Compressor Location Ideas
Discussion in '5th Gen 4Runners (2010-2024)' started by crashdb, Feb 4, 2025.
  1. Feb 4, 2025 at 7:47 AM
    crashdb
    crashdb [OP] How Did I Get Here?
    Dave
    Manassas, VA
    2022 TRD-OR-P
    Little Tree Air Freshener
    All the usual locations under the hood are taken up by other things. I thought one of the two kits that mount it behind the grille, but have concerns about the location during various activities. It's still an option though. Ideas welcome here, too. I actually think we're down to one company making a behind the grille option now.
    Desert Does It underseat. That area is taken up as well. There's also conflicting information on whether the dual compressor will fit under there. Moot point either way.
    So I've been eyeing the rear cubby. I was curious to see if anyone had done this so I can get some ideas. This won't be something I can take days to mess with. I have to pull out my packed drawers to figure things out. So any ideas to speed the process would be great.
    I've only gotten as far as a universal mount with the possibility of adding some very strong magnets. I have a feeling this won't work well because the area behind the plastic isn't flat.
  2. Feb 4, 2025 at 7:55 AM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    Grenadier Trialmaster
    Rock Sliders, Bull Bar
    You didn’t mention the type of compressor you’re using, that might make a difference in how you go about it.
    I’d pass on the magnets, I don’t think I’d trust them.
    I’ve heard of the rear cubby (where the bottle jack is) but never have seen one in person.
    I know you said there’s no room in the engine bay, so you’ve already considered the location by the passenger firewall (sometimes people forget about that one).
    So I’d pursue the bottle jack location.
    Good luck
  3. Feb 4, 2025 at 8:24 AM
    I keep it simple. I have a portable compressor. When its needed I take it out from the bag -> Connect the hose -> Plug in to the 12V battery -> Inflate the tires.
  4. Feb 4, 2025 at 8:39 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    This is the way. I mean, how often are you really using a compressor? This might take a bit longer, but slow down and enjoy the scenery.
    FatChance, Saker and kmeeg[QUOTED] like this.
  5. Feb 4, 2025 at 9:29 AM
    nova
    nova New Member
    mike
    While the OP didn’t mention it, some folks have air lockers. That’s a good reason for on board air :cheers:
    Captain Spalding and Saker like this.
  6. Feb 4, 2025 at 9:42 AM
    crashdb
    Dave
    Manassas, VA
    2022 TRD-OR-P
    That would be helpful, huh? It's an ARB dual compressor.
    As far as under the hood, all the normal places are taken up. The passenger side space has the secondary air pump re-located there so I could relocate the washer reservoir into the space at the front of the engine bay.
    The driver's side area has a switch panel brain thing there.
  7. Feb 4, 2025 at 9:44 AM
    crashdb
    Dave
    Manassas, VA
    2022 TRD-OR-P
    I do that now and after absent mindedly grabbing the compressor after use or burning the carpet on another vehicle, I'm done with the portables.
  8. Feb 4, 2025 at 9:45 AM
    2019 TRDP w/Kangs brah!
    I have been looking as well because my Viair 450P is not up to the task of using my Moreflate Air Hub so I was looking at the ARB twin and where to mount it. I do not like the behind the grill or the under seat mounts. I was looking at Mountain Offroad because it mounts on the passenger side and you can run the ARB tank underneath but really I'm just using it to air up so I may just go with the portable option.
  9. Feb 4, 2025 at 9:47 AM
    crashdb
    Dave
    Manassas, VA
    2022 TRD-OR-P
    That was the mount I had initially wanted. While I don't really need the tank, it'd be nice to have just in case.
  10. Feb 4, 2025 at 12:39 PM
    nova
    nova New Member
    mike
    o_Oo_Oo_O
    Everybody’s hack job is different. My washer tank was in the way, only I went with the Rago tank relocation kit. It was the only thing I could find that allowed me to get my dual ARB mounted by the passenger firewall. My wife objected to the sound of the compressor so the under hood location was the compromise. It turns into a bit of a puzzle finding space and fitting it together while still being able to close the hood‍. And yes, the ARB pairs nicely with the lockers :spending:
    crashdb[QUOTED][OP] likes this.
  11. Feb 4, 2025 at 7:58 PM
    2020 Venture / 2017 Tacoma
    Sounds to me like you got too many things going on in the engine bay. This is where I have mine as most use this spot for it.
  12. Feb 4, 2025 at 8:52 PM
    4runnerfromdxb
    4runnerfromdxb New Member
    Driving mostly in the desert, the under the hood space does not make any sense due to sand getting everywhere. I wired mine at the back, above the wheel well on driver side - the "tray" there perfectly fits a single piston arb (got 4 lines setup, so I don't really care if takes 2 minutes more to fill up 34s than a dual piston arb). Thinking about a full size drawer system - I will definitely keep a compartment for compressor where it is now.
    EDIT: I've seen a few installations done under the passenger seat, but this requires at least 1" spacer to offset the seat rails. Many chose this approach too..
  13. Feb 5, 2025 at 4:55 AM
    wingo
    wingo *****
    2020 Venture
    I installed a single air compressor in the cargo area cubby over the wheel well. A single compressor is all I need and is good enough to fill tires and other things that need air.
  14. Feb 5, 2025 at 5:16 AM
    crashdb
    Dave
    Manassas, VA
    2022 TRD-OR-P
    That looks nice. Very clean install.
  15. Feb 11, 2025 at 11:06 AM
    hamsey
    hamsey New Member
    Norm
    Fraction Land
    2024 T4RLE
    @ChessGuy I have a couple of questions. Which mount is that? Where do you have the switch mounted? What did you do with the wiring harness that was mounted to the side? Are the wires long enough to reach the battery terminals along the back and drivers side? Planning on adding a ARB dual on the passenger side and figuring it all out. Thanks!
  16. Feb 11, 2025 at 12:39 PM
    West Coast, Sierra Mountains
    After playing the musical chair game beginning with the usual next to the main fuse box under the hood to passenger side firewall I ended up relocating the washer fluid reservoir, eliminated the fill spout and made a quick release bracket for my ARB single. It’s a tight fit but works great, and I can pull it, plug in a 12V extension cord with battery clips to use independently from my 4R.
  17. Feb 11, 2025 at 4:02 PM
    JakeTheSnak3
    JakeTheSnak3 Whoever.
    Jacob
    Concord, CA
    2023 4runner Trd Pro
    I have had lasfit brand for about 1.5 years now. I am very happy with it. Small, portable, durable. Good quality too. Saves space. Suits MY needs. I am speaking for myself, I would like to point it out, so that nobody will try to eat me for it, like it happened on this site in the past...
    kmeeg[QUOTED] likes this.
  18. Feb 11, 2025 at 8:36 PM
    It has been a while but I can't remember the tray we used on the side where the fuse box is located. But I remember that we did the switch pro from Shqd or Sdhq...one of the two and maybe they gave us the tray where we mounted the compressor. And yes, the connections are long enough that they can get to the battery terminals. This pic might show it.
  19. Feb 11, 2025 at 9:55 PM
    Viair88, perfect fit.
  20. Feb 14, 2025 at 11:17 AM
    hamsey
    hamsey New Member
    Norm
    Fraction Land
    2024 T4RLE
    @ChessGuy Thank you. Most likely going with the M.O.R.E. mount. Seems like the best option for passenger side.
