Changing wheels and tires
Discussion in 'Wheels & Tires' started by Cars, Mar 24, 2023.
  1. Mar 24, 2023 at 8:36 PM
    Cars
    Cars [OP] New Member
    Cars
    2022 TRD Sport
    None
    New to the forum. I have a 2022 4Runner TRD sport, stock. Stock tires are 245/60/20. Looking to replace for aesthetic reasons only.
    Will a 275/55/20 fit? Will it rub? The item in question is from a 2016 predator edition.
    Any information would be appreciated!
    Junya likes this.
  2. Mar 25, 2023 at 7:05 AM
    That's pretty close to the OEM size. I think it will come down to wheel offset and your alignment specs. I would expect the possibility of some minor trimming, if anything.
  3. Mar 25, 2023 at 7:07 AM
    Cars
    Cars
    2022 TRD Sport
    None
    Thank you!
  4. Mar 25, 2023 at 7:11 AM
    Well69
    Well69 New Member
    2022 Limited 4Runner
    It's worth checking out the spreadsheet for tire sizes. It's on the forum.
    The offset does matter. I learned this the hard way. I still don't really understand what the offset is, just that I had some plastic rubbing.
  5. Mar 25, 2023 at 7:12 AM
    Cars
    Cars
    2022 TRD Sport
    None
    How do I find the spreadsheet?
  6. Mar 25, 2023 at 7:31 AM
    The best way I can describe it is the hub surface in relation to the center of the wheel. 0 offset, the hub is dead center. Positive offset moves it outward, making the wheel move inward. Negative offset is the opposite. Here's a picture stolen from a tire dealer's website:
    Here's the article I stole the picture from:
    https://www.lesschwab.com/article/what-is-wheel-offset.html
    I think @Well69 was talking about this:
    Well69[QUOTED] likes this.
  7. Mar 25, 2023 at 7:37 AM
    Cars
    Cars
    2022 TRD Sport
    None
    Thank you! This is great!
  8. Mar 25, 2023 at 7:50 AM
    Well69
    Well69 New Member
    Thank you
  9. Mar 25, 2023 at 9:56 AM
    2018 Limited
    2018 Limited New Member
    BDR
    2018 Limited
    There are offset and tire calculators online that may help you see this visually. You can input oem Vs your new size and it overlays the new size so you can see the differences. It will also provide you your data as well. Here’s one example below.
  10. Mar 28, 2023 at 9:37 AM
    Sejin
    Sejin New Member
    2017 Super White SR5
    I think as long as your within the OEM size you should be fine
