Cornfed Suspension lift & leveling kits
Discussion in '5th Gen 4Runner Parts Marketplace (2010-2024)' started by 2016 4Runner SR5, Aug 31, 2023.
  1. Aug 31, 2023 at 4:54 PM
    2016 4Runner SR5
    2016 4Runner SR5 [OP] CONTACT ME FOR CORNFED LIFT SPACERS 631-202-8245
    #Rensing Off-Road
    North Carolina
    4th gen & 5th gen 4Runner Cornfed Suspension kits are made in America and ready to ship anywhere! All listed pricing includes priority shipping within the US. Kits work with XREAS, KDSS, and TRD Pro models! I am an independent vendor for Cornfed Suspension. All advertised pricing is through me directly. To place your order, please PM, call, or text 631-202-8245 Installation is also available for anyone in the Mooresville NC area.
    1/2" rear $59
    3/4" rear $69
    1" rear $79
    1.5" rear $89
    2" rear $99
    3/4" front $49
    1" front $59
    1.5" front $69
    2" front $109
    1" front 1" rear $119
    1.5" front 1/2" rear $129
    1.5" front 1" rear $139
    1.5" front 1.5" rear $149
    2" front 1" rear $179
    2" front 1.5" rear $189
    2" front 2" rear $199
    2.5" front 1.5" rear $209
    2.5" front 2" rear $219
    3" front 2" rear $229 NOT FOR USE WITH TRD PRO SUSPENSION
  2. Sep 29, 2023 at 9:04 AM
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    4th gen & 5th gen 4Runner Cornfed Suspension kits are made in America and ready to ship anywhere! All listed pricing includes priority shipping within the US. Kits work with XREAS, KDSS, and TRD Pro models! I am an independent vendor for Cornfed Suspension. All advertised pricing is through me directly. To place your order, please PM, call, or text 631-202-8245Installation is also available for anyone in the Mooresville NC area.
    1/2" rear $59
    3/4" rear $69
    1" rear $79
    1.5" rear $89
    2" rear $99
    3/4" front $49
    1" front $59
    1.5" front $69
    2" front $109
    3" front 2" rear $229 NOT FOR USEWITH TRD PRO SUSPENSION
  3. Oct 22, 2023 at 5:08 AM
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    1/2" rear $59
    3/4" rear $69
    1" rear $79
    1.5" rear $89
    2" rear $99
    3/4" front $49
    1" front $59
    1.5" front $69
    2" front $109
  4. Nov 25, 2023 at 4:38 PM
    Diggs9
    Diggs9 New Member
    Keith
    wheels. tires, lift
    just ordered the 2"/1" for my 5th gen
  5. Nov 25, 2023 at 5:04 PM
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    Your order was through the website which isn’t me. Glad you chose Cornfed product either way.
  6. Nov 27, 2023 at 8:17 PM
    limitededition
    limitededition New Member
    Chris
    Dripping Springs, TX
    2019 ORP
    Do these kits help reduce the front-end nose dive on stock suspension?
  7. Nov 27, 2023 at 10:00 PM
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    Yes they do.
  8. Dec 4, 2023 at 1:47 PM
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    1/2" rear $59
    3/4" rear $69
    1" rear $79
    1.5" rear $89
    2" rear $99
    3/4" front $49
    1" front $59
    1.5" front $69
    2" front $109
  9. Feb 29, 2024 at 2:35 PM
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    1/2" rear $59
    3/4" rear $69
    1" rear $79
    1.5" rear $89
    2" rear $99
    3/4" front $49
    1" front $59
    1.5" front $69
    2" front $109
  10. Feb 29, 2024 at 2:53 PM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    They do? How so? With this kit, the same shocks and springs are used. As an Engineer I should understand this but I'm at a loss how this is possible.
  11. Feb 29, 2024 at 7:01 PM
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    Geometry changes of the upper and lower control arms change the way the vehicle rides. anything over 1” uses an internal spacer which adds preload to the coil. This also changes the way the vehicle rides. Stock suspension is extremely soft and mushy. Adding the internal spacer slightly firms up the front suspension and improves ride quality.
  12. Feb 29, 2024 at 7:25 PM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    So this preload is the increased distance between the UCA and LCA? Does this mean suspension travel is now less than OEM? Thanks.
  13. Mar 1, 2024 at 3:48 AM
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    You're not changing the overall length of the shock in terms of travel. You’re essentially changing the rest position of your shock meaning the shock rod is further out of the shock body at the rest position. Same goes for the rear. Spacer sits on top of the coil spring. This does change down travel as your shock is your limiting factor.
