Coolant tubes?
Discussion in '2nd Gen 4Runners (1990-1995)' started by 2ndgenFrank, Oct 29, 2021.
  1. Oct 29, 2021 at 3:08 PM
    2ndgenFrank
    2ndgenFrank [OP] New Member
    1994 4runner
    I recently just joined and I know I might asking a lot already to try and find out what tubes these are. I'm looking to replace these because I'm not comfortable driving with my pipes looking like that and while I'm there I going to place any coolant line also just for the peace at mind. IMG-6364.jpg IMG-6364.jpg IMG-6362.jpg
  2. Oct 30, 2021 at 1:31 PM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    Yours look much worse than mine. I did spring a leak in one once at the very end of the longer hose and could not find a replacement so I cut it and was able to stretch it to fit. Good luck in your search.
  3. Nov 1, 2021 at 10:54 AM
    2ndgenFrank
    1994 4runner
    Yeah I'm finding out the search for those tubes are going to be a pain.
  4. Nov 3, 2021 at 6:19 AM
    Probably could get something made. They don't look all that complicated. For cheap, I would probably use coolant junctions from another automotive application. There seems to be a lot out there.
  5. Nov 7, 2021 at 12:35 PM
    ZARTT
    ZARTT New Member
    Art
    1995 4Runner, Black,Tan Interior, 5spd.,(convert from A340) 207,000 mi., on its 3rd 3VZE.
    Ford Taurus 2 spd. elec. cooling fan, GM CS-144 alternator upgrade. Intimidator AGM battery.
    Quote "I might asking a lot already to try and find out what tubes these are."
    Hi:
    There are a couple of sites that are pretty good at guiding you toward obsolete part numbers, as long as you input the VIN, or the frame, and model number of the vehicle.
    The vehicle numbers were put in different places according to the year of manufacture.
    On the car you are describing, the numbers are posted on a sticker located on the rear side of the drivers door jamb.
    The VIN will have the 17 digit format JT3VN39W2S02XXXXX, and frame and model # will have a format similar to VZN130L-GKMGEH.
    The sites are www.PartSouq.com and www.Amayama.com.
    The sites seem to use the same microfiche that the dealers used back in the day.
    Good Luck.
    Art.
    oilcooler likes this.
  6. Nov 12, 2021 at 8:51 AM
    Shibrew
    Shibrew New Member
    Cody
    87 4Runner SR5
    5vz swap, OME,
    Hey Frank,
    I've got an 87 that i pulled the 3.0L out of and did a bunch of research on the heater plumbing. Here's the info you're looking for looks like you have a rear heater in your rig:
    Also looks like someone has changed out a couple of the heater tubes already. Your best bet for the metal pieces is robbing them off another 3.0l. I do think the 3.4 have some that are very similar so you might be in luck there?
    https://parts.springhilltoyota.com/...-CONDITIONING---WATER-PIPING/671440-8716.html
  7. Nov 16, 2021 at 8:06 AM
    watermelonman122
    watermelonman122 New Member
    Utah
    1994 4Runner SR5 3.4 V6 4wd 5spd
    Your best bet would definitely be going through Toyota parts. Shibrew's got the diagram from their site. They will be the perfect length and shape. A little pricey, but worth it to save the headache. If your heater hoses look like that, there's a few other coolant hoses that you'll wanna take a look at. I just replaced all of these on mine.
    -One at the back near heater hoses but towards the centerline of the car. It makes a nice U shape.
    -There's two on the underside of the throttle body, one coming in and one going out.
    -Down on the bottom of the engine on the driver side, there's two more. They go to the engine cooler. One that's a little U-bend that is a bitch to get at and another long on that goes to the thermostat housing.
  8. Dec 5, 2021 at 6:38 AM
    Tonyota
    Tonyota New Member
    96 4runner and 95 4runner
    Too many for this space.
    Let me know if you don't find what you're looking for.
    I have a parts rig that has them.
  9. Dec 29, 2023 at 12:07 PM
    oilcooler
    oilcooler New Member
    sacramento
    1990 4Runner SR5 3.0 Automatic
    towing vehicle for my motorcycles
    hello, i'm trying to replace all of my cooling and heater hoses, but can't find many of the hoses for my 1990 4Runner with 3.0 and rear heater. what do people do it's time to replace these hoses and metal tubes?
    Trehdo likes this.
