Code P1613
Discussion in '4th Gen 4Runners (2003-2009)' started by dm101, Jun 27, 2022.
  1. Jun 27, 2022 at 11:48 AM
    dm101
    dm101 [OP] New Member
    2005 4runner Limited 4x4
    Anyone have familiarity with the code above?
    Thanks!
  2. Jun 27, 2022 at 11:54 AM
    I can’t help you out, but welcome to the forum.
  3. Jun 28, 2022 at 9:39 AM
    iamincrediboy
    iamincrediboy New Member
    Central MD
    Google is your friend.
    https://www.autocodes.com/p1613_toyota.html
    https://www.dtcdecode.com/Toyota/P1613
    Means your secondary air injection system (SAIS) is failing, or at the very least (unlikely) theres a loose connection somewhere throwing the code. Few options to fix/bypass the issue:
    1. take to Toyota and have them fix it, between labor and parts somewhere around $3k depending on where you go/pricing it out
    2. @slyfox75 on T4R.org (think hes still active) makes a kit that requires only a bit of splicing of wires within the engine bay, kit is less than $100
    3. https://hewitt-tech.com/ makes a more intricate bypass kit that replaces the SAIS driver itself, blocks off the exhaust bypass tubing, plugs into the wiring harness, and splices into the ECU in the cab. $400
    :cheers:
    AuSeeker likes this.
  4. Jun 28, 2022 at 12:46 PM
    dm101
    I have reset the CEL waiting to see if it goes off again. I was hoping maybe the controllers fail sometimes. Hewitt is out of the second gen and claim 1st gen wont fix my issue/vehicle.
    Wires look fine. Put some dielectric on one of the connectors, may put some on one of the others that I missed and looks a little grimy.
    Truck is running fine except for loss of power from the transmission one time which I suppose is a different issue. Neutral safety switch maybe.
    Havent had the truck long. See what happens next.
  5. Jul 5, 2022 at 9:04 AM
    iamincrediboy
    Central MD
    If you havent reached out to SlyFox on T4R you should do so. He's quite knowledgeable on it all after these years of building his kit alongside the Hewitt folks. He may well know something else not previously mentioned
  6. Jul 12, 2022 at 3:44 AM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    Here's Slyfox's contact info, etc., send Jeff an email, that's the best way to contact him!
    "Slyfox75 AIP/SAIS bypass kit. Bypass = $49 Stainless Blockoff Plates $28(pair) email to jeffcolemaps at gmail for more info or questions. -jeff"
    iamincrediboy[QUOTED] likes this.
