goat Trout chaser
    Hudson Valley NY
    5th gen
    130k with my original plastic one…do all my own wrenching. Never felt a reason to…
  11. Mar 2, 2024 at 4:47 PM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited
    OME Nitrocharger struts and shocks. OME 884X front springs, OME 889X rear springs, full RCI skids, RCI roof rack, RCI sliders with kickouts, Method Racing MR306 Mesh wheels.
    "This expands and contracts at the perfect rate for the heat cycles that this engine goes through, the O-ring seal is just the right size to mate the plastic and metal surfaces together, and it doesn't need to be extraordinarily tight to seal. But some stupid American is going to think they are smarter than us and put a metal one on. And from Amazon! Hahahahahaha!" -That's probably something close to what they think.
    brownersd, kojak, glwood54 and 2 others like this.
  12. Mar 2, 2024 at 5:09 PM
    craftech
    What great responses. That you all so much for that.
    I'll stick with the plastic housing and use one of my cap wrenches (I have every size). If for some reason it doesn't seem adequate (unlikely) I'll get the Motivx.
    Ripper238 likes this.
  13. Mar 2, 2024 at 5:29 PM
    agreed on the “no one touches my car”. I have a 2011 SR5 with 167k and still has the original plastic housing. Cant even count how many oil changes Ive done. I did however buy a new backup oem housing just incase. It’ll fit my 2022 as well so all good.
    oh and only torque to 18 ft lbs per housing instructions. :)
    Redwood[QUOTED] likes this.
  14. Mar 2, 2024 at 5:31 PM
    and dont forget, they’ll use an impact gun as well. Lol!
    Daddy83 and icebear like this.
  15. Mar 2, 2024 at 5:34 PM
    catbrown357
    Tempe
    2011 Limited
    Spend a little money and buy the correct cap wrench. I too thought I had the correct one starting out, and I learned the hard way when it rounded off the filter housing. Recommend the MotivX PN MX2320 and the MotivX drain tool PN MX2341. The drain tool makes draining the filter housing really easy and clean.
    • [​IMG]
    Roll over image to zoom in
    • [​IMG]
    • [​IMG]
    • [​IMG]
    • [​IMG]
    Visit the Motivx Tools Store
    435 ratings
    100+ bought in past month
    $54.95$54.95
    Or $10.15 /mo (6 mo).
    Select from 1 plan
    Or $18.32/month for 3 months on your eligible Citi credit card, with 0% promo APR
    Brand Motivx Tools
    Item Package Quantity 1
    Head Style Hex
    Finish Type Anodized
    Operation Mode Mechanical
    About this item
    • This is a bundle package containing both the Motivx Tools cartridge style oil filter wrench and oil filter drain tool for Toyota and Lexus vehicles.
    • Included are the Motivx Tools MX2320 oil filter wrench and MX2341 oil filter drain tool. These tools are for use on 2.0L - 5.7L engines that use the new cartridge style oil filter system. They do not work on standard spin-off style oil filters.
    • Works on many late model Sienna, Tundra, Highlander, Camry, RAV4, Tacoma, Sequoia, Avalon, Corolla, FJ Cruiser and Venza Toyota vehicles.
    • Includes a Toyota oil filter wrench for removing the oil filter housing cap and a oil filter drain tool for draining the filter housing before removing.
    Gen-V likes this.
  16. Mar 2, 2024 at 6:04 PM
    craftech
    Thanks for the explanation. I just ordered the set. And the looks are pretty neat as well for a filter wrench. ;)
    catbrown357[QUOTED] likes this.
  17. Mar 2, 2024 at 6:13 PM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    I have a plastic housing. 13 years, never had a problem . The Toyota engineers knew what they were doing.
  18. Mar 3, 2024 at 7:28 AM
    Old goat
    Hudson Valley NY
    5th gen
    Don’t forget to put anti-seize on all your skid plate bolts every oil change…
  19. Mar 3, 2024 at 8:06 AM
    That's a good set, a lot of folks went with that. I took a different road, in case someone else finds this thread and is interested in an alternative. I like this one due to the slots in the filter housing tool that notch around the filter housing 'ridges', and doesn't rely solely on grabbing the body (which it does also):
    $42 for the pair.
