Console Safe Combination not working - currently storing locked air
Discussion in '5th Gen 4Runners (2010-2024)' started by Co-Star, Mar 3, 2022.
  1. Mar 3, 2022 at 3:44 PM
    Co-Star
    Co-Star [OP] New Member
    2022 Lime Rush TRD Pro
    Alas, I set the 4-digit combination of the port added console safe and closed it. Then tried to open it and the combination doesn’t work.
    Anyone know how to free the trapped air that is currently safely locked away? There’s nothing else in it
  2. Mar 3, 2022 at 4:01 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    I would recommend trying again and rotating each number +1 or -1 with each try.
    So if your code is 1234 try...
    1234
    2234
    0234
    1334
    1134
    Etc... bet ya its one off. Unless you spun it and closed it. Good luck!
  3. Mar 3, 2022 at 4:08 PM
    JaSC
    JaSC New Member
    Anderson, SC
    Black 2018 4Runner TRD Off Road Premium, crawl control and MTS
    ToyTec Lift, Dual Batt Redarc. Rear safe drawer, console safe, Aux 2004 JGC fuse box, Warn bumper, 12,000lb winch
    Is it the OEM model? I have one. it has combo and a key. I had my firearm in the safe while at a restricted area and found that neither combo or key was working when I was ready to leave and this after a year of owning/using. Ended up breaking into it. Fairly easy. Eventually I'll chunk it.
    Wanted to add that it was a mechanical issue not a matter of combo not working. Entire mechanism was frozen more or less.
  4. Mar 4, 2022 at 3:54 AM
    ZackDanger
    ZackDanger New Member
    Western MA
    I once accidentally set a combo lock with one wheel halfway between two numbers… like 0 - 0 - 0 - 0.5
    I got real lucky figuring out what happened.
  5. Mar 4, 2022 at 6:18 AM
    Co-Star
    No key.
  6. Mar 4, 2022 at 7:53 AM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    Did you try 0000?
    I bought a console vault that looks just like that. IIRC to set the new combo, you put a paperclip through the hole on the side of the wheel, set the new combo, then remove the paperclip.
  7. Mar 4, 2022 at 8:39 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Man, those quarters must be a bitch to get out
    DRobs, McSpazatron and newlife like this.
  8. Mar 4, 2022 at 10:18 AM
    TrailGuy2016
    TrailGuy2016 New Member
    2016 Trail Premium, Silver
    I saw that also!
  9. Mar 4, 2022 at 10:31 AM
    K-Paul
    Corbin Dallas
    SR5 4WD
    id LOVE to have this in my Runner. What year did they start including this feature?
  10. Mar 6, 2022 at 4:46 AM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
