Constant weak honking/horn beeping, doesn’t start, key fob in-op
Discussion in '5th Gen 4Runners (2010-2024)' started by jjgandarillas, Nov 15, 2023.
  1. Nov 15, 2023 at 12:27 PM
    jjgandarillas
    jjgandarillas [OP] New Member
    2016 Grey 4runner
    Custom leather interior professionally installed, JBA high caster UCA, 3” lift unknown, 33” tires
    I once again am asking the community for help,
    my 2016 SR5 4runner has a low power honk about every 1 second, every time it honks it also lights up the dash very faintly,
    The key fob does not work,
    The truck will not turn over at all,
    When the key is turned on the honking stops but the truck doesn’t do anything.
    I have heard it’s possibly the coil spring for the airbag,
    Also heard it might be the auto start installed,
    There is a lost forum stating a relay somewhere is bad. Please help
  2. Nov 15, 2023 at 12:31 PM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    If you have an aftermarket auto start, that's where I would begin.
    kolter45, Slopemaster and Rocko9999 like this.
  3. Nov 15, 2023 at 1:19 PM
    whatsinaname
    whatsinaname New Member
    2023 Blizzard Pearl Limited
    Have you checked your battery to make sure it is holding a charge? Had one die on my F-150 a couple of years ago and it was doing some strange things. Every symptom you listed could be the result of a bad battery.
    Crank_Mancastle and 08TXRunner like this.
  4. Nov 15, 2023 at 2:09 PM
    jjgandarillas
    2016 Grey 4runner
    I’ll give it a check, never hurts to go the cheapest route first. I kind of doubt it but I won’t rule it out.
  5. Nov 15, 2023 at 8:30 PM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    Whatsinaname is right. A bad terminal/ground connection, bad battery or charging system can cause all kinds of weird shit.
  6. Nov 15, 2023 at 8:36 PM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    I would conduct a comprehensive inspection for rodent damage.
  7. Nov 16, 2023 at 6:31 AM
    Disconnecting an aftermarket auto start would be the cheapest route.
    kolter45, 5thToy and 08TXRunner like this.
  8. Nov 20, 2023 at 6:50 AM
    jjgandarillas
    2016 Grey 4runner
    Sorry for the late reply, for all who were curious, I had to “reset” the auto start. Disconnected the battery overnight and the problem resolved itself the following morning. Very odd
    Harringbr99 and 2Toys like this.
  9. Nov 20, 2023 at 8:14 AM
    Remote start strikes again. Glad you figured it out.
    jjgandarillas[OP] and 2Toys like this.
