Cold Air Intake... K&N vs TRD
Discussion in '5th Gen 4Runners (2010-2024)' started by ziva, Apr 2, 2024.
  1. Apr 2, 2024 at 8:41 AM
    ziva
    ziva [OP] New Member
    2014 SR5
    Oi
    Decided to delay all the sick light upgrades and landed on purchasing my first official mod for the 2014 SR5 which will be a cold air intake... Performance over looks, ammirite?
    I wanted to hear some viewpoints, suggestions, and reasoning behind the decision you went with IF you decided to upgrade or even switch from the TRD to the K&N, vice versa.
    Installation struggles/modifications, noticeable performance differences, etc...
    Thanks!
    - Z
    Screenshot 2024-04-02 at 11.38.39 AM.png Screenshot 2024-04-02 at 11.38.56 AM.png Screenshot 2024-04-02 at 11.39.36 AM.png
  2. Apr 2, 2024 at 8:51 AM
    2016Pro
    Don't waste your money, you will get the same performance gains by installing raptor lights or a chrome bull bar (don't do those either)
  3. Apr 2, 2024 at 8:55 AM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    Spend the money at a local strip club; you’ll get more satisfaction.
    Yotaholic, kakwvu, BillyE and 9 others like this.
  4. Apr 2, 2024 at 8:57 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Unless it's sealed, it's essentially a hot air intake. A waste of money. Buy the TRD if you want, because it's sealed and gets air from inside the wheel arch. And, it's engineered by and for Toyota.
    Rocko9999 and ziva[OP] like this.
  5. Apr 2, 2024 at 9:17 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Injen. Is probably the best intake design. Still its only a noise maker.
  6. Apr 2, 2024 at 9:20 AM
    HazOpRed
    HazOpRed 22' TRDOR
    Pls don't get the K&N. In my mind, only two other options exist for air intakes. It is the TRD (because oem and cool factor) and AFE Momentum GT (option for heavier "trail filter", also has an air inlet bypass in the engine bay if needed {sometimes snorkel not happy at interstate speed is what that's for}). Option 3 is to remove the air filter for max engine air flow and Toyota investment $
    ziva[OP] likes this.
  7. Apr 2, 2024 at 9:26 AM
    Neither do anything but add noise but go boxed and a dry filter if you do get one. K&N is garbage.
    You can build the TRD for much cheaper if you search for the thread with part numbers.
    BGH2023, MTBVRF and ziva[OP] like this.
  8. Apr 2, 2024 at 10:39 AM
    Stock airbox is a CAI already.
  9. Apr 2, 2024 at 11:16 AM
    Doodle210
    Doodle210 New Member
    Get a closed box, go for the S&B CAI. Wife and I have it on both our 4runners and it's def worth it. Installation was about 30-45 mins.
  10. Apr 2, 2024 at 11:31 AM
    Why? You aren’t going to notice any differences at all. Invest in a Sherpa roof rack.
    Fu3lC3ll and 2016Pro like this.
  11. Apr 2, 2024 at 11:55 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    IME you'll get no improvement in power. Maybe some additional intake/ induction noise, which is cool I guess if you're into that.
    Most importantly the paper stock filters do a great job at catching dust where the oiled fabric filters do not. The oiled filters can also lead MAF sensor issues if you over-oil the filter.
    And as others have stated the factory airbox is already a CAI that breathes great. An aftermarket one (despite the manufacturer's adverts) will likely have no positive effect on power.
    If you need more power consider a tune.
    These newer cars are calibrated with OEM equipment. Unlike older engines, an intake/ exhaust here (without a tune) can cause you to lose power as the factory ECU will see inputs it does not like/ expect. So changing equipment without getting a tune will likely cause the engine to run less efficiently as the factory fuel mapping and ignition timing are being dictated by what these sensors see, then what the ECU allows. In short, changing the equipment without tuning may do more harm than good.
    2016Pro, Slopemaster and ziva[OP] like this.
  12. Apr 2, 2024 at 12:22 PM
    ziva
    2014 SR5
    Thanks for this info.
    Based on the replies and jokes on the question I'm going to use the money towards a tune instead, unless you think it received a tune a the dealership during its time being traded in & serviced there. No, there is no tune info on my service records either.
    If a tune isn't the best use of my money at this point, then, I guess I'll get the sick light upgrades lol
    2016Pro likes this.
  13. Apr 2, 2024 at 12:35 PM
    Interesting. They even make these for vehicles that don't exist:
  14. Apr 2, 2024 at 12:37 PM
    1SilverRunner
    Tejas
    If you need a little more pep or throttle response a tune is a great way to do it.
    Keep in mind every vehicle is a little different.
    Coming from the sports car world the normal formula was do your mods then get it dyno tuned for those specific mods. Elevation, temperature, load, etc have to be considered when this is done.
    Conversely, I think for these rigs a tune just allows them to be a little more responsive. Better throttle response and a little more low end torque. I don't think many people tune these things to be revved to 6k and squeeze all the horsepower possible.
    Toyota's 1GR-FE is a workhorse of an engine. It's not a powerhouse, but it is incredibly reliable. That's where the magic is at imo.
