Code 14 nightmare
Discussion in '2nd Gen 4Runners (1990-1995)' started by Jbruce243, Aug 3, 2022.
  1. Aug 3, 2022 at 9:08 PM
    Jbruce243
    Jbruce243 [OP] New Member
    Justin
    1993 Black 4Runner
    Sound system, led light bar, normal maintenance and repairs
    So I recently did a head gasket repair and after getting everything back together code 14 is now popping up with no spark. I made sure timing was done properly to TDC, got new spark plugs, wires, distributor cap and rotor, new igniter, ignition coil and a newer Ecu. I have verified continuity to the igf and igt wires along with testing all the connectors to make sure they are in spec. I’m at a loss right now as to what’s causing this code
  2. Aug 3, 2022 at 10:03 PM
    Did you use TOYOTA coils and igniters?
  3. Aug 4, 2022 at 10:25 AM
    Justthemechanic
    Justthemechanic New Member
    Nevada desert
    94 4Runner SR5, 5 speed, 3.0
    OME 2” lift, BudBuilt armor, RRO sliders, Spartan rear locker
    Here is a copy of the page from the FSM for diagnosing a Code 14. It has the wire diagram and pins at the ECM to check for voltage and ground.
    It also has you check the distributor. The air gap is hard to check unless you have a non ferrous feeler gauge, a standard feeler gage sticks to the magnet. The coils are easy to check, just measure the resistance. A few years back I was getting an occasional Code 14 and it turned out to be low resistance in one of the distributor coils. A new distributor from Auto Zone cured the problem.
