Cleaning throttle body, ECU reset required?
Discussion in '4th Gen 4Runners (2003-2009)' started by LongsPeak95, Aug 21, 2022.
  1. Aug 21, 2022 at 4:43 AM
    LongsPeak95
    LongsPeak95 [OP] New Member
    Tampa
    2005 4Runner SR5
    My '05 SR5 has 178k miles, and cold idles around 1000rpm; smoothly and with no hesitation. Acceleration is also quick and smooth. MAFS was just cleaned.
    I was going to clean the throttle body but I've read that, unless the engine runs poorly and/ or gas mileage is poor, it is not necessary. Additionally, resetting the ECU is required.
    Should I go ahead and thoroughly clean the throttle body and, is disconnecting the battery's negative terminal to reset the ECU, necessary?
    Thanks!
  2. Aug 21, 2022 at 3:54 PM
    spencermarkd
    spencermarkd New Member
    Spencer
    Pullman, WA
    2007 Driftwood Pearl SR5
    Not absolutely necessary, but I still would. Taking off the negative terminal for a few minutes will reset the idle learning and your fuel trim levels. Your ECU would eventually adapt on it's own, but it'd be faster IMHO to reset and let it adapt from scratch.
  3. Aug 21, 2022 at 4:05 PM
    LongsPeak95
    Tampa
    2005 4Runner SR5
    Thanks! I wouldn't mind doing that, however, all of the settings on my sound system would also require resetting and that's a pain!
  4. Aug 23, 2022 at 12:37 AM
    akhero
    akhero New Member
    I just cleaned my TB and it idles higher i didn't realize why now I know. How do i reset the ECU? Or should i just disconnect the battery?
  5. Aug 23, 2022 at 3:27 AM
    LongsPeak95
    Tampa
    2005 4Runner SR5
    The videos I have watched and the posts here in cleaning the throttle body say you should disconnect the battery's negative terminal before cleaning it.
    Once you have cleaned and reassembled the throttle body, you reconnect the negative terminal and, after a few miles of driving, your truck's ECU "relearns" and adjusts to accommodate the cleaned TB.
  6. Aug 23, 2022 at 8:53 PM
    akhero
    akhero New Member
    I just did it i need to drive it a little to learn thx
    LongsPeak95[OP] likes this.