    Slopemaster likes this.
  15. Apr 2, 2024 at 12:37 PM
    1SilverRunner
    Tejas
    They are made just not sold in the USA sadly
  16. Apr 2, 2024 at 12:50 PM
    ziva
    2014 SR5
    Noted... I appreciate it
    I don't necessarily need more torque or better response but instead want to try and take care of my new obsession as best as I possibly can.
    Coming from never owning a 4x4, Toyota, or even a decent vehicle before, I'm figuring everything out as I go. I thought that a better cold air intake would be a good first step in the overall performance/maintenance of my rig.
    I'll look up more about tuning!
    Thanks again!
  17. Apr 2, 2024 at 12:57 PM
    garoto
    garoto New Member
    I have the TRD and love it. Rather than splitting the wire loom, I opted for a MAF wire extension instead.
    BGH2023 and ziva[OP] like this.
  18. Apr 2, 2024 at 1:27 PM
    Just keep the oil changed and enjoy it. :)
    7Runner, 5thToy, 2016Pro and 2 others like this.
  19. Apr 2, 2024 at 1:42 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    The tunes available for this 4runners cost around $500, kdmax , yotawerx, and ott. Search them on here. It definitely makes a nice difference in the 2000-3500 rpm range. Adds torque sooner so it doesn't take as much effort to get up hills and a improvement in the cruising range of the rpms. Throttle response is also improved. Also slightly improves mpg. Well worth the money imo.
  20. Apr 2, 2024 at 1:42 PM
    catbrown357
    Tempe
    2011 Limited 4WD
    Why? Because it makes more noise? Because you can feel it (not likely)? Tell us how it's definitely worth $350.
    2016Pro likes this.
  21. Apr 2, 2024 at 1:54 PM
    ziva
    2014 SR5
    Thank you!!!
  22. Apr 2, 2024 at 2:24 PM
    FYI, the tunes for 2010-2019 are somewhat less $, as they are less involved than the newer version 4R. At least that was true when I got mine tuned.
  23. Apr 2, 2024 at 2:30 PM
    HotelMedicis
    HotelMedicis No Commercial Interests
    I'm quite sure that you already have a cold-air intake set up just like the rest of us. It comes that way -- stock.
    2016Pro likes this.
  24. Apr 2, 2024 at 2:56 PM
    Doodle210
    It definitely feels peppier compared to stock. Wife had it on hers before I got mine, I could see a difference. Now did I track all of the runs with timing for science? No, because I didn't really care.
    Also, mine wasn't $350. I got it off Mercari from someone who never had the chance to install it on their 4R due to an accident. I managed to get it for $200 shipped ‍
  25. Apr 2, 2024 at 3:42 PM
    wafersmith
    wafersmith New Member
    2018 TRD off-road
    I have had a CAI and tune on Tacoma. Now only tune on the runner. K&N made the throttle feel a little more touchy but other than that no real noticeable gains. Tune has added way more than CAI except sound. Tune adds HP and Torque and smooths out the power over the gears, less downshifting.
  26. Apr 2, 2024 at 4:03 PM
    The FJ was produced for another 9 years after exiting the US market:
  27. Apr 2, 2024 at 4:51 PM
    Sin4R
    Distant land called Timbuktu
    2024 4Runner Limited
    Mall crawling kit.
    I race (not 4Runner), so I am probably one of the few people that properly uses cold air intake that I have on my track car. Let me explain why it matters and in what circumstances. I will simplify and skip over ram intakes and forced induction, as neither would be applicable to a 4Runner.
    When you race, your engine bay gets really hot. This is called heat soak. This does not happen as much under normal driving circumstances. As air density is lower at higher temperatures, at wide open throttle you get less air and consequently can burn less fuel. So if you pipe outside air you prevent heat soak of the engine bay from decreasing peak torque.
    Cold air intake does nothing if: a) you drive at a partial throttle, b) you don’t continuously load engine to the point of heat soaking.
    Just like you won’t get anything out of a spoiler on a Civic or drag slicks on a Miata, you won’t get anything out of cold air intake on a 4Runner. Not the right car for it, not the right driving conditions for it to work.
  28. Apr 2, 2024 at 5:06 PM
    ziva
    2014 SR5
    I wanted to ignore the comment but come on man... no shit. I was asking about an upgrade, either the K&N or the TRD Pro Kit. Thanks for the info though. I'll make sure mine came with it "-- stock"
  29. Apr 2, 2024 at 5:08 PM
    ziva
    2014 SR5
    Interesting.
    Thanks!
    Sin4R[QUOTED] likes this.
  30. Apr 2, 2024 at 6:15 PM
    Go for lights, lift kit or roof rack. We are all just telling you from experience because more than likely one of us bought something we regret. If you go for lights don’t go cheap (you will regret it) aske me how I know. lol. I now have diode dynamics and absolutely love them. I’ve literally submerged them and they stayed on. Roof rack I love my Sherpa. Suspension I like eibach. But continue to ask this community. There are a lot of damn good people on here. We just don’t want you to make the same mistakes we’ve made
    ziva[QUOTED][OP] likes this.
