Check Engine Light Solid, Traction Icon Solid, VSC Off Flashing
Discussion in '4th Gen 4Runners (2003-2009)' started by 4R777, Oct 23, 2020.
  1. Oct 23, 2020 at 2:57 PM
    4R777
    4R777 [OP] New Member
    2008 4runner Sport V6
    Check Engine Light (On; Solid)
    Traction Icon (On; Solid)
    VSC Off (Flashing)
    Bad gas cap.
    Step 1
    1. Drove to Autozone
    2. Borrowed their scan tool
    3. Put key in ignition and turned to ACC
    4. Plugged scantool into OBD port and let it scan
    5. When it says 'donE', I unplugged
    6. Took scan tool back into Autozone for worker to readout code
    7. Bad gas cap
    Step 2
    1. Drove to Toyota dealership
    2. Bought new cap for $23+tax (in CA)
    3. Removed old cap
    4. Installed new cap
    Dashboard lights are still on
    Step 3
    1. Disconnect battery
    2. Reconnect battery
    Dashboard lights off
    This is the second time I've replaced my gas cap, so I'm on my third gas cap. However, lights did not go off, even after driving almost 1000 miles. So I disconnected the battery. This also reset my seatbelt warning noise back to default (On), so I had to turn that off again.
    For anyone wondering how to off the seat belt alarm in 4th gen, it's pretty simple.
    https://www.youtube.com/watch?v=T_j3E1c_Fds
    jentb737 likes this.
  2. Oct 28, 2020 at 5:48 PM
    Texas V8
    Texas V8 New Member
    Austin, Texas
    2024 4Runner Limited
    This exact condition appeared today on my 2008 4Runner Sport V8. After doing a lot of searching, a Toyota guy suggested doing the easiest thing first. Test your gas cap by tightening to one click, then untighten. If it easily untightens then it is prolly a bad cap. I tried this and the untighting was weak so it kind of points to me needing a new gas cap. He noted that it may take a little time before the lights go out so suggested I drive the car for several days or a week to see if the lights go out before going to the next step.
    So in your case, I would have to ask, did you allow some time or did you immediately replace the cap?
    nimby likes this.
  3. Oct 28, 2020 at 6:50 PM
    Welcome.
  4. Oct 28, 2020 at 10:06 PM
    4R777
    Ok so apparently you didn't read my initial post. Lol
    Drove 600 miles in last few days and lights are still on. Will be resetting the lights by disconnecting the car battery and see if they come back on.
  5. Oct 29, 2020 at 5:34 AM
    Texas V8
    Texas V8 New Member
    Austin, Texas
    This is the post I read so no, I did not see a reference to 600 miles nor how long you waited between gas caps. Never-the-less, I hope the reset fixes the problem.:cheers:
  6. Oct 30, 2020 at 11:43 AM
    Texas V8
    Texas V8 New Member
    Austin, Texas
    Wanted to do a follow-up. I hooked up my OBDII scanner and got a P0456 code - Evaporator Emission System leak (very small leak). I installed an OEM gas cap and filled the tank once. My friend told me it took 3 fuel-ups for the lights to go out for him so I will report back when the lights go out, or what I end up trying next ;).
    r32, did the car batt reset work?
  7. Nov 1, 2020 at 7:01 AM
    Texas V8
    Texas V8 New Member
    Austin, Texas
    At the risk of chatting with myself I promised a Follow-up:D. I decided to clear the code using the OBDII scanner. Ever since, no lights so guess a simple gas cap change fixed the problem.:yes:
    SlvrSlug likes this.
  8. Nov 2, 2020 at 7:44 AM
    4R777
    Updated original post.
    Driving almost 1000 miles and 3 full tanks of gas, lights were still on.
    Disconnected battery and lights went off.
    Texas V8 likes this.
  9. Nov 2, 2020 at 7:50 AM
    Texas V8
    Texas V8 New Member
    Austin, Texas
    Yeah, I tried doing a reset using the odometer/ignition method but it would not reset. Luckily, I had a code scanner and that reset worked. Probably the same as disconnecting the batt. Glad it worked out for us both :cheers:
    4R777[QUOTED][OP] likes this.
  10. Apr 6, 2025 at 9:12 AM
    jentb737
    jentb737 New Member
    Jent
    2008 Toyota 4Runner
    none
    Thank You 4R777 .... Thank You Very Much ..... my wife failed to install the gas cap correctly after filling up and half of the dash board lite up like a Christmas tree ...... I followed your advice and all of the lights are now back to normal ..... Thank You Very Much .... 4R777 do you fly the B777???... posted by Jent.
  11. Apr 7, 2025 at 11:14 AM
    Ralph Blake
    Ralph Blake New Member
    2008 sr5 4runner
    All that is needed is to clean the fuel caps o-ring and then grease it this will make it seal again, there is no need to keep buying a new fuel cap unless you enjoy making your Toyota Dealer richer.