    There are different spacer designs. With a spacer that sits on top of the strut up front, a 1.5” thick spacer yields 3” actual lift. This does change the overall length of the strut. This style spacer can cause issues with bottoming the shock out of you don’t add longer bump stops to limit up travel. That is not how these spacers are designed for that very reason. The Cornfed design also rides significantly better than the thick spacers that sit on top of the strut.
    MeefZah and ThatOneGuy like this.
  14. May 20, 2024 at 11:00 AM
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    All kits in stock ready to ship! PM, call, text 631-202-8245
  15. Jul 12, 2024 at 6:08 PM
    Klinsman55
    Klinsman55 New Member
    K
    Northern Nevada
    2024 LE silver
    XREAS. Cooper Discoverer Road and Trail AT 255/75r17. Trd Pro Wheels
    what exactly does a cornfed suspension or leveling kit do for the vehicle?
    I have a 24 Limited and about to put 255/75r17, ive seen other LE with bigger tires and no lift and looks like not much room left in wheel well. Dont want to do a new suspension yet b/c my XREAS is new and enjoying it. Thinking maybe 1/2-1” in front only just to maybe decrease rake a little and more room for tire.
    - does it add ground clearance?
    - will my ride get stiff?
    - will my suspension travel decrease offroad?
    - decrease mpg?
  16. Jul 13, 2024 at 3:32 AM
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    - does it add ground clearance? Yes
    - will my ride get stiff? No
    - will my suspension travel decrease offroad? No
    - decrease mpg? No, you will decrease MPG with your larger heavier tires though.
    Klinsman55[QUOTED] likes this.
  17. Aug 15, 2024 at 11:37 AM
    gottmituns
    gottmituns New Member
    2006 SR5
    Would a 3/4 or 1inch be preferable on a stock 4th gen with oem size tires. Xreas swapped to oem size kyb. Looking to add a bull bar and avoid front end sag.
    2016 4Runner SR5[OP] likes this.
  18. Aug 15, 2024 at 8:13 PM
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    Bull bar weighs nothing and won’t cause sag. Usually 1.5” is ideal for leveling a 4th Gen. picture below for reference.
  19. Aug 28, 2024 at 3:43 PM
    meats
    meats New Member
    Broken Arrow, OK
    2018 Magnetic Gray TRD OR
    2/1 Cornfed Leveling kit Sway Bar Delete 285/70/17 - Arroyo Tamarock M/T
    I need that 2/1 kit
  20. Aug 28, 2024 at 5:37 PM
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    Thanks for reaching out!
    Anyone looking for a kit can reach me
    any time 631-202-8244
  21. Sep 2, 2024 at 9:05 AM
    MT hunter
    MT hunter New Member
    Looking into 3/2 inch for 2023 4 runner. Went to your website but not listed?
  22. Sep 2, 2024 at 9:28 AM
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    Contact me directly 631-202-8245. The website is not mine. I am an independent dealer.
  23. Sep 5, 2024 at 4:44 PM
    danno1948
    danno1948 New Member
    Dan
    Ocala FL
    2021 4runner
    pretty much stock except wheels /tires leveling kit
    Chris, I have a 2024 TRD Pro and wanting to just level it, what kit do i need to get from you to get it level Thanks Dan
  24. Sep 5, 2024 at 5:50 PM
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    3/4” front kit. Please text me. 631-202-8245
  25. Nov 6, 2024 at 2:53 PM
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    1/2" rear $59
    3/4" rear $69
    1" rear $79
    1.5" rear $89
    2" rear $99
    3/4" front $49
    1" front $59
    1.5" front $69
    2" front $109
    MeefZah likes this.
  26. Mar 22, 2025 at 10:15 AM
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    1.75” front 1” rear 265/70/17
    MeefZah likes this.
  27. Mar 28, 2025 at 12:16 PM
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    2” front 1.5” rear. Tires are 266/70/17
  28. Feb 6, 2026 at 4:40 PM
    Gravel
    Gravel New Member
    SR5 4x4
    Shout out to Chris for great service. I ordered a 2/1 kit for my 2022 SR5 and somehow messed up the delivery address with the help of PayPal. Chris kept in touch and made sure I found my kit (at an address I left 15 years ago) and I got it in hand the day after it was delivered to the wrong address.
    Highly recommend buying from him, he’s a good man!
  29. Feb 7, 2026 at 6:19 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    The 5th gen 4R kits also work on the GX460 w/ KDSS (as long as you keep it reasonable in height no tinkering with the GX's KDSS is required). This is a 1.5" front and 1" rear setup which allows clearance to run 255/80 17 pizza cutters (33.2") and has proven to be reliable and comfortable over 2 years and 25,000 miles of mixed use. Cornfed is a great shop. Can't speak to this particular vendor as I haven't used him - but his forum presence makes him seem very responsive and well-versed on the product and had I not ordered direct from Cornfed (before I found this thread) I absolutely would have used him.
