Coolant in my exhaust
Discussion in '3rd Gen 4Runners (1996-2002)' started by Phillyphil, Dec 4, 2024.
  1. Dec 4, 2024 at 7:12 AM
    Phillyphil
    Phillyphil [OP] New Member
    97 third GEN 4Runner v6
    My mechanic recently replaced the valve cover Gaskets. He had to remove throttlebody Portion of manifold along with the valve covers During the job. Now when I start the motor tons of white smoke coming from exhaust mechanic thinks it’s due to vacuum leak causing coolant to get into exhaust. Any help would be appreciated.
  2. Dec 4, 2024 at 7:36 AM
    andrewtheadventurer
    White smoke with a coolant smell seems like head gasket to me
  3. Dec 4, 2024 at 7:44 AM
    Phillyphil
    I thought the same thing too, but no coolant in oil pan when checking dipstick.
  4. Dec 4, 2024 at 8:13 AM
    Lost Woods
    Lost Woods New Member
    Coolant is a 100% closed system so if it's leaking anywhere, it's a problem. It's not uncommon to have some residual coolant after repair that dries in the exhaust that can smoke briefly on startup when it mixes with condensation but that should be very temporary. You shouldn't be seeing it after a few days and a hundred miles.
    Head gasket leaks can be any mix of oil passages, coolant passages, the combustion chamber, and external leaks... no coolant in oil doesn't mean it's not leaking into the combustion chamber. You can check the coolant for hydrocarbons to verify that kind of leak.
  5. Dec 4, 2024 at 8:48 AM
    Phillyphil
    So replacing valve cover, gaskets along with manifold gaskets Pictured below can Cause problem… engine was running fine with no coolant in exhaust
  6. Dec 4, 2024 at 9:41 AM
    Lost Woods
    No, valve cover and most intake manifold gaskets won't cause that, I saw head gasket without coffee yet so went that direction. Sounds like you have a second issue unrelated to what they did.
  7. Dec 4, 2024 at 10:07 AM
    Phillyphil
    Thanks for the help. Is there anyone else that has any ideas on what can be causing this issue after replacing golf cover gaskets??
  8. Dec 4, 2024 at 11:31 AM
  9. Dec 4, 2024 at 12:13 PM
    Phillyphil
    OK, thanks for the scoop…. vehicle won’t idle on its own and will putter out if not applying gas…. when applying gas tons of white smoke from exhaust pipe, along with antifreeze dripping from exhaust pipe…
  10. Dec 4, 2024 at 4:44 PM
    maxthebird
    maxthebird New Member
    1998 red 4runner
    There are 2 coolant lines and a vacuum line connected to throttle body. When I removed mine, I was sure to not mix them when re-installing. Any chance they were mixed up?
    Scubaman0044, ghbucky and Bluesky 07 like this.
  11. Dec 4, 2024 at 5:01 PM
    Phillyphil
    thanks for the scoop…. I think you might’ve nailed it….going to check into it tomorrow.
    OK you called it….. The coolant and vacuum lines were switched out…. Thanks a lot for the Advice Definitely appreciate it….
  12. Dec 6, 2024 at 7:04 PM
    This is one reason why I prefer ONLY using TOYOTA preformed OEM hoses.
    People use cheap generic hose and bend it around and get things switched.
    The TOYOTA OEM molded hoses can NOT be confused. They go very directly exactly where they need to.
    andrewtheadventurer likes this.
  13. Dec 6, 2024 at 7:11 PM
    andrewtheadventurer
  14. Dec 6, 2024 at 9:59 PM
    that'smy4runner
    that'smy4runner New Member
    Time for a new mechanic. :eek:
  15. Dec 7, 2024 at 6:13 AM
    Impractical buy
    Impractical buy New Member
    Windy City (ish)
    2015 Limited
    Well, he wasn’t wrong……
    It was vacuum related.
  16. Dec 12, 2024 at 8:37 PM
    that'smy4runner
    But he did it lol...