    I also stayed with the oem plastic filter housing.
    McSpazatron likes this.
  20. Mar 3, 2024 at 8:13 AM
    catbrown357
    Tempe
    2011 Limited
    That's interesting. I have an older version of the MotivX, same part number, and it DOES have the slots in it like this one. I agree, those slots are a definite acknowledgment of positive engagement on the filter housing.
  21. Mar 3, 2024 at 9:20 AM
    I wouldn't bother with that hose the oil filter from dealership comes with little tubes that pop into the oil filter to drain remaining
    Unless you're an autist and can't afford to drop a single drop of oil that little plastic pop in tube works great
  22. Mar 3, 2024 at 9:40 AM
    Not telling the OP what to go with, just letting him know what’s available. He can decide. One member on here had that plastic oil drain tool that comes with the filter break off in the housing.
    catbrown357 likes this.
  23. Mar 3, 2024 at 6:38 PM
    Startrek
    Startrek New Member
    We all know that plastic drain tube that comes with filter, splashing oil around.
    Some people (me) attach piece of hose to that plastic drain tube to drain oil lower to oil collecting bin to prevent splashing oil. It is 5/8 garden hose approximately 10" long. Others (earlier me) use 16 oz hard plastic Cola bottle (empty) with same plastic drain to collect oil. Many others just buy aftermarket.
  24. Mar 4, 2024 at 3:51 PM
    Redwood
    Redwood New Member
    I have literally done thousands of automotive oil changes in my career. I look at the plastic pop in piece for draining the housing that comes with the filter and go "Meh" and toss it. It's a messy job no matter how you slice it. Why complicate it.
  25. Mar 4, 2024 at 4:03 PM
    catbrown357
    Tempe
    2011 Limited
    It's pretty nice using the MotivX screw in tool. I can release the oil when I'm damn good and ready. No mess whatsoever.
    Guppy1301 likes this.
  26. Dec 9, 2024 at 11:40 AM
    4Overlander
    4Overlander New Member
    2024 4Runner ORP KDSS
    I personally wouldn’t go with the metal housing that is made for the wrong filter size A1 instead of A5 and then modify the inner tube in the hope that it’ll be fine. That makes little sense to me.
    Instead I would go with the housing from Lexus:
    Part # 1562031050 replaces 15620-31050
    which I found by searching which Lexus do use the same filter size A5: 04152-YZZA5 as the 4Runner and found the oil filter housing for that Lexus.
    Many times Lexus models have the same but upgraded parts of Toyota models, such as metal instead of plastic to save costs on Toyota’s.
    Now, at least I know for sure that I have a metal housing that is made for the same oil filter, thus the correct size filter.
    Next is to verify that the inner tube can be swapped, because the pressure conditions in Lexus model engines maybe different than for 4Runner engine (see The Car Care Nut YouTube channel that explains this in details).
    Note that this Lexus part 15620-31050
    is different than the Toyota that everyone suggests 15620-31060 although close it’s not the same. And I note that Toyota and Lexus share a lot of parts and when they do, they use the SAME part numbers. So these 2 parts are DIFFERENT otherwise they would have use the same part number.
    I will pursue my hypothesis, and search and posts updates later.
    danfiveoh and Oscar like this.
  27. Jul 16, 2025 at 11:42 AM
    Oscar
    Oscar New Member
    2022 Lime Rush TRD Pro
    Any update 7 months later?
  28. Jul 16, 2025 at 12:01 PM
    Swapped back to plastic in March and couldn't be happier.
  29. Jul 16, 2025 at 12:06 PM
    I rounded off the nubs on the plastic housing using the wrong filter wrench.
    I made the switch to the metal housing because it was less expensive than the ungodly amount they charge for the plastic one. I guess I like to live dangerously.
    Anyways, been using it for 100k miles now. Oil analyses are clean AF.
    andrewtheadventurer and 2Toys like this.
  30. Jul 16, 2025 at 12:14 PM
    kolter45
    Denver
    Inferno Pro & BRM Sport
    I have the alum one for when the plastic one may shit the bed but I don’t think I’ll replace the plastic one unless necessary
