charging warning light and tire pressure light both on.....thoughts??
Discussion in '4th Gen 4Runners (2003-2009)' started by DIPA, Sep 2, 2025 at 6:52 AM.
  1. Sep 2, 2025 at 6:52 AM
    DIPA
    DIPA [OP] New Member
    Shawn
    Rhode Island
    2023 Lunar Rock Off Road Premium
    Good morning, out of the blue today both the charging warning light (battery icon) and the low tire pressure light came on. Battery is only a few months old, and I checked the tire pressure, a couple tires were a few pounds low, filled them up to 32 psi. Drove another 15 miles, no change in either light. In case it matters this is a 2007 SR5.
    Everything seems normal other than these two lights being on......thoughts on what might cause such a thing? Seems strange they both came on together.
    Thanks in advance!
  2. Sep 2, 2025 at 8:27 AM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    I would say the two are not related. You have two separate issues.
    The TPMS light will come on for low tire pressure and when the battery in the sensor gets weak. The tire shops have a tool they use to find a weak battery in a TPMS sensor. Those batteries only live so long.
    As far as your charging system - the battery symbol on your instrument panel indicates that the battery is not being charged. It could be the alternator or something else.
  3. Sep 2, 2025 at 8:37 AM
    Ensure your ground wire on the battery is secure, first.
  4. Sep 3, 2025 at 8:58 AM
    DIPA
    Shawn
    Rhode Island
    Thanks for the info, had AAA visit: battery good, (original) alternator (190k miles) bad!
    AuSeeker and 3JOH22A like this.
  5. Sep 3, 2025 at 9:15 AM
    Did the TPMS light extinguish? The light could've come on because the TPMS ECU wasn't getting sufficient power with the alternator failure.
  6. Sep 3, 2025 at 9:35 AM
    Electrical issues can have bizarre symptoms but if they’re original tire pressure sensors (and assuming they’re the battery-powered kind) their time likely has come.
  7. Sep 3, 2025 at 4:12 PM
    Typical TPMS sensor battery life is 7 years. If a 2007 had its second set of sensors expiring at this point, it would've been considered above-average battery life.
