Clicking sound and not starting
Discussion in 'General 4Runner Talk' started by tholroyd, Jan 23, 2022.
  1. Jan 23, 2022 at 6:19 AM
    tholroyd
    tholroyd [OP] New Member
    Trevor
    2020Runner
    My 2020 4Runner has let me down for the first time. I’ve been noticing my display lights surging of late. Ignored it, but yesterday tried starting the truck and it began making a fast clicking sound and wouldn’t start. Shocked, I called for a boost and that got it going, but went to start it later in the day and now battery is completely dead! Only 30K Kilometres. Anyone experience this?
  2. Jan 23, 2022 at 11:58 AM
    PhantomTweak
    PhantomTweak New Member
    Patrick
    OREGON
    1999 4Runner, bone stock
    Could be the battery, the alternator, the wiring between the two, the grounds, the fusible links. Does that help?
    I would check the output of the alternator first, if you can make the truck run. Then, ensure the voltage felt on the alternator, is felt on the battery's positive terminal. Lets you know the fusible link between the two is good or bad.
    I would get both the battery and alternator tested by an auto parts store. Most of them do that free of charge.
    Finally, I would check all the associated wiring, and especially the ground points, are nice and clean, uncorroded, and so forth.
    That's all just what I would do, though. Your mileage may vary.
    Pat☺
  3. Jan 23, 2022 at 1:14 PM
    Mtbpsych
    Mtbpsych New Member
    If it started right up after getting a jump start, bad battery. Check the connections to make sure there’s no unusual corrosion, but if the engine hasn’t died while driving your alternator should be good.
    Easy way to test the alternator though is to unplug the battery while the engine is running, if it dies you have a bad alternator.
    Over on tacomaworld there has been owners who reported that the OEM batteries crapped out after 1-2 years of ownership.
  4. Jan 23, 2022 at 6:36 PM
    It’s worth asking…have you done any mods that rely on electrical? Seems it’s easy for mistakes doing electrical work, or bad parts (even a cheap led light gone bad) is enough to cause crazy problems
  5. Jan 23, 2022 at 7:28 PM
    4R21
    4R21 New Member
    AK
    Land of Cheese
    I have heard of batteries going bad :rolleyes: ! Did ya leave the light on like Motel 6 ? Jk :rimshot:
  6. Jan 24, 2022 at 9:47 AM
    Sixgunz
    Sixgunz Gold Member
    Phoenix
    2022 ORP
    Another vote for bad battery. My Tundra battery didn't make it a full year.
  7. Jan 24, 2022 at 11:17 AM
    PhantomTweak
    Patrick
    OREGON
    I'm not certain about the newer trucks, but I know on first gen trucks you cannot disconnect the battery while the truck is running. It provides the excitation voltage for the alternator. Pull it out of the circuit, no excitation, no voltage out of the alternator. No voltage out of the alt, no running of the truck.
    The later gens may or may not be wired the same, but once Toyota finds a setup that works fairly well, they tend to stick with it through generations.
    Just a heads up.
    Pat☺
  8. Jan 26, 2022 at 8:49 AM
    Sandbuster
    Sandbuster Breaking Wind
    Central Florida
    2019 TRD Offroad
    Spending most of my working life in auto electric I also suspect a battery issue. Although it of course can happen, alternators seldom fail anymore. Many folks make the mistake of taking a voltage reading at the battery thinking if it has 12+ volts it must be okay - not so. Only a battery load test can give you an accurate test of the battery's ability to operate your car.
    PhantomTweak and ElectroBoy like this.
  9. Jan 26, 2022 at 2:02 PM
    DaveW
    DaveW New Member
    dave
    2020 Toyota 4Runner TRD Offroad
    Just recently had my battery replaced on warranty on my 2020 4R TRD OR.
  10. Jan 26, 2022 at 4:31 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    For a quick state-of-charge health check of your battery, check it’s voltage after it’s been resting a while, maybe first thing in the morning.
